2010 Tundra spark plugs
Discussion in '2nd Gen Tundras (2007-2013)' started by WhitmanTundra, May 21, 2020.
  1. May 21, 2020 at 5:50 PM
    WhitmanTundra
    WhitmanTundra [OP] New Member
    Alexis
    Illinois
    2010 Toyota Tundra SR5 4.6L V8 double cab
    So I have a 2010 Tundra 4.6L V8
    I am changing my spark plugs.
    I've never done this service before, but I read my service manual and my owners manual and I saught YouTube and it seemed like a task I could tackle.
    I've completed 7 of the 8 spark plugs
    1. On the passenger side of the engine, the spark plug closest to my cab seems to be impossible to access. There is a solid metal line of sorts that doesn't seem to want to budge and then all of the wire harnessing.
    I did remove my whole air intake thing with the filter and what not, to give me more room....but for the life of me I cannot access that 8th plug.
    Help?
    Tips?
    2. I noticed on the plug just before this one in question, was covered in oil when I removed it. So far, that was the only one. Though I assume that 8th and final plug will also have oil.
    I assume this oil is from a valve cover gasket needing replaced.
    Any tips on this?
    Is this something the average DIY person could accomplish?
    Thank you, as always.
  2. May 22, 2020 at 9:15 AM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Might be a long shot but I know on other trucks that last plug was gotten from underneath and reaching up to it .
    WhitmanTundra[OP] likes this.
  3. May 22, 2020 at 9:18 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Not sure if you have tried, but on the 5.7 you basically need a bunch of short 1" extensions and the plug socket. Feed them in 1 at at time until you can put a wrench on it.
    Oil on the plugs can be the tube seal and not the valve cover, but you usually replace them both at the same time anyways.
    WhitmanTundra[OP] and zachzap361 like this.
  4. May 22, 2020 at 10:38 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    Seriously though, back in the 80's when I worked for an indy auto shop, I could not stand working on imports. Domestics then were easy in comparison. I didn't usually need any real specialized tools. The imports were a pain. It was hard to get to a lot of things without scraping knuckles or the bolts were just simply inaccessible without pulling off other PITA components.
  5. May 23, 2020 at 7:04 AM
    WhitmanTundra
    Alexis
    Illinois
    Well, I got all 8 spark plugs
    But now my truck runs really bad. My check engine light is on. I think a lot of fuel is coming out my exhaust, by the smell. And my truck thinks it's in 4low even though it isn't.
    Not sure what I did wrong
  6. May 23, 2020 at 10:47 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Plug wires all on? Any loose vacuum hoses? CEL? Scan it for a quick answer.
  7. May 23, 2020 at 10:49 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    I'd double check all your connectors just to make sure they're seated fully. It almost seems like you might have disconnected something from the air injection valves if the 4.6 is anything like the 4.7.
  8. May 23, 2020 at 11:18 AM
    WhitmanTundra
    Alexis
    Illinois
    I'll double check everything....I got really nervous and just shut it down. But I appreciate the thoughts....I'll go over everything with a fine tooth comb.
    I don't have an OBD scanner. I should probably get one. Blue driver is supposed to be really good, yea?
  9. May 24, 2020 at 2:09 PM
    WhitmanTundra
    Alexis
    Illinois
    Well as it turns out, I had a connecter for one of my spark plugs disconnected.
    After that, my truck started up and ran just normal.
    My traction control light was still on, check engine light still on, and 4 low blinking. So after a Google search on that its something about an AIP something or other. So I disconnected my battery for 10 minutes. Now it starts up just fine and sounds great. No lights. And my truck shifts through all the 2wd, 4hi, and 4lo just fine.
    I'll still probably have my mechanic check it over. But dang....that was scary!
    NewImprovedRon and mich27 like this.
  10. May 24, 2020 at 2:36 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    I wouldn't rush to the mechanic. Drive it normally and then see what happens.
  11. Jul 15, 2021 at 6:38 AM
    mich27
    mich27 New Member
    Hi whitmantundra,
    i got the same problem about remove #8 spark plug on the 4.6 liter v8,
    kindly show me how you did . very much appreciated
    mich27
  12. Jul 15, 2021 at 10:08 AM
    WhitmanTundra
    Alexis
    Illinois
    Honestly, I had to get very clever with a swiveling ratchet, extensions, and patience. There was a profound amount of cussing, kicking buckets, and taking breaks.
  13. Jul 15, 2021 at 2:26 PM
    mich27
    mich27 New Member
    still can not remove the igniter # 8 , because the metal tube that welded-bar blocked the igniter to be lifted out,. I removed 2 bolts #10
    that hold the electric- wires- bundles on the firewall,and the bold that hold the water heater tube , could not move that metal tube, no prevailed.
    So I put back old # 8 , never got to see the sparkplug. :-( .
  14. Aug 8, 2021 at 12:37 PM
    Rustynut61
    Rustynut61 New Member
    2010 tundra 4.6
    Mich27
    There are 2 12mm bolts that hold the tube in question, the back on is a little tricky to see. By removing them and you already removed the harness bolts you can move the tube and the wires around and change that rascal out fairly easy. Hope this helps.
    NewImprovedRon likes this.
  15. Aug 9, 2021 at 3:31 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    I just used a 6" flex spark plug socket from gearwrench a 4inch square swivel extension from snap on and a folding head style ratchet snap on , made it easy :rofl: , just remember to disconnect your battery or cover it with rubber mat. "I totally don't have a history of forgetting an touching things an making sparks" :annoyed:
