Replacing bed floor panels? (rusted completely through)
Discussion in '1st Gen Tundras (2000-2006)' started by taranovich92, Apr 27, 2020.
  1. Apr 27, 2020 at 6:09 PM
    taranovich92
    taranovich92 [OP] 300K mile club
    New Smyrna Beach, FL
    2003 Tundra T3 Edition
    Airaid cold-air intake, Airaid throttle body spacer, JBA headers w/ cats, Northeastern stainless resonator, MBRP 3" res-back exhaust, Eibach struts & springs @ 3", Suspension Maxx extended front links, SPC upper control arms, OME rear shocks, Husky Spring heavy duty leafs, 2" block in the rear, TRD rear sway bar, 1.25" wheel spacers, Nitto TerraGrappler G3 285/70/17, Apple CarPlay, CB radio, Randy Ellis Design front bar, Hella 500 rally lights, Mini LED projector headlights, Trailrunner Customs fogs, SkidRow Offroad skid plate, 333 Fab steering rack clamp.
    So I pulled my factory bed liner to finally take a look at how much rust I'm dealing with in the bed, and it's a lot. The bed floor is completely rusted through in several spots and it's rusty around 4 of the 6 bed mounting bolts. I got a sheet of corrugated metal from Jegs a couple years back for this repair but it doesn't match up too well with the Toyota bed. I'm going to pull the bed off and completely repair the floor and the mounting points. Does anyone know where I can find some corrugated metal bed floor panels for a 2003 Tundra? If that's even possible.
  2. Apr 27, 2020 at 6:27 PM
    Hillbilly Taz
    Hillbilly Taz New Member
    Glenn
    AL
    2011 Tundra SR5 DC, Silver Sky, 4.6 L V8
    Westin Steps, Tonneau Cover, Vent Visors, Go Rhino Dominator Step, Husky X-act mats
    Don't know. Hopefully someone will chime in.
    taranovich92[OP] likes this.
  3. Apr 27, 2020 at 6:46 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Maybe check for better condition beds on wrecked trucks?
  4. Apr 28, 2020 at 6:41 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    I'm in the same boat as you, Chris.. I found a couple junk yards out west (Arizona) that have pretty clean beds, and they're not too terribly expensive. Shipping adds a bit, but you could have a rust free bed for less than 1200-1400 dollars, delivered to your house.
    The other option is possibly find a local bed that you can cut the floor out of and use it to patch the areas that are bad. That might be what I do later in the summer when I get to that point. I'm still working under the front of the truck repairing the frame rust...:mad:
  5. Apr 28, 2020 at 7:08 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
  6. Apr 28, 2020 at 7:28 AM
    Ncherry84
    Ncherry84 New Member
    Nate
    Dickinson, ND
    2020 Tundra SR5 CrewMax Magnetic Gray Metallic
    Stock
    Myself personally, if see what the wreck ok ng yards have, but, 17 years old it may be slim pickin's. A lot of yards don't keep inventory much past 8-10 years old. That would probably be your best bet honestly.
  7. Apr 28, 2020 at 8:33 AM
    3.4Tundra
    3.4Tundra New Member
    Greg
    So. California
    2006 V8 Tundra 2wd
    Bilstein 5100
    There are a lot of these trucks out on the road still and many are reaching retirement age right about now... I'd go for a junkyard bed swap.
    Maybe you can leave your info with these yards and get a notification when one comes in?
  8. Apr 28, 2020 at 8:39 AM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
  9. Apr 28, 2020 at 9:06 AM
    taranovich92
    I looked all night online and could only find patch panels for old toyota pickups. Which looks like it could work in the middle of a first get tundra bed but who knows. But I need patches near the sides of the bed and it's a strange pattern on the first gen tundra. I'm doing this on the cheap so I'm at the point where I'm just going to find a guy with a big sheet metal brake, buy some 1/8th inch sheet and have him put the proper pattern in it, or close enough. Use that for the patches, use some kind of angle or channel for new supports underneath, weld it, seal it, paint it, and drop the factory liner back in. Hopefully it goes to plan hahaha.
    N84434[QUOTED] likes this.
  10. Apr 29, 2020 at 7:29 AM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    There's always hope....
  11. Apr 29, 2020 at 9:14 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Can't you just do flat patch areas? Just cut back to other clean rest free flat areas.
  12. Apr 29, 2020 at 10:45 AM
    G10dra
    G10dra Not a New Member
    If you're a DIYer than an unconventional way is to buy a parts truck and swap and fix everything at once..
  13. May 19, 2020 at 9:39 PM
    taranovich92
    Here's a little before and after. I wish I would've taken a picture of the bed before I spot welded the patches in. I just squared up the holes best I could with an angle grinder. I am going to coat top and bottom with KBS Coatings Satin Black and caulk all the seams with black silicone, then throw the factory liner back in. I will put up picturesIMG_7654.jpg IMG_7685.jpg when it's 100%. Should be solid for the rest of the time I own the truck and probably longer.
  14. May 19, 2020 at 9:41 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Cut and weld or flat bed that thing
  15. Mar 2, 2022 at 7:15 AM
    jefffrazee
    jefffrazee New Member
    2001 Tundra SR5, AC, 4x4, 4.7l
    I know this is kind of an old thread, but I too am having issues with the rust in my bed. What thickness steel did you use? TIA!
  16. Mar 2, 2022 at 10:03 AM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    When I did my bed, I used 1/8th inch steel plate, since it was a little easier to work with. I welded in flat panels, and then bent the ribs and welded those over the flat plate, to reconstruct the bed floor pattern.
    I have photos in my rebuild thread, if you need a reference.
  17. Mar 2, 2022 at 10:23 AM
    jefffrazee
    Awesome! thank you! I am getting my tundra back from my local dealership on friday from getting the frame recall completed and saw that there are a ton of rust holes. Thank you!
    G_unit3000 and N84434[QUOTED] like this.
  18. Mar 2, 2022 at 1:16 PM
    I noticed while looking up a part number for another member needing tailgate bumpstops the other day, Toyota used to sell the bed floor separately as a weld-in part.
    The part is discontinued but you may be able to find online or in overstock under either p/n 65311-0C010 or p/n 653110C010 if you have a '00-'06 access cab/non-stepside specifically. There would be several other variations using a (likely) different part number:
    - Access cab, stepside
    - Double cab, stepside
    - Double cab, non-stepside
    - Regular cab, long bed non-stepside
    - Regular cab, long bed stepside (did they make one? i dunno)
    - Regular cab, short bed stepside (did they make one? i dunno)
    I don't think they made the RC in a short bed, so I'm betting at least two are invalid, and there may be more configurations I didn't list. I just see you have an AC in the '00-'06 range like me, so I quoted our part number.
    Anyway, I'm damn near certain SOMEONE out there makes an aftermarket weld-in floor.
    G_unit3000 and FrenchToasty like this.
  19. Mar 2, 2022 at 6:19 PM
    nickrick78
    nickrick78 New Member
    Pittsburgh PA
    2004 DC
    I have some rust in the bed floor of my 2004 DC. Couldn't find any direct fit patch panels, so I ordered two of these 2ftx4ft panels for an older C10 that should hopefully be close enough, so I can repair the rusted parts.
    https://www.summitracing.com/parts/amd-791-4073
    G_unit3000 and N84434 like this.
  20. Mar 2, 2022 at 8:11 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
  21. Mar 3, 2022 at 4:59 AM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    If the ribs line up, that would be fantastic. Way easier than fabricating the whole blasted thing...
  22. Mar 3, 2022 at 5:16 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    throw a stall mat from tractor supply on it, $50.
  23. Mar 3, 2022 at 5:18 AM
    I mean, if you're going to go the trash route, don't forget to shoot some expanding foam in there to hold it up when the bed frame rusts apart, too. But I mean, if you can't see the damage, it's not really there after all.
  24. Mar 3, 2022 at 5:20 AM
    Tundradrenalin
    Virginia Beach, VA
    I meant after the weld repair
    G_unit3000, shifty` and FrenchToasty like this.
  25. Mar 3, 2022 at 5:40 AM
    nickrick78
    Pittsburgh PA
    2004 DC
    I sort of kind of laid a panel in there and it seems close enough! We will see, I will post pictures!
  26. Mar 3, 2022 at 6:29 AM
    jefffrazee
    Definitely let me know how it goes!
    nickrick78[QUOTED] likes this.
  27. Mar 13, 2022 at 4:34 PM
    Gavinsuydam
    Gavinsuydam New Member
    Gavin
    2004 3.4l v6 SR5 Access Cab
    They still did a frame replacement on your 01? I thought it was 15 years max.
  28. Mar 13, 2022 at 4:38 PM
  29. Mar 13, 2022 at 4:40 PM
    Gavinsuydam
    Gavin
    shifty`[QUOTED] likes this.
  30. Mar 13, 2022 at 4:42 PM
    NP, and a lot of us '04-'06 owners are waiting, wondering if Toyota will ever open it up for the rest of the 1st gen trucks.
