2014-2020 steering wheel in a 2010
Discussion in '2nd Gen Tundras (2007-2013)' started by copmagnet82, May 14, 2020.
  1. May 14, 2020 at 7:45 PM
    copmagnet82
    copmagnet82 [OP] Member
    Paul
    Chicago
    2010 SR5 & 2021 TRD Pro
    I've been searching for months... I don't know... maybe I'm not doing it right :notsure:, but has anyone installed a 2014-2020 steering wheel in a 2007-2013 Tundra. I really hate the steering wheel that I have in my 2010 and I'm wondering if it's a swappable item.
  2. May 14, 2020 at 8:34 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Anything is possible, you just have to be cautious about the airbag clock spring. Should be a straight swap, you may have to verify the airbag though.
    copmagnet82[OP] likes this.
  3. May 14, 2020 at 8:44 PM
    blackdemon_tt
  4. May 15, 2020 at 4:52 AM
    Bloomjtundra
    Bloomjtundra New Member
    Josh
    2011 Tundra DC 4x4
    I felt the same about my 2011 wheel. What don’t you like about it?
    Here are the ideas I found:
    Most expensive route - a new Toyota OEM wheel that’s leather wrapped or wood/leather combo.
    eBay a used wheel you like from the 2nd gen.
    ebay a new aftermarket wheel for the 2nd gen. There are a handful out there from one brand and they appear to offer different colors/ combinations of wood and leather.
    3rd gen/Tacoma wheel. This option I’m not sure of because of the different shape of the airbag. No idea if that matters. Also, not sure of any compatibility issues with the control buttons (if you don’t have steering wheel audio now I guess it doesn’t matter).
    what I’m doing: I sent my wheel to a place in Texas to get it leather wrapped. It’s not super cheap but I couldn’t find the matching color I needed for my truck’s airbag on eBay. I have the tan cloth seats with brown dash and airbag, etc.
    I will have a black leather and brown wood OEM wheel from limited or platinum trim I’ll be selling once I get my leather one back from the wrap place in Texas. It is used with some wear but looks pretty good. I’m using it in the interim.
    good luck with your wheel search.
  5. May 15, 2020 at 9:53 AM
    copmagnet82
    Paul
    Chicago
    Yeah, I figured, but I haven't seen anyone do it and was wondering if there is something that prevents the swap.
  6. May 15, 2020 at 9:55 AM
    copmagnet82
    Paul
    Chicago
    I don't like the overall shape, and I don't mean that it's round ;).
  7. May 15, 2020 at 10:01 AM
    ckkone
    ckkone New Member
    SLC, UT
    Might be possible. The Landcruiser 200 wheel is the same as the 2nd gen tundra just the airbag cover and controls look different, the outer wheel is the same so it might be more of a direct swap? I bought a leather wrapped cover from Amazon, haven't installed yet but from all the pictures I've seen they look great.
    https://www.amazon.com/dp/B00RXIQTBQ/ref=twister_B0794YNG9B?_encoding=UTF8&psc=1
  8. May 15, 2020 at 11:34 AM
    iNKBOi
    iNKBOi Colorado Boi
    Ben
    Vail, CO
    2008 Radiant Red Double Cab SR5 TRD Off-road and now 2020 TRD Pro Army Green Crew
    Does anyone have this steering wheel in a 2007-2013 Tundra?
  9. May 15, 2020 at 11:40 AM
    iNKBOi
    iNKBOi Colorado Boi
    Ben
    Vail, CO
  10. May 15, 2020 at 12:12 PM
    copmagnet82
    Paul
    Chicago
    Y0TA PR0 likes this.
  11. May 15, 2020 at 12:16 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
  12. May 15, 2020 at 5:03 PM
    Bloomjtundra
    Josh
    2011 Tundra DC 4x4
    I think the DIY wraps look awesome. I just didn’t have the patience to do it so I sent mine out. The good custom shops for wheels can make all sorts of mods too. Thumb grips, etc.
  13. May 15, 2020 at 8:11 PM
    iNKBOi
    iNKBOi Colorado Boi
    Ben
    Vail, CO
    That steering wheel is nice, but looks like it’s for a 2014-20 even though it says 2009-20
  14. May 15, 2020 at 8:38 PM
    copmagnet82
    Paul
    Chicago
    It's a 2014-2020 shape, so you would need a new airbag and other parts. You're looking at about $1600.00 for that set-up.
  15. Sep 1, 2021 at 12:11 PM
    DPK_David
    DPK_David New Member
    I dont understand how there is not more people looking into this. I personally have a 2013 sequoia and I am thinking the best bet would be to go with a 2014 sequoia wheel, or I should say controls and harness. Either way once I have the wheel in and working I would want to get the wheel itself rewrapped. I just more so want to make sure the spline is the same and the connectors are the same, even if a few pins need to be moved.
  16. Sep 1, 2021 at 7:35 PM
    68vert
    68vert New Member
    AZ
    2011 Rock Warrior
    I've been thinking about the same...
  17. Sep 2, 2021 at 6:05 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    Swapping a steering wheel isn't a small investment. You're looking at approx $300 - $500 for a newer model steering wheel and airbag with no guarantee it would work without a good amount of research. I don't know many that would take the time or risk. That being said forum member Jeff_5_7 did a full interior swap which led to me wanting to do a partial swap (instrument cluster and steering wheel only). Check it out:
    https://www.tundras.com/threads/ful...cluster-console-seats-ect.90411/#post-2291106
    Jeff_5_7 likes this.
  18. Sep 2, 2021 at 7:52 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    I bought a used 2018+ Wheel for $120
    Then a good steering wheel airbag for $270.
    Total Cost = $390
    The swap can be done in less than an hour, however most people dont like the idea of having buttons on the steering wheel that do not work. I spent alot of time adding wiring so my steering wheel controls would work.
    Keep in mind the 2014-2017 Wheel and the 2018+ Wheel are slightly different when it comes to buttons on the steering wheel. The 2018+ has more controls for the cluster display and safety systems.
    Here is a 2018 Wheel in my 2007 Truck. It is bolted to the 2007 steering column
    Trusty Rusty, azimuth and Danny3737 like this.
  19. Jan 7, 2022 at 4:52 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Do you care to share how you did the wiring?
  20. Jan 7, 2022 at 8:01 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    BrandonL812[QUOTED] likes this.
