entry doors?
Discussion in 'Home Improvement' started by smslavin, May 21, 2020.
  1. May 21, 2020 at 4:58 PM
    smslavin
    smslavin [OP] New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    so the 1940s era hardware on our front and side doors has finally given out. the deadbolt mechanism has sheared off on the inside so the only way to unlock the front door is from the outside. the doors themselves have warped and are starting to separate at the seams. need some recommendations on what to get for replacement. steel? fiberglass? straight up wood? if i'm just replacing the door, i don't need a prehung, right?
  2. May 21, 2020 at 5:07 PM
    @1UPPER
    He knows alittle about home repairs. :rofl:
    T-Rex266 and ColoradoTJ like this.
  3. May 21, 2020 at 5:12 PM
    smslavin
    Hudson Valley
    Some stuff
    really? never knew that... :typing: :spy: :D
  4. May 21, 2020 at 5:13 PM
    Yea, I've seen some of his work.....it's okay I guess.;)
    ColoradoTJ likes this.
  5. May 21, 2020 at 5:16 PM
    smslavin
    Hudson Valley
    Some stuff
    yea, he seems to be better at anodizing stuff purple than he is at building stuff...
    Squatting Pigeon likes this.
  6. May 21, 2020 at 5:33 PM
    I would not go with a solid wood door again in our climate. My entry door is needing refinished. So I will have to remove door, bar the front entryway, sand the door and refinish with SPAR varnish/urethane.
    You have seen my entryway, and that’s gonna suck ass.
    8147FE86-2A4D-4D44-A0D4-DEB6A58F636B.jpg 6C5F4619-8BCD-447F-ACF4-BC606E5967AC.jpg
    One of my carpenters buddies I have said once you remove a door from the frame, it really never goes back on from the original.
    I will refinish this door once and then replace the entryway with a more efficient one.
    T-Rex266 and Prostar 190 like this.
  7. May 21, 2020 at 5:42 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    With all the temperature swings and direct sunlight you get up there my money would be on steel.
    I've had them all over the years and steel has been the one with the most staying power for me.
    smslavin[OP] likes this.
  8. May 21, 2020 at 5:53 PM
    smslavin
    Hudson Valley
    Some stuff
    yea, that should be fun for you :D
    guess i'm making a home depot run tomorrow. now, to smart lock or not to smart lock?
  9. May 21, 2020 at 5:58 PM
    That wood does look good with that stone.
  10. May 21, 2020 at 6:01 PM
    I think most exterior doors from Lowes and HD are prehung. You might have to see if you have any local door builders.
  11. May 21, 2020 at 6:05 PM
    I would smart lock it. My kids have issues with locking doors. As of today, if I find a door unlocked, each have to pay me 1.00 and goes up .25 cents every time. This seems to be the only thing that works...taking money out of their accounts.
    smslavin[QUOTED][OP] likes this.
  12. May 21, 2020 at 6:06 PM
    Jrharvey02
    Jrharvey02 New Member
    That’s funny that you think HD is gonna have a front door for a 1940’s house that’s just gonna fit right in there...we owned a house for nearly a decade in whittier, 1896 built, everything was custom, hope you have better luck.
  13. May 21, 2020 at 6:06 PM
    Thank you.
    It wouldn't be my selection in doors though. Not very secure, the wood bows in the winter months, and isn't energy efficient.
    What kind of doors do you use in FL?
  14. May 21, 2020 at 6:11 PM
    They are mostly steel here due to hurricanes. There are some that are wood but the humidity wreaks havoc on them.
  15. May 21, 2020 at 6:11 PM
    smslavin
    Hudson Valley
    Some stuff
    yea, that's what i'm afraid of. at least for the front. side door was added during a remodel at some point but not done by us. wife already got in touch with a guy who's going to come by for a look see next week. figured i'd do a little homework as well.
  16. May 21, 2020 at 6:25 PM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    I have a wood grain fiberglass door. It’s pretty efficient and low maintenance. But I also have a good storm door. Too cold and snowy here during the winter, so a storm door helps keep the wind out.
  17. May 21, 2020 at 6:36 PM
    Atl626
    Atl626 New Member
    2018 black Crewmax SR5
    I'm a remodeling contractor in Atlanta, I would personally go for a fiberglass door, is impact resistant unlike steel doors and a quality fiberglass door has goo insulation. I once saw a carpenter bee going to town on a brand new mahogany door installed on a customers house....bees, sun make me shy away from any wood door, they are beautiful but a maintenance headache.
  18. May 21, 2020 at 6:39 PM
    Check out Provia doors they make a steel door that is wood grained and you can get it that looks like a stained real door they are great doors.
  19. May 21, 2020 at 6:52 PM
    Thank you Bryan....you are in fact a super secret elite member.
  20. May 21, 2020 at 6:53 PM
    We use their doors all the time they're top-notch. They're still doors have no wood inside the door once so ever just in the frame and they offer tons of options they will make the outside one color and the inside another color so you don't even have to paint it when it arrives.
  21. May 21, 2020 at 6:56 PM
    Go to Lowe’s to avoid the entry line
    Smart lock. All of our locks are Schlage. Proven (based on CIA books I’ve read :spy: ) to be one of the hardest to pick. Our front door is smart locked too. Some, you can also have it autolock based on your preferred time.
