  1. May 14, 2020 at 12:34 PM
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    Haven't had a lot of time today but a few things were accomplished.
    • Got driverside header temp installed (2) bolts holding it on awaiting new lock nuts
    • Attached driver-side cat (hand tight)
    • o2 hand tight
    • Removed Passenger-side cat entirely for new o2 bung (should get here tomorrow)
    • Removed 3 out of 4 passenger-side heat shield bolts. (had to take a shower to hit my hair cut appoint which was 2.5 months overdue!
    About to go back out and start removing the pass. header and maybe the rest of the exhaust since I have the BAMuffler waiting to install.
    Will update more later.
    bmf4069, chrisb, TX-TRD1stGEN and 5 others like this.
  2. May 14, 2020 at 1:02 PM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    @imDementeD so u have a supercharged 4.7 and its NOT your profile pic? Wtf
    Darkness likes this.
  3. May 14, 2020 at 1:17 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    @imDementeD I remember when mine were that pretty. Give them about a year or two and they'll blend in.
    bmf4069, chrisb, NUDRAT and 5 others like this.
  4. May 14, 2020 at 1:32 PM
    imDementeD
    You make a good point...I'll update it :)
    It's a bit dirty but...that's how we like em ;)
    bmf4069 and Tundra2 like this.
  5. May 14, 2020 at 2:12 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I installed my JBA shorties in 2003, the picture was taken about a year ago.
    A valve cover gasket was leaking a little oil at the time.
    bmf4069, Tundra2 and Darkness like this.
  6. May 14, 2020 at 3:40 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Are those the ceramic coated? The titanium coating is about $150 extra. Suppose to keep the heat down a bit. Sounds like it’d be worth it since lack of the heat shields not fitting from OEM designed oldies.
  7. May 14, 2020 at 3:44 PM
    Rex Kramer
    Georgia
    Ceramic... Titanium wasn't available in '03.
  8. May 14, 2020 at 3:48 PM
    I thought the ceramic would have stayed shiney longer. Do you live where they put lots of stuff on the road during the winter? It bearly rains here, let alone snow in the winter. They only spray a small amount of something on the bridges to keep from freezing overnight
  9. May 14, 2020 at 3:56 PM
    Fred
    Hand Protectors
    They look good for their age. Better looking than @Darkness Cali weathered ones. Must be that Malibu air salt aire. :poking:
    bmf4069, chrisb, Darkness and 3 others like this.
  10. May 14, 2020 at 4:39 PM
    imDementeD
    Update! I didn't get to start when I wanted as the wife wanted to mow and water her plants but I eventually got out right before 5:30pm.
    So for me, the passenger side ended up being harder. I think this is for a few reasons.
    • The passenger side had definitely been messed with (different heat shield bolts that were tiny and couldn't see since the shield and bolts were so rusted).
    • The nuts on the headers weren't the locking style which came off a lot easier. Studs were definitely newer and all but 1 stayed in place (the nut easily backed off though)
    • I turned the wheels when I was on the driver side and should have straightened it out to start the passenger side.
    • I left the (2) hardest bolts for last. The bottom/back one was fairly easy once I went from underneath the truck. The last bolt though was a nightmare. (this goes back to the tires not being straight and I couldn't access these without having to turn the wheels)
    • I removed the cat before starting - This helped access some but allowed the header to start dropping off making that last bolt the nightmare on top of it already being a pain!!!
    Mostly mistakes on my part when I should have copied exactly how I did the driver side.
    Overall, it took (2) hrs to remove the header and temp install the new one. The timing was close to the driver side once I included the temp install on that side but I def feel it was tougher on me and surely being up since 2 am doesn't help. I'm exhausted and ended up with a lot more cuts/scrapes.
    I feel this is will be about 5 hrs once I tighten everything up and re-install the cat (this wasn't necessary on the driver side as I need to weld the bung for the o2 otherwise this would have been left in place). Not bad for laying in the dirt using hand tools and keeping the wheels on. I definitely think without the wheels on a lift could easily be 4hrs or less.
    1 pic of it installed. Again just (2) bolts to hold it in place.
  11. May 14, 2020 at 4:43 PM
    04 Tundra
    04 Tundra New Member
    Albert
    2004 Toyota Tundra 4x4 AC Limited
    DIFF Breather, Painted Rims, Interior Wrap, Tint,
    We finally got them on after all this time IMDEMENTED !
    bmf4069, theblurry1, MS22 and 4 others like this.
  12. May 14, 2020 at 4:52 PM
    Rex Kramer
    Georgia
    Very little salt is used here in my area, plenty of rain though.
    Over 16 years & 150,000 miles of use.
  13. May 14, 2020 at 5:12 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I'll be honest, considering mine have been on since 2009 I felt ashamed seeing how much cleaner his looked. Now that I know his are coated and mine are raw I don't feel bad.
  14. May 14, 2020 at 5:26 PM
    Dang, headers with a supercharger. That truck's gonna have balls. Now all you need are some dirty deeds injectors. :burnrubber:
    bmf4069, lsaami and FrenchToasty like this.
  15. May 14, 2020 at 6:24 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    2 things to add.
    One: Was out driving today, and heard a metal on metal clunk. I naturally thought WTF? My truck normally makes very little noise, therefore I pay extra attention to "abnormal" noises. Drove for a little bit, and heard it again. Then I remembered I had two empty "Yeti-like" tumblers in the back seat. Separated them from each other. No more noise. All good there.
    Two: Today while I was out in town nature called... so I pulled into the local Marathon gas station. They had an attendant outside turning people away if they didn't have a mask. Went back to the truck. Dug around, and thought "Fuck me, I don't have a mask."
    I dug around in my day bag, and found a tank top. Wrapped that around my face kinda half-ass, and went inside.
    Sat down, did my business, and then reached into the TP dispenser. No TP. I thought to myself, "Well fuck me. Just a series of unfortunate events this last hour. Jeez."
    Pulled my pants up, and kinda cracked the stall door looking for paper towels. No dice. Hand dryer instead of paper towels in the loo. I thought "Well shit..."
    I carefully walked around the gas station, and found a 10 pack of baby wipes for $6. I also found one roll of paper towels for $1.39. No TP. I thought "Well I can make the paper towels work."
    Carefully walked to the counter, and set the paper towels down. I said to the cashier "You guys are out of TP in the men's bathroom."
    He looked down at the paper towels, and then back up at me wearing my new hat (pic attached), looked down at the paper towels, and then back up at me. He kinda huffed like I had given him a monumental task such as chewing Mount Rushmore down to nothing using only his teeth.
    Hopefully you fellas get a laugh at my expense. I know I thought it was funny even though I was in a bad mood.
    Cheers.:rofl:
    lamboboy732, bmf4069, chrisb and 5 others like this.
  16. May 14, 2020 at 6:26 PM
    ezdog
    ezdog New Member
    Gateway To The West
    2001 RCLB V8,4WD 2015 RCLB 5.7,4WD
    I know I did and your guilty look in the reenactment said it all for me!
  17. May 14, 2020 at 6:27 PM
    I think I would have walked out without a “face mask”!
    lamboboy732, bmf4069, chrisb and 4 others like this.
  18. May 14, 2020 at 6:28 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    That was a Pre-gas station picture I sent to mom and pop while explaining the story.
    There has been a few locals that were "arrested" by the local PD for public endangerment due to no masks. All stories have been swept under the rug, but I wasn't trying to go to jail today.
  19. May 14, 2020 at 6:36 PM
    i meant I would have used that “mask” in the stall, and ran out of there!
  20. May 14, 2020 at 6:37 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    It took me 3 radiators being sent to the house, damaged, and sent back before I finally ordered one through O'Reilly's, or Autozone.
    I elected for "in store pickup" because the shipping people for both companies are a little gentler on items going to stores.
    The first one was immaculate except the overflow nipple was broken off.
    Sent back for a full refund.
    The second one was also immaculate except a forklift had pierced the coils with its forks. Sent back for a full refund.
    The third one had a broken top "housing" (the plastic pieces on top, and bottom.)
    Finally had one sent to one or the other. I paid a little extra to get one through them, but I finally had one "un-fuckered." I asked the guy before I paid if I could inspect it. He asked "why?" I explained the situation. He said "Oh no shit! Go for it man. You sound... frustrated."
    Best of luck.
  21. May 14, 2020 at 6:41 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Its hard to run with fucked up feet, friend.
    I understand what you're saying, but I elected to "Play it safe."
  22. May 14, 2020 at 6:44 PM
    I didn’t know your were an Ambi-turner
    Tundra2[QUOTED] likes this.
  23. May 14, 2020 at 6:47 PM
    Is that a Denso unit? I ordered a Denso radiator and they package it so poorly it arrived the same way. I honestly couldn't even blame the delivery driver. They didn't have anything in the box to protect the radiator.
  24. May 14, 2020 at 6:52 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    That is how all 3 of mine were upon arrival.
    Just a box, with styro-foam on the top/bottom, but nothing in the middle protecting the coils.
    NG²​
    I HIGHLY recommend having one shipped to an auto parts store.
  25. May 14, 2020 at 7:02 PM
    Yeah, shame on Denso honestly. I sent mine back and bought one locally from O Reillys. It has a lifetime warranty at least.
  26. May 14, 2020 at 7:36 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Hahaha. Awesome. Sorry that must have sucked for you though. That’s why I always make a habit out of checking for TP before going Poopie
  27. May 14, 2020 at 7:42 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    honestly damage like that is common on any radiator. unless you buy OEM. but ive even had that issue with OEM
    speedtre likes this.
  28. May 14, 2020 at 8:00 PM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    Late reply, but I'm gonna have to blame the air injection BS that was on my 05 for why this was very much not the case for me.
  29. May 14, 2020 at 8:05 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I would have wiped my ass with the tank top and flipped my shirt over my head like so
    Technically still wearing a t shirt so they couldn't even kick you out for the old "no shoes no shirt no service"
  30. May 14, 2020 at 8:11 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Glad all worked out. Ordered OEM denso to the store. Not a scratch on it, and I actually damaged it more installing it than they did shipping it. LOL
    I usually check also, but in this instance it was drop trow immediately or suffer the consequences.
    :crapstorm:
    I thought about it for a split second, but decided no one else wanted to see my belly hair.
    bmf4069, chrisb and CodyP[QUOTED] like this.
