Upper control arm dimensions help
Discussion in 'Suspension' started by 1stGenTrd, May 18, 2020.
  1. May 18, 2020 at 9:08 AM
    1stGenTrd
    1stGenTrd [OP] New Member
    Julian
    2000 Primer Gray Tundra TRD
    Looking for new control arms to fit a 2" leveling kit on my first gen tundra trd. Research tells that Oem parts should fit right in. Nows the wonky part, the aftermarket uppers that are already on the truck hit the coil bucket and put tires at a severe negative camber. My question is, what do stock uppers measure from the frame in a straight line to the upper ball joint? Would like to confirm that Oem uppers fit and that there is not another problem as well. Many thanks in advance.
  2. May 18, 2020 at 3:10 PM
    You need to post pics so that we can see what you have going on.
