High Idle
Discussion in '2.5 Gen Tundras (2014-2021)' started by WildcatTundra, May 26, 2020.
  1. May 26, 2020 at 6:54 PM
    WildcatTundra
    WildcatTundra [OP] New Member
    Bought my first ever new Tundra (2020 - 1794 Edition) last month and I LOVE it.
    Previously have owned new Ford, Chevrolet, and GMC trucks that were all very nice, but I can already tell the Tundra will be my favorite.
    (I will ask you in advance to forgive me for posting this Tundra neophyte question):
    When I first start my Tundra it seems to idle/rev much higher than other trucks I have owned. Wondering if this is typical with Tundras, or if I have some type of switch/feature engaged that I shouldn't have, or if I need to take it back to the dealer to check?
  2. May 26, 2020 at 7:33 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Mine has done this as long as I've owned it. I assumed it was normal because I read about some Lexuses doing the same thing but I'm sure someone with more Tundra experience than me will chime in.
    YardBird likes this.
  3. May 26, 2020 at 7:40 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    A high idle on start up is normal for the 3rd gen. Tundra.
    My 1997 Toyota T100 high idles on start up.
    Start it. Drive it. Enjoy it.
  4. May 26, 2020 at 7:41 PM
    1engineer
    1engineer New Member
    Appalachians
    2019 Tundra Limited TRD Off Road.
    Normal, and not much different than other brands. Almost every gas engine is set up to bring everything up to temp quickly and that is what high idle does.
    YardBird and 15whtrd like this.
  5. May 26, 2020 at 7:48 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    Noticed it with mine right off as well, but it settles down quickly and I am used to it now. The engineers probably designed it that way for a reason. I didn’t like the fast idle right off, but then full synthetic oil is a much better lubricant. The viscosity is low, so I guess the big engine gets quickly oiled up. My BMW was the same and still going strong at 267k miles.
  6. May 26, 2020 at 7:49 PM
    15whtrd
    15whtrd Mr. Blonde
    Normal. My neighbors love it so much especially with the 6 inch dirty deeds mufflers. He tells me it sounds like an airplane taking off.
  7. May 27, 2020 at 4:41 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    You're my hero of the day!!!
    15whtrd[QUOTED] likes this.
  8. May 27, 2020 at 5:06 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    This is done as part of the process to get the converters up to operating temp ASAP to reduce emissions. This is also the reason for those dang secondary air pumps that so many have issues with. Those pump air into the exhaust stream to fire up the converters. Other manufacturers have their own methods for accomplishing the same. The Tundra's viscous clutch fan is usually locked at this point as well and adds to the volume; this usually disengages after about a minute or so. Some applications use an electric so it's not heard, and we get used to that. I think I read that Toyota keeps the clutch fan because it reliably moves the most air, versus electric of comparable diameter.
    15whtrd likes this.
  9. May 28, 2020 at 10:53 AM
    15whtrd
    15whtrd Mr. Blonde
  10. May 28, 2020 at 11:07 AM
    TomyTun
    TomyTun New Member
    CA
    2016 TRD Off Road, Crewmax, 5.7L Non-FFV
    None
    Yup. Mine does the same too.
