Engine whine...
Discussion in '2.5 Gen Tundras (2014-2021)' started by Alloutdrs1, Apr 10, 2019.
  1. Apr 10, 2019 at 6:17 PM
    Alloutdrs1
    Alloutdrs1 [OP] New Member
    Andrew
    Virginia Beach, VA
    17' Tundra SR5, 12' Tacoma TRD offroad
    Not sure if it's normal or not but lately I've noticed my truck has a little whine to it when accelerating, more prounounced as the rpms increase and right before a shift. Doesn't get any louder if you step in it. I tried to get a video, not to sure if it can be heard or not.
    Any thoughts? Normal quirk of our trucks?
  2. Apr 10, 2019 at 6:19 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
  3. Apr 10, 2019 at 6:30 PM
    Blueknights75
    Ron
    Clayton, NC
  4. Apr 10, 2019 at 6:33 PM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    I don’t hear it. However, I don’t hear high pitch sounds as well as my wife and kids, so it’s probably me and not you.
    YsoSeRiouS! likes this.
  5. Apr 10, 2019 at 6:41 PM
    Racingjohndeere55
    Racingjohndeere55 New Member
    Sounded like a blower spooling up... when are you due for timing belt, water pump and belt tensioner? Might be due
    johnvan likes this.
  6. Apr 10, 2019 at 6:53 PM
    johnvan
    johnvan OG
    john
    Rensselaer,New York
    2016 inferno SR5 DC
    Is it still under warranty? Take it to the dealer if it is. Does sound like an idler or tensioner.
  7. Apr 10, 2019 at 6:58 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Exactly, but unfortunately no boost for me...lol. I'm only 1t 45k so I doubt timing chain.
    Idler or tensioner covered under powertrain? I'm past the Bumper to bumper 36k, if there not I will just remove belt and spin them by hand and see what they sound/feel like. At idle there isn't much whine, just under acceleration pretty much.
  8. Apr 10, 2019 at 7:04 PM
    Mnorris1206
    08 tundra
    Whine or a whistle? not trying to be off the wall but did you change the air filter to like a k&n ? Just wondering .
  9. Apr 10, 2019 at 7:11 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Its a whine, no whistle. No Intake for me, I have an Afe drop in and TRD airflow accelerator but this has become a recent thing and I have had those parts on for 15k now.
    Mnorris1206[QUOTED] likes this.
  10. Apr 10, 2019 at 7:21 PM
    Mnorris1206
    08 tundra
    Got ya strange
    Racingjohndeere55 likes this.
  11. Apr 11, 2019 at 4:18 AM
    Racingjohndeere55
    Turn the stereo up, run 'er til it blows.
    Walkem likes this.
  12. Apr 21, 2020 at 5:05 PM
    SuperWhiteTurdPro
    SuperWhiteTurdPro New Member
    2019 Super White TRD Pro
    I’ve got the same issue. Mostly under load around 2k rpm. Dealer couldn’t replicate of course. Worse when it’s really cold out and more evident upon cold starts but I can drive all day and can still hear it faintly. ‘19 w/20k
  13. Apr 21, 2020 at 5:11 PM
    Bronzeback
    Bronzeback New Member
    Mine is the same. Stops above 2k RPM. '17 with 17k miles.
  14. Apr 21, 2020 at 5:13 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Did you replace the throttle body gasket with one without the screen?
    GTBullitt68 likes this.
  15. Apr 21, 2020 at 5:13 PM
    SuperWhiteTurdPro
    It only started around 5k miles ago and that’s what bothers me. What could have changed?
    Edit: it’s totally different than the throttle body whistle that I can also hear. It sounds like one of those high mileage minivans that sounds like it is going to the moon with transmission whine before it shifts
    omgboost likes this.
  16. Apr 21, 2020 at 5:24 PM
    Bronzeback
    It's a whine, almost like a belt. Not the whistle that sounds like radio feedback or the fan motor of your HVAC, which is the high flow filter whistle.
  17. Apr 21, 2020 at 5:29 PM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    I say a bearing in a pulley...could be AC, PS, Alt, Tensioner, water pump, idler, etc.
  18. Apr 21, 2020 at 5:41 PM
    SuperWhiteTurdPro
    Agreed. Any way to home diagnose which one it could be? Seems like the kind of goose chase dealerships shrug off.
  19. Apr 21, 2020 at 5:43 PM
    Bronzeback
    Other threads say air injector pump. Only happens to me on cold days and goes away once fully warm.
  20. Apr 21, 2020 at 5:45 PM
    socaltundra951
    socaltundra951 Gentlemen Prefer Black Tundras
    Southern California
    Black CrewMax 5.7
    Someone who really likes you installed a supercharger while you were asleep.
    :thumbsup::burnrubber:
  21. Apr 21, 2020 at 6:09 PM
    SuperWhiteTurdPro
    Even when warm it’s present
  22. Apr 21, 2020 at 6:59 PM
    Crunch527
    Iowa
    Get a stethoscope and you can quickly find it.
  23. Apr 23, 2020 at 8:47 PM
    offsetplayer2
    offsetplayer2 New Member
    Woods and Fields, NC
    2018 Inferno CM 4WD
    I’ve had it since day 1. ‘18 here. Barely noticeable after you start getting up in speed and rpms but can notice when taking off.
  24. Apr 24, 2020 at 4:19 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Idler/tensioner pulley whine...it will oscillate with RPMs too, right? Tundras are known for occasionally faulty tensioners... had mine replaced and it fixed the whine...now it's back after 5k miles. It's a crap shoot with aftermarket and OEM on these specific parts...hard to pick up the clean end of a turd in this case. It 100% sounds like the tensioner from my experience...
  25. May 21, 2020 at 4:37 PM
    SuperWhiteTurdPro
    Agreed. Sounds like I may as well live with it...
  26. May 21, 2020 at 6:27 PM
    offsetplayer2
    2018 Inferno CM 4WD
    Mines whined since day one and goes up with rpms. I’ve lived with it for 35k miles and still runs good.
