Husky floor liner warranty
Discussion in '2nd Gen Tundras (2007-2013)' started by Tundra234, May 29, 2020.
  1. May 29, 2020 at 5:11 PM
    Tundra234 [OP] New Member
    Have any of you dealt with Husky on warranty? My drivers floor mat has a couple of holes in it between the ribs. I saw them when I took the mat out to dump it and had dirt under it. They are probably 8 yrs old now but I think it's a lifetime warranty.
  2. May 29, 2020 at 11:05 PM
    MikeBeach
    MikeBeach New Member
    Houston TX
    '11 CM-DAP-SABM/AFE/5100s etc.
    Yeah lifetime printed on the set I just received today. Question, as I was getting ready to email them and found this thread. Did you use the supplied floor pins or use your factory retention clips. Reason I ask, installed them tonight and broke both of the clips they supplied.
  3. May 29, 2020 at 11:17 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  4. May 29, 2020 at 11:19 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    I'd contact them again and ask if you can purchase more clips.
    They might just send you some...
  5. May 29, 2020 at 11:50 PM
    MikeBeach
    Houston TX
    Thats what Im hoping. I've installed a lot of stuff, baffled how I broke both. Oh well.
  6. May 29, 2020 at 11:54 PM
    MikeBeach
    Houston TX
    Wow, I'm stupid. Didnt realize these came apart, this is what I get for thinking I'll just throw them in at 100am,after a few beers. Idiot.
  7. May 30, 2020 at 6:31 AM
    I used the factory on the drivers side and nothing on the pass side.
    BravoDeltaRomeo likes this.
  8. May 30, 2020 at 6:34 AM
    I didnt use mine don't feel bad.....I had no idea they came apart either.
  9. May 30, 2020 at 7:13 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    Only reason I knew those came apart was the top kept coming off when I tried to take it out.
    I ended up gluing them together.
    @MikeBeach your pass side clip looks different than mine.
    My 'screw' in piece has a threaded end like a wood screw.
    It screws into the carpet to keep it in place.
    And to those that have that and can't get the screw to catch;
    I could not get that 'screw' to go into and stay in the carpet.
    I ended up putting a very thin piece of scrap wood under the carpet.
    Put the mat in, marked where the hole is in the carpet with a sliver sharpie.
    Pulled the mat out, stuck the wood under the carpet
    Drilled a small starter hole, put the mat back in, gently screwed the screw in place.
    I'm just careful with it when I need to remove it not to overtighten it.
  10. May 30, 2020 at 7:22 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    His driver's side clips look like the ones I had in my 2005.
    Grommet hole in the carpet and those clips click into it and the hook ends go in the holes of the mat.
    My 2014 driver's side has the clips that turn and lock I'm guessing like you have.
  11. May 30, 2020 at 8:39 PM
    MikeBeach
    Houston TX
    Correct, the p/s threaded in fine and work great. The caps were so tight I had to use pliers. I ended rigging something together that may end up being better then theres. JB weld and I hacked up the OEM clips.
    1lowlife[QUOTED] likes this.
  12. May 30, 2020 at 10:02 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Looks like something I would do...:thumbsup:
  13. May 31, 2020 at 8:05 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    Finally found the pics of the mats I had replaced..
    D935EE6F-6182-4749-BE08-925B833577E3_zps_bdd293927386c4513ae59326f1e2974cba6ce9cd.jpg
    F0EB5B47-1510-40F1-AE73-C49DAE5B6736_zps_77a51710898eab2a65462061a5a9da3f0eacc928.jpg
    2 weeks later..
    4BA8229B-B041-4F1B-BA45-64342A805AC1_zps_06548763820396d9036d32f38993116608e0809c.jpg
