VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. May 16, 2020 at 7:32 AM
    #3511
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    Base tune isn't really base tune its your factory tune with tons of code edits. So it should be way better than factory. It also edited the transmission shifting which from the factory is pretty bad. I had The Tacoma version when it was Test Beta like this one is and it was totally worth it. And it just got better over time With final releases.
    Vr0ck and Wynnded like this.
  2. May 16, 2020 at 7:34 AM
    #3512
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    It's frustrating for all of us but things had to pivot in response to the pandemic. We simply need to remain patient.
    Vr0ck and PeakIT like this.
  3. May 16, 2020 at 7:41 AM
    #3513
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Distractions are limited for all of us.
    shellshock and Jengel451[QUOTED] like this.
  4. May 16, 2020 at 7:54 AM
    #3514
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    No... I don't think that's right. The base tune is still his own completely rewritten code. It's not just an adjusted factory tune.
    I could be wrong, but you are the first person so say that.
    It wouldn't make sense to give someone an adjusted stock tune, have them send logs for that, only to turn around and give them another tune with his own program.
  5. May 16, 2020 at 8:02 AM
    #3515
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Not to get into the minutiae too much, but it strikes me as "code edits" and "rewritten code", although maybe not "completely" rewritten, may be somewhat a splitting of hairs. Open to opinions, thoughts and perspectives on this.
    Edit: The more I ponder this as coffee begins to saturate my grey matter, the more I think that this could be an extended off-topic discussion that would be inappropriate to have here as it would just antagonize those that come to this thread for the information it was originally intended and could go on for much too long. So, I move to let sleeping dogs lie.
  6. May 16, 2020 at 8:10 AM
    #3516
    TruckyTruck
    Gary
    Split those hairs!
    Wynnded[QUOTED] likes this.
  7. May 16, 2020 at 8:15 AM
    #3517
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Edited, in part due to my not wanting to get a mess of notifications to this thread for something that's not really that related. :oops:
    I'd rather check my email for a tune. :)
    Ericsopa and TruckyTruck[QUOTED] like this.
  8. May 16, 2020 at 8:18 AM
    #3518
    TruckyTruck
    Gary
    Booo! Lol
  9. May 16, 2020 at 8:20 AM
    #3519
    TruckyTruck
    Gary
    You've got two and a half months to wait for that tune! Might as well talk about something in the meantime
  10. May 16, 2020 at 8:23 AM
    #3520
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  11. May 16, 2020 at 8:26 AM
    #3521
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I haven't seen this most recent one, I'm hoping that Mat will have the inclination to circle back through Zendesk to check my reply. Simple error, not too worried about it.
    TruckyTruck[QUOTED] likes this.
  12. May 16, 2020 at 8:36 AM
    #3522
    PeakIT
    PeakIT Old Member
    Utah
    Semantics i guess. The machine assembly code the computer is written in is super complex. He didn't rewrite the whole flash, that would be idiotic as it controls endless parts of the truck. He did complex editing and writing the parts that affect the things like shift points, torque converter lock up and on and on and added huge rewritten chunks into expanding fuel and timing etc. Other tune places that do anything for these trucks don't get get into it as far as the OV Tune. I believe all flashed tuner tunes not piggyback are made using a TSB flash for each identified ECU as a starting point just like the dealer installs and reverse engineering rewriting some functions editing others etc. I'm sure some parts are refactored some are rewritten other parts are written from scratch. I am not a computer scientist or software engineer but I'm married to one and hire them for contract work for a job. I wouldn't expect her to be able to explain or sell or anything else like that. She is good at writing code and is insulated from customer service as a Sr Team director by several other levels in the industry. They do this or they would never get anything done explaining extremely complex coding and process to laypersons would be a huge waste of their time. I cant believe Matt actually talks to you guys with all the shit he gets given.
    data logging logs are used for him to edit to more specific tables for your specific use mods, altitude, heat, fuel, weight, experience for your truck. This is the way to remotely collect data to custom tune. The best way is Dynotuning but then you'd need a competent tuner and Dyno to add to the equation and this is in the baby stages currently as they are releasing the new Tuner software that will act as a user interface front end into custom tunes.
    snivilous, Ericsopa, Vr0ck and 4 others like this.
  13. May 16, 2020 at 8:38 AM
    #3523
    TruckyTruck
    Gary
    I meant until the completion of the tundra tune.
  14. May 16, 2020 at 8:39 AM
    #3524
    TruckyTruck
    Gary
    Request denied.
    shellshock and PeakIT like this.
  15. May 16, 2020 at 8:39 AM
    #3525
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    :bowdown:
    TruckyTruck likes this.
  16. May 16, 2020 at 8:40 AM
    #3526
    TruckyTruck
    Gary
    Lol
    PeakIT likes this.
  17. May 16, 2020 at 8:41 AM
    #3527
    TruckyTruck
    Gary
    You just finished "venting" and now you want to lock the thread? :rofl:
    ChargedToyo likes this.
  18. May 16, 2020 at 8:44 AM
    #3528
    TruckyTruck
    Gary
    Please do. Hit the ignore button. Quit crying
  19. May 16, 2020 at 8:48 AM
    #3529
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    Yep. Done here. Later all.
    TruckyTruck and Wynnded like this.
  20. May 16, 2020 at 9:11 AM
    #3530
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    Thanks for the insight, I can only imagine how much time it takes to do what Mat does.
    While I know nothing about writing code I have run businesses for over 20 years so I’m honestly at a loss as to why Mat hasn’t hired anyone to field questions/emails. It would free up time for him to focus on his expertise.
    Timely communication is essential to customer satisfaction and is just part of the cost of doing business.
  21. May 16, 2020 at 10:31 AM
    #3531
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    Is this still available?
  22. May 16, 2020 at 10:55 AM
    #3532
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    Most tuning is done by alteration of table values, not completely rewriting ecu code. Things like direct shift, shift lock, etc are all custom code that mat has written.
  23. May 16, 2020 at 12:36 PM
    #3533
    art64
    art64 New Member
    Trade secrets maybe. More employees you hire to write codes, etc, the more your secrets exposed and potential for leakage. Once leaked, then, other tuners will be able to do what OV does and maybe more. It'll be bad for OV.
    DAP tune is the same. Takes a while for them to send you your tune even though they have been around for maybe 3 years now if not more tuning Tundras. I used to have DAP. There's 1 main guy doing it. He does the in-person tune also. Also tune other vehicles.
  24. May 16, 2020 at 2:06 PM
    #3534
    Hobbesdsm
    Hobbesdsm New Member
    Eddie
    2016 crewmax limited
    TRD exhaust and rear sway bar, 2018 led headlights
    @OVTune I tried out the new tow/haul mode tune on the freeway.As I went to pass a slower vehicle (~60mph or so) give it some throttle I noticed the truck didn’t down shift,... even at WOT, nothing happened. It’s like the gearlock in 6th on “S mode” but I was on D mode. Is this normal? I remembered on the stock and base tune it would automatically downshift.
  25. May 16, 2020 at 2:45 PM
    #3535
    NWATundra
    NWATundra New Member
    2013 White Tundra DC
    This is the reply I got from him for the same question.
    When you use the TOW button it sets it to gearlock mode which disables downshifting, so you should also put the truck in S so you can control the gears.
    Hobbesdsm[QUOTED] likes this.
  26. May 16, 2020 at 2:50 PM
    #3536
    Kelvin
    Kelvin New Member
    So if I’m reading the latest updates right. It looks like 19-20 tunes aren’t too far out? I’m currently driving a TRD blown Lexus and I don’t think I can live without a supercharger so my Tundra will be getting the Harrop blower. Just waiting for this pandemic stuff to go away so I can go get my Tundra.
    Kung likes this.
  27. May 16, 2020 at 3:40 PM
    #3537
    Kung
    KG, VA
    This. I mean, yeah, to be honest, I totally understand and even agree with the frustration/exasperation of those who've been waiting a while, but by the same token, as a fellow IT guy, I'm amazed Mat posts here instead of having someone else front while he does the back-end stuff. (Though I'm sure there are reasons.)
    The only thing I can compare this to (and this is a bad comparison, but as a non-programmer IT guy, it's all I got) was the time I had to rebuild the boot sector of a hard drive that belonged to a tactical IT system when I was on the USS Enterprise. We *COULD NOT* lose the data, and so I did some research to see if it could be done. At the time there wasn't that much online, but I did find some sources saying it'd been done in the past.
    Somehow, myself and another guy were able to successfully rewrite the boot sector of the bad drive to get the drive up long enough to recover the data. It took both of us working in shifts about 5 days straight.
    With this said, to the OP - I HIGHLY suggest a Synology/QNAP NAS if you don't have one. They've been a godsend for me.
  28. May 16, 2020 at 4:49 PM
    #3538
    Ericsopa
    Ericsopa Old man and the sea
    That's the way my tune works. I don't drive much in "D" anymore, I taken to using s-mode almost all the time. But the tow-haul gear-lock works in either mode. I make sure ahead of time, if I think I'll need a quick acceleration to pass, say on a regular two-lane highway, I either turn off the tow-haul, or be ready to manually shift it down, usually to 4th gear if I'm at 60 or below.
  29. May 16, 2020 at 6:41 PM
    #3539
    Hobbesdsm
    Eddie
    Much appreciated guys for your replies. Good to know it’s how the tune work.
    Tundralicious likes this.
  30. May 17, 2020 at 5:49 AM
    #3540
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    The problem with hiring someone to do this type of work is that right after I train them, show them how to write this code that nobody knows how to write, they can walk away with it and compete against me.
    I actually had this happen in the Mazda tuning world back in the day. Helped someone learn some things, turned it into a business and not only competed against me, trashed talked me, and verbatim copied text off my website.
Thread Status:
