Rear Shock Advice
Discussion in 'Suspension' started by ND1992, Apr 20, 2020.
  1. Apr 20, 2020 at 3:08 PM
    ND1992
    ND1992 [OP] New Member
    Nate
    Denver, Colorado
    2015 SR5 Double Cab, TRD Off-Road Package
    Just bought my 2015 SR5 Double Cab a few months back but the rear shocks need to be replaced. The truck has the TRD off-road package so it came with Bilstein 4600 shocks (#48530-0C031). I am not really interested in getting any kind of lift so my first thought is to just replace with the OE Bilstein shocks. I do some mild off-roading, so would it be worth it to upgrade to something different? Could I even do that if I still have the OE shocks on the front? Budget is a factor but I would spend a little more for a better quality shock if that's what is recommended.
  2. Apr 20, 2020 at 3:10 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    5100s to the rescue
  3. Apr 20, 2020 at 3:13 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Have the fronts been replaced already? I gotta think of the rears are shot, so are the fronts.
  4. Apr 20, 2020 at 3:17 PM
    ND1992
    Nate
    Denver, Colorado
    The fronts have not been replaced. It has about 45K miles on it, and apparently the previous owner must have done some serious towing to wear down the rear shocks so soon.
  5. Apr 20, 2020 at 3:19 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    2022 GMC Sierra AT4 L5P - 2017 4runner SR5P - 2023 Tesla Model 3 LR
    Is it the shocks or the leaf springs?
    My rear leaf springs flattened very quickly. I didn't tow much and never had a load that even came close to capacity.
    Also welcome from Utah!
  6. Apr 20, 2020 at 3:25 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I put on 6112s in the front and 5160s in the back and love them! They really soak up the bumps. Ran me about 1100 for the set with the fronts already assembled, i agree with @Backslider the it could be the leaf springs, mine are wore out and I need to replace them as well
  7. Apr 20, 2020 at 3:52 PM
    ND1992
    Nate
    Denver, Colorado
    I think it's just the shocks. So if I were to put in 5100s in the back and keep the 4600s in the front how would that affect lift heights?
  8. Apr 20, 2020 at 3:53 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Well, at lowest setting the 5100s still have a 0.75" lift to them. You may have a slight rake but if you have an aftermarket bumper it probably wouldn't be so bad.
    Sumo91 likes this.
  9. Apr 20, 2020 at 3:54 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'd replace them all at the same time.
    Sumo91 likes this.
  10. Apr 20, 2020 at 3:54 PM
    Sumo91
    TN
    With 5100s or 5160s in the back it wont affect your ride height unless you add shackles or blocks. The shock wont lift your truck, it just helps with the rebound. the leaf spring is what will make your truck keep its height. If its worn, your rear end will sag.
    SC_TRD likes this.
  11. Apr 20, 2020 at 3:57 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Whoops. @Sumo91 is correct. The front shocks have some lift to them. Rear, none.
    Sumo91 and SC_TRD like this.
  12. May 30, 2020 at 6:18 PM
    ND1992
    Nate
    Denver, Colorado
    Thanks for the replies everyone. I have decided to go ahead and replace all 4 with the 5100s. Can you tell from the photos if my leaf springs are worn and would also need replacements?
  13. May 30, 2020 at 6:52 PM
    Tundraman479
    Tundraman479 New Member
    2024 Tundra Crewmax TRD Sport Lunar Rock
    TRD Pro Suspension 275/60r20 Wildpeaks
    Did the ride improve after installing the 5100's?
