Way to dim or turn off dash lights?
Discussion in 'Lighting' started by ncorry, May 5, 2020.
  1. May 5, 2020 at 7:27 AM
    ncorry
    ncorry [OP] New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    I know about hitting the stalk on the left of the instrument cluster, but does anyone know of a way to completely turn off the dash lights regardless of headlights being on/ off or how bright it is outside?
    If there's not one, anyone know of a wire or circuit that I could wire a switch into?
    I do a lot of night-time hog hunting and best I've come up with so far is to wedge a bunch of rags into the instrument cluster......
  2. May 5, 2020 at 7:30 AM
    I would think the hogs would hear the truck before they see dash lights on the lowest sitting.
    What’s the plan post hunting with it for driving?
    Tundyfundy and BENWALES like this.
  3. May 5, 2020 at 7:34 AM
    ncorry
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    It's not an issue with the hogs seeing the dash lights, it's having them shine in my eyes. We cruise delta farmland with multiple thousand acre, perfectly flat fields. With NV and thermal scopes, we can see/ detect hogs at over a mile on a good night.
    Plan post hunting is to turn them back on. I may be missing something about this question.
    Tundyfundy and T-Rex266[QUOTED] like this.
  4. May 5, 2020 at 7:34 AM
    :anonymous: I read your last part as you want to cut the wire
    Tundyfundy likes this.
  5. May 5, 2020 at 7:36 AM
    ncorry
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    10-4! Nope, don't want to make it permanent. Of course most prospective used truck buyers usually test drive during the day..........
  6. May 5, 2020 at 7:54 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Pull the fuse?
  7. May 5, 2020 at 7:56 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I keep mine pretty low, but I thought if I turned the knob all the way to the left they turned off.
    I'll check it again tonight..
  8. May 5, 2020 at 8:42 AM
    9am53
    9am53 New Member
    adam
    2015 Black RCLB 4x4
    2020 PRO headlights and grill
    You have adjusted the brightness using the knob in the guage cluster right?
  9. May 5, 2020 at 8:58 AM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    Also on my 20 you can turn off the head unit. I believe it is under projection and at the bottom there is a button to turn the screen off.
  10. May 5, 2020 at 9:53 AM
    Rngr188
    Chad
    Harrison AR
    Ok so I just looked, there are two "knobs" one at the speedo side that goes through trip and odo. On the tach side there is a "knob" press it in to adjust your dash brightness its a bar that goes full black for off to full blue for brightest and any brightness in between. On my 20 press Menu on the HU and at the bottom is a display button press it and turn display off, screen will be blacked out but music will still play. Doing that will give you a blacked out interior.
  11. May 5, 2020 at 11:02 AM
    ncorry
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    I can turn the HU display off on my 19. During the day, the stalk on the left of the cluster will turn dash lights off, but won't go all the way off at night when the truck's little light-sensing brain knows that it is dark outside.
  12. May 5, 2020 at 11:54 AM
    Rngr188
    Chad
    Harrison AR
    Cover the dome sensor in the middle of the dash :notsure: Idk.
    Edit: Nevermind that idea as it would still think it's dark.
    I tried mine today at lunch and the dash lights went dim, didn't think about the night aspect
  13. May 5, 2020 at 3:31 PM
    U can cut a wire for the DRL (which controls the cluster lights during the daytime when it thinks it’s night)...idk if that makes sense
    Pudge likes this.
  14. May 11, 2020 at 10:57 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    I was wrong, the dash lights do not dim down to off.
  15. May 11, 2020 at 11:19 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Ditto. Only dim but don’t shit off. Sounds like they fixed this on 2020 models.
  16. May 11, 2020 at 11:35 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    You could probably cut the ground to the dimmer circuit and put a switch in line. Should kill all your interior dash lights.
    Make a little jumper harness to do it without damaging the trucks harness
  17. May 12, 2020 at 2:42 AM
    Zero One Actual
    @ncorry
    We do the same thing and I know exactly what ambient light can do to you while driving. The easiest solution I came up with and cheapest was to take a large piece of black foam, cut it down to fit perfectly into the dash and then make small cuts with a blade until it fits perfectly into the dash. I also got some multicam black fabric and used wallpaper glue to glue it to the foam, I then cut two holes on the sides of the foam and tied 550 cord through them to use to pull the foam out. It is pitch black. Then when done, grab the 550 loops, pull the foam cutout off the dash and toss it in the back and you are driving normally again.
    https://www.rockywoods.com/500-Denier-Mil-Spec-Nylon-Camouflage-Fabric-MultiCam
    https://www.amazon.com/Case-Club-Cl...s=custom+cut+foam+black&qid=1589276815&sr=8-8
    Also, by going this route, you don’t need to deal with wires, fuses or messing with electrical stuff.
    BrandonL812, 1lowlife and GODZILLA like this.
  18. May 27, 2020 at 11:51 AM
    ncorry
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    Don't know how I missed your reply, but thank you!!! You got a pic of the finished product?
