Spacers for 2020 SR5 Tundra
Discussion in 'Wheels & Tires' started by GhostF8CEkill3r, May 18, 2020.
  1. May 20, 2020 at 2:05 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    If the spacer is still intact, which looks like it is, than this would have also happened with an offset rim. It puts the same pressure on the factory bolts as the spacer. The failure point was not he spacer but the factory bolts. Also looks like it was loose a while judging by the worn down area inside the spacer.
  2. May 20, 2020 at 2:10 AM
    Tundyfundy
    Bay Area, CA
    There warning signs all over this. That black around all the holes is indicative of some type of messed up mating. The spacer should sit flush all the way around and not have spot around the lugs. The more I look at this the more things look neglected and incorrectly installed.the fact that soot was getting between th hub and spacer most likely means they had been running them loose.
  3. May 20, 2020 at 2:27 AM
    Rob06struck
    Rob06struck New Member
    Rob
    06 Tacoma
    Alot
    My point is these things cause stress to factory components that they were not designed for. Do you really want to gamble with that kind of failure at 70MPH? Installation may void warranty if it can be proven that the spacer caused a given failure. Believe me a dealer will look really hard at that if it can save them $$$$
    That spacer was correctly installed on a Mall-Crawler.
  4. May 20, 2020 at 2:40 AM
    Tundyfundy
    Bay Area, CA
    Correct, the exact same stress an aftermarket rim would cause. No more no less. We are all about aftermarket parts here so no real argument there. As far as the correct installation I would beg to differ...
    as long as we’re quoting the Tacoma guys, here you go. 7 pages of “spacers work fine”.
    https://www.tacomaworld.com/threads/wheel-spacers-yes-or-no.464678/page-7
  5. May 20, 2020 at 2:41 AM
    Tundyfundy
    Bay Area, CA
    Post number 8 is spot on.
  6. May 20, 2020 at 2:50 AM
    GhostF8CEkill3r
    GhostF8CEkill3r [OP] Darth Tundra
    JSUN
    Conroe, Texas
    2023 Black Tundra Platinum Hybrid
    3" Front, 1" Rear - (Leveled) on 35" x 12.50"R20 Toyo ATIII w/1" wheel spacers.
    ahh yes... clear case of impact wrench and more cow bell!
    Tundyfundy likes this.
  7. May 20, 2020 at 7:16 AM
    Wallygator
    Tundyfundy[QUOTED] likes this.
