Rear end Swap for MPG?
Discussion in '2nd Gen Tundras (2007-2013)' started by icket, May 2, 2020.
  1. May 2, 2020 at 7:48 AM
    icket
    icket [OP] New Member
    Eric
    2013 Tundra
    K&N Cold Air Intake Flowmaster
    As I understand, the 2013 Tundra had 4.30 rear end gears. I personally have not the need for that low of a gear. I could use a 3.73 gear and it would be beneficial to me.
    I called the local dealer and said that the 4.7L trucks came out with a higher rear end gear but I couldn't use it, I would also have to change the front differential gear as well.
    Has anyone been through this?
  2. May 2, 2020 at 2:18 PM
    Dr_Al
    Dr_Al New Member
    Al
    Welcome. Is your Tundra 4wd? If so then you would need to change both front and rear to be able to continue to use 4wd. If just a 2wd obviously not. I'm not sure how much gas savings you would get by going to a taller gear.
  3. May 2, 2020 at 2:28 PM
    Blue Thunder
    Washington
    Don't chase that dog...complete waste of time. What very limited MPGs you gain will never pay for the cost of the swap.
    There's no magic bullet for MPGs other than slowing down or driving another car. Gotta pay to play...
  4. May 2, 2020 at 2:30 PM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    +1
    Tundyfundy and YardBird like this.
  5. May 2, 2020 at 2:38 PM
    timsp8
    NY
    Yep. People chase better mpg and spend more than they save to do it.
  6. May 2, 2020 at 2:47 PM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    I wouldn't do it. You run the risk of making it worse because it may not want to stay in overdrive from "lugging" the engine.
    revtune likes this.
  7. May 2, 2020 at 2:58 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    Is your truck completely stock? Are you running heavier wheels and or larger tires? Changing gears to 3.73 would be an absolute waste of time and money. There’s plenty of data from members here and other owners of 2nd and 3rd gen tundras about the lack of fuel economy. If the mpg bothers you that much, perhaps you need to sell the truck.
    Blue Thunder likes this.
  8. May 2, 2020 at 10:18 PM
    Tundra_power
    Tundra_power New Member
    I have 4.10 gears sport package..
  9. May 5, 2020 at 2:26 AM
    Bloomjtundra
    Bloomjtundra New Member
    Josh
    2011 Tundra DC 4x4
    What gearing is used on a 2011 SR5 4x4 with tow package?
  10. May 5, 2020 at 3:39 AM
    Adam New Member
    Buy a Prius if you want MPG.
  11. May 5, 2020 at 11:40 AM
    Tundra_power
    4:30
  12. May 5, 2020 at 11:48 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    You would be spending $1-2k for the parts and labor to install. That $ would buy a ton of gas.
  13. May 5, 2020 at 11:59 AM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    The 4.6L and 4.7L powered trucks have a different rear axle. The 10.5" unit behind the 5.7L trucks doesn't have too many gear options and 3.73 gears do not exist for it. For a few years 5.7L trucks were made without a tow package and received 4.10 gears. Going down this route is not worth your time.
  14. May 5, 2020 at 11:59 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    The truck is already turning 2000rpm or so at 80mph on the interstate, I can't imagine lower rpm providing enough torque for cruising let alone being lower enough to substantially change your fuel consumption.
  15. May 5, 2020 at 1:23 PM
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    Put the pen to paper and figure out if it's worth the gamble/effort or not.
    15000miles/yr ÷ 17mpg = 882 gals of gas @ $2/gal = $1764.
    15000miles ÷ 20mpg = 750 gals of gas @ $2/gal = $1500
    $1764 - $1500 = $264 per year in fuel savings
    If a regear cost you $1000, it will take roughly 4 years to just break even on gas savings - assuming you actually achieve a massive 18% increase in avg. MPG.
    Timing of the Return On Investment will vary as any/all of these factors change: miles driven, price of fuel, cost of regear, and actual mpg efficiency gained/lost. More miles, higher price of gas, lower cost of regear, or greater mpg efficiency gain will see a faster return, while fewer miles, cheaper gas, higher cost of regear, or lower mpg efficiency gain will take longer to recover.
    Obviously if the change for whatever reason results in fewer mpg than you're currently getting now it will be totally wasted effort and an ongoing negative $ return on the investment to regear.
    careyrob and Bloomjtundra like this.
  16. May 24, 2020 at 6:06 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    If you do change gears. You will have to reprogram the transmission other wise you will dump extra fuel into the engine or run lean witch wont help at all. The gearing is all done by the factory for the optimization of the setup . Unless your changing tire size dont change your gearing for mpg. It will be to much of a headache and thousands of $. It will not be worth it
