LED Interior Lights
Discussion in '2.5 Gen Tundras (2014-2021)' started by leesmanTRD, May 2, 2020.
  1. May 2, 2020 at 5:18 AM
    leesmanTRD
    leesmanTRD [OP] New Member
    2020 Black TRD Sport
    New Tundra guy here, been browsing the forums for a while finally picked up my 2020 TRD Sport on 5/1/20. My first “mod” is LED interior lights, looking for a kit that doesn’t mess with the remote locking sensor that’s right near the cargo light. Any suggestions?
  2. May 2, 2020 at 5:55 AM
    platslvrblt19
    platslvrblt19 New Member
    San Antonio, TX
    ‘19 Silver Platinum Tundra
    After researching and almost pulling the trigger on much more expensive lights, I went with the Fyre Flys on Amazon, no issues - easy plug and play.
    NewImprovedRon likes this.
  3. May 2, 2020 at 5:57 AM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    A second vote for Fly’s
  4. May 2, 2020 at 5:59 AM
    16 blue crewmax
    16 blue crewmax New Member
    Doug
    Richmond Virginia
    2016 Blazing blue pearl crewmax trd
    superbrightleds is what I am using with no issues
  5. May 2, 2020 at 6:11 AM
    leesmanTRD
    Just ordered these on Amazon! Thanks for the help
  6. May 2, 2020 at 6:59 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Disconnect the battery before you swap them. Too many people blow fuses swapping them
    VSB, CH1NO, HulkSmurf14 and 1 other person like this.
  7. May 2, 2020 at 7:05 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    This!
    Or your second thread will be "I just swapped my interior lights to LED and now nothing works"
    CH1NO, TRDOBSESSED and WFD473 like this.
  8. May 2, 2020 at 7:37 AM
    platslvrblt19
    San Antonio, TX
    This, or I just closed the doors and made sure the lights were completely dim before making the swap.
    CH1NO and NewImprovedRon like this.
  9. May 2, 2020 at 11:40 AM
    egibson606
    egibson606 New Member
    Eric
    Georgetown, ky
    2019 super white SR5 tundra
    I'll toss in another vote for the fyre flys. 19 and zero issues with them and the remote.
  10. May 6, 2020 at 9:33 AM
    Singhv497
    Singhv497 New Member
    Vikash
    2019 Toyota Tundra Platinum
    Anyone know the difference between the Fyre Flys and the GTR lighting bulbs?
  11. May 6, 2020 at 10:28 AM
    Eric the Ricer
    Eric the Ricer New Member
    2020 CM Limited MGM
    I just put in the Fyre Flys in my 2020, everything is working as it should. Have a few extra bulbs since Toyota has decided to eliminate a lot of lights.
  12. May 6, 2020 at 10:55 AM
    Singhv497
    Vikash
    Thanks... I should have put besides the price haha
  13. May 6, 2020 at 11:04 AM
    LittleTRD
    LittleTRD New Member
    James
    Central California
    2015 Tundra Crewmax
    Camburg UCA's, Fox Factory 2.5's Front & Rear, Coachbuilder +3 Shackles, Decked Bed System, Snugtop Rebel Shell, switch pros 9100, and baja designs for all additional lighting.
    Beesta likes this.
  14. May 10, 2020 at 5:49 AM
    Tactun
    Tactun New Member
    Tom
    South Florida
    2020 Silver XSP
    Has anyone installed footwell lights that can change color? I see vleds has a package but they’re a single color.
  15. May 21, 2020 at 6:16 AM
    leesmanTRD
    Fyre Flys installed, but I had issues with the key fob working while the cargo light was still on. Talked to their customer support and they’re sending out cargo lights that won’t interfere
  16. May 21, 2020 at 6:35 AM
    platslvrblt19
    San Antonio, TX
    Interesting, was it not locking while the lights were still on and it worked once lights went off?
  17. May 21, 2020 at 7:15 AM
    leesmanTRD
    Yeah while the cargo light was on the key fob wasn’t working at all, apparently it’s got something to do with the frequency given off by the led bulbs. The sensor for the fob must be up near the cargo lights
  18. May 21, 2020 at 9:32 PM
    Tundratech
    Tundratech New Member
    The CorsoMotion is the best LED interior kits IMO, I have tried many LEDs but this kit is the best.
    The reason is,
    Cheap $10 eBay LEDs use simply like direct power way, means using just resistors to drop down a car/truck voltage 12v to lower for LEDs,
    so the voltage on the LEDs is not stable and slowly damaging the LEDs, and this causes the LED color fading problem after some use, and
    eventually LEDs might die or get dimmer.
    The CorsoMotion LED has current control type chip, you can see the picture from LittleTRD (thanks)
    there are 2 on that board, means for driver and passenger's side.
    That chip provide stable current power to the LEDs, so the LEDs never get hot and no damage and even Corsomotion LEDs use much less power from the truck.
    If you forgot to power off the interior lights, with CorsoMotion LEDs, no problem at all.
    I use CorsoMotion LEDs for my truck, and my Accord and this company is just the best.
    https://corsomotion.com/products/fi...terior-leds-07-20?_pos=1&_sid=7e7acbcd4&_ss=r
  19. May 22, 2020 at 5:23 AM
    TTund16
    TTund16 New Member
    Search the site before you start the work.
    I think it's easy to mess the dome light or break something in there or its hard to get to the light. Don't recall the details.
