Front Sway Bar bracket bolt nutplate broke inside frame
Discussion in 'Suspension' started by afirststep, Dec 10, 2018.
  1. Dec 10, 2018 at 1:13 PM
    afirststep
    afirststep [OP] New Member
    Andrew
    Tundra 2011 4x4 cab
    None
    Front Sway Bar bracket bolt nut-plate broke inside frame leaving the bolt free spinning to nut plate - can not be removed as is. I guess the bolt rusted on the exposed end in the frame and froze to the nut-plate. With enough torque the nut-plate came loose. Toyota dealer says he has no parts for 'inside' the frame. He said it was probably spot welded to the frame. (No help even when asked for a factory contact.)
    Help a new guy out - this started with a frozen alternator that melted the serpentine belt. My perfect 2011 Tundra 4x4 just hit its first major problem at 130K...
  2. Dec 10, 2018 at 3:46 PM
    15whtrd
    15whtrd Mr. Blonde
    https://www.kent-automotive.com/Threaded-Inserts/Fasteners/FS220.kac
    Something like this?
    Rivet nut.
  3. Dec 10, 2018 at 3:52 PM
  4. Dec 10, 2018 at 3:52 PM
    Welcome from Texas, Sorry, hope the issue gets fixed
    15whtrd likes this.
  5. Dec 10, 2018 at 4:39 PM
    15whtrd
    15whtrd Mr. Blonde
    He hasn’t been around in awhile. Hopefully all is well with him. Hes handy to have around.
  6. Dec 10, 2018 at 4:41 PM
    I've noticed that as well
    15whtrd[QUOTED] likes this.
  7. May 18, 2020 at 6:00 PM
    14srAKH
    14srAKH New Member
    2014 tundra sr white
    Wheels, center console swap, tinted windows,
    Just had this happen to me. Any luck on an how to fix it?
