Undercover Ridgelander + Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by trd.james, May 22, 2020.
  1. May 22, 2020 at 1:10 PM
    trd.james
    trd.james [OP] New Member
    James
    2020 TRD PRO | Westcott Lift | 35" KO2's
  2. May 25, 2020 at 9:25 PM
    dsnuts
    dsnuts New Member
    18 sr5 crewmax
    i was the undercover rep for western Canada. I had one on my dodge ram 1500. good cover, hard to open with any sort of weight on it as the shocks aren't rated for much more than the cover itself. If you want storage above and below your bed its a great setup. if you are constantly using the bed for taller items then i suggest that its not the cover for you.
    trd.james[OP] likes this.
  3. May 26, 2020 at 7:07 AM
    trd.james
    James
    @dsnuts Thanks for the reply! I'm thinking I'll end up with the RetraxPro XR, which is where I started. I liked that the Undercover came with the crossbars included, so the pricing was much better 'all-in'. That said, I don't think it suites my needs as well as the Retrax does.
