Pro comp tie rod question
Discussion in '2nd Gen Tundras (2007-2013)' started by Forcefed, Apr 21, 2020.
  1. Apr 21, 2020 at 5:36 AM
    Forcefed
    Forcefed [OP] New Member
    2007 Tundra Limited
    6 inch lift, ADS suspension, Alcan custom rear springs, 46 gallon metal gas tank, Full Line-x body, Wheels with 35's, Smittybilt bumpers front and rear, 10k warn winch, custom rack.
    I have currently been rebuilding my front end of my tundra. I have a pro comp lift installed but the pro comp coils had started to leak so I decided to upgrade. I installed ADS coils all around, replaced all ball joints, upgraded to polys on the control arms, new steering rack with polys, new hubs, new power stop brakes and rotors, and new tie rod ends. The problem I have is I originally ordered moog tie rods, but the guys at ADS said to use the pro comp tie rods, so I ordered those. When I went to install the pro comp tie rods I noticed how short they are, and I only get about five or so turns with them, and the moog I get about 20 turns. The truck originally had the the moog tie rods and seemed fine. My question is, is this normal for the pro comp? Another thing is the moog seems to allow more travel than the pro comp. For comparison the moog tie rods are about 2 inchs longer than the pro comp.
  2. Apr 21, 2020 at 12:24 PM
    MyFj08
    MyFj08 New Member
    Mark
    2012 crewmax 4wd.
    I'm working on it
    Go to Coachbuilder outer tie rods they are much better quality the procomp
  3. Apr 21, 2020 at 12:28 PM
    Forcefed
    2007 Tundra Limited
    I was thinking about that, I just don't know if my rims will clear. I thought you need 20 inch rims for them, and I only have 18s on my truck.
  4. Apr 21, 2020 at 1:27 PM
    MyFj08
    MyFj08 New Member
    Mark
    2012 crewmax 4wd.
    I'm working on it
    They are the same as the procomp
    Just twice the quality
    Also. Email or call Dave. And ask him he will know
    And is always very helpful
  5. Apr 21, 2020 at 1:33 PM
    Forcefed
    2007 Tundra Limited
    I will hit him up. If this does work this should really finish up the front end. The only reason I didn't go with the Coachbuilder is I thought they wouldn't fit. Thanks for the info. Next will be the custom rear leafs.
  6. Apr 21, 2020 at 1:36 PM
    MyFj08
    MyFj08 New Member
    Mark
    2012 crewmax 4wd.
    I'm working on it
    I have the procomp 8" lift
    And put on the Icon RX . Leaf spring pack with the Coachbuilder +3 shakles. And let me tell ya the ride quality is superb
    Bigboitundra likes this.
  7. Apr 21, 2020 at 1:41 PM
    Forcefed
    2007 Tundra Limited
    I have to do a custom setup because I did a 48 metal gas tank with full size spare on the tailgate and a roof top tent on my custom rack and I need to up the weight on the rear springs. Plus, fix the major lean I get when the tank is full. My current driver side leaf is flat, starting to go the other way. Once I finish up the front it goes in for the rear.
  8. Apr 22, 2020 at 5:43 AM
    Forcefed
    2007 Tundra Limited
    Just an update. I installed the pro comp tie rod ends to check fitment and the rim does not fit with them on. Now I know why the guy before me had the moog tie rods. I think I'm just going to bite the bullet and buy different rims and coachbuilder tie rods.
    MyFj08 likes this.
  9. May 5, 2020 at 8:53 AM
    MyFj08
    MyFj08 New Member
    Mark
    2012 crewmax 4wd.
    I'm working on it
    18" wheels. (Rims)??
    I know the specs on my 7" procomp lift
    Says 5" max back space with 18's & 6" back space with 20's
  10. May 28, 2020 at 10:42 AM
    Forcefed
    2007 Tundra Limited
    Sorry about the late delay, been busy. I got the front end all together and I had to put the moog tie rods on just to get it back on the road. I ordered tie rods from Dave. I just need to order wheels so I can run the new tie rods. Looking for 18's that will work, really don't want to go for 20's. I think a -24mm offset will clear the tie rods with 18's. Going to go to a local shop to check it out. The truck should be going in today or tomorrow for the new rear leafs to be built. I'll post a pic when I finally get this build all done. Also, my bed stiffeners came in, and they're at LINE-X right now getting coated.
