NEED NEW HEADERS any cheaper options then jba or dirty deeds? Still looking for high quality.
Discussion in '1st Gen Tundras (2000-2006)' started by 04 Tundra, Apr 18, 2020.
  1. May 5, 2020 at 9:17 AM
    #61
  2. May 5, 2020 at 2:45 PM
    #62
    04 Tundra
    04 Tundra [OP] New Member
    Albert
    2004 Toyota Tundra 4x4 AC Limited
    DIFF Breather, Painted Rims, Interior Wrap, Tint,
    Getting new studs and lock nuts from Toyota tomorrow then i will start the install. Yeah i wonder what my Gibsons would give preference wise ?
  3. May 5, 2020 at 2:49 PM
    #63
    It’s weird it’s only on the upper outer two on the Primary.
  4. May 5, 2020 at 3:02 PM
    #64
    04 Tundra
    Albert
    Yeah that's how they come originally from Gibson though i made sure
  5. May 7, 2020 at 4:48 PM
    #65
    04 Tundra
    Albert
    Done easy install glad i did it. I could not spin my tires on a dry road before i can now lol
    revtune, CLS2011 and Darkness like this.
  6. May 7, 2020 at 4:49 PM
    #66
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Nice. How many beers? :burp:
    revtune and FrenchToasty like this.
  7. May 7, 2020 at 4:50 PM
    #67
    04 Tundra
    Albert
    Install 0 came home from work and finished in the dark was to excited to even take a break lol
    Darkness, revtune and FrenchToasty like this.
  8. May 7, 2020 at 5:03 PM
    #68
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    Great job! Glad you went with oem studs and locking nuts. Did you end up using the gaskets that came with the headers?
    04 Tundra[QUOTED][OP] likes this.
  9. May 7, 2020 at 5:05 PM
    #69
    04 Tundra
    Albert
    Yeah i used the new ones they were very nice
    revtune[QUOTED] likes this.
  10. May 7, 2020 at 5:15 PM
    #70
    When you removed them, did you go for the nuts or the studs, or which let loose first? Also any PNs for the studs and nuts?
  11. May 7, 2020 at 5:25 PM
    #71
    04 Tundra
    Albert
  12. May 7, 2020 at 5:29 PM
    #72
    04 Tundra
    Albert
    I got OEM studs and lock nuts
  13. May 8, 2020 at 1:14 PM
    #73
    Professional Hand Model
    Fred
    Hand Protectors
    My steering column seal had a tear in it. I was able to reach up from laying on my back and squeeze some acrylic caulk around the seal partial torn lips. This is an option for those not wanting to disconnect column and replace the seal. Cheap fix at .10c with the caulk.
  14. May 8, 2020 at 1:21 PM
    #74
    Fred
    Hand Protectors
    Just read through this thread which popped up during my ban time. Great info. Summarizing:
    1) JBA shorties are good!
    2) Use JBA included gasket.
    3) Buy Toy OEM Studs and Bolts.
    revtune likes this.
  15. May 8, 2020 at 1:29 PM
    #75
    Fred
    Hand Protectors
    Gibson Shorties look good. I’ll check their site.
  16. May 8, 2020 at 2:04 PM
    #76
    There was mixed responses on this one. Keith from DD told me to use JBA gaskets with his long tubes. Most everyone else says to use Toyota OEM gaskets. Apparently Percy gaskets are also good.
  17. May 8, 2020 at 5:23 PM
    #77
    revtune
    revtune New Member
    Dane
    Houston Texas
    For JBA shortys, the supplied collector gaskets are good to go. For the header gasket, I went with percy’s seal 4 good 66080 on the recommendation of fellow users. The oem stud/lock nut combo works really well. No need for constant retorque.
  18. May 8, 2020 at 5:32 PM
    #78
    Fred
    Hand Protectors
    Ye. I’m reviewing and saw some complaints on the JBA ‘cardboard gasket’ sucking. I’ll go down this Percys route on some research tomorrow. Thanks for this.
    Guessing I should order some OEM bolts for both the flanges connections going to the middle pipes? Mine look rusty and crusty. Might need to grind down and punch those old ones out.
  19. May 13, 2020 at 5:06 PM
    #79
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
  20. May 13, 2020 at 5:12 PM
    #80
    Fred
    Hand Protectors
    I’m liking the Made in USA Doug Thorley Ceramic Coated. Currently sold out due to ‘Stemillus’ and everyone sitting around the house collecting checks with nothing to do but fix their fences and work on trucks.
    imDementeD likes this.
  21. May 13, 2020 at 5:32 PM
    #81
    So dive deep and look into them, I remember a big thread on them with the v8runners(4.7l as wel) I didn’t read all of the thread as some of its new and I haven’t been active there for a while
  22. May 13, 2020 at 6:09 PM
    #82
    Fred
    Hand Protectors
    Read the first two pages and then skipped to the pre-prompted feelgood pivotal post #160. Continued on to the last two pages and feel let down on shit scam products. WTF is going on with everyone and crap labor skills and products?
    Makes me want to go tighten my 18 year old manifold nuts and call it a day!
    revtune and FrenchToasty[QUOTED] like this.
  23. May 13, 2020 at 6:42 PM
    #83
    04 Tundra
    Albert
    I love the gibsons I got try and find a deal
