Are Focals Plug and Play speakers compatible with the 3rd Gen JBL system?
Discussion in '2.5 Gen Tundras (2014-2021)' started by kentran5397, May 13, 2020.
  1. May 13, 2020 at 1:38 PM
    kentran5397
    kentran5397 [OP] New Member
    Dallas. TX
    2014 Tundra 1794 Edition
    2019 Trd Pro LED Headlight 2019 1794 Grill LED Interior and Reverse Light LED Bedlight Vled Footwell LED Driver Side Grab Handle Bullet Fender Flares MX4 BakFlip Start X Remote Start Dual USB ports for the front and rear KO2 A/T Tires 275 60 R20 *Future Mods* TRD Rear Sway Bar Leveling Kit 38 gallon fuel tank swap
  2. May 13, 2020 at 1:53 PM
    kentran5397
    Dallas. TX
  3. May 13, 2020 at 3:50 PM
    TXTundra2722
    2015 Black Tundra
    @james@tech12volts can definitely hook you up with whatever you need audio wise in your tundra. Many members including myself run his products and highly recommend him. Customer service is second to none.
    panicman and kentran5397[OP] like this.
  4. May 13, 2020 at 4:42 PM
    jre5490
    jre5490 Rane
    Rane
    MS Gulf Coast
    2019 Tundra SR5 TSS
    Everything I’ve read about these sets that Focal makes is that they are plug and play. There is a plug on the side of the speaker that you should be able to use the factory wiring. If a set wasn’t so dang expensive I would have already ordered these.
    kentran5397[OP] likes this.
  5. May 13, 2020 at 5:07 PM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    I believe the stock JBLs speakers have a 2 ohm impedance. Those Focal are 4 Ohm. Would make your weak factory amp appear even weaker. That’s based on my elementary car audio education.
  6. May 13, 2020 at 5:46 PM
    jre5490
    jre5490 Rane
    Rane
    MS Gulf Coast
    2019 Tundra SR5 TSS
    Yeah the stock amp needs to go. I haven’t touched my audio yet in my truck but the first upgrade I tackle will be the stock amp under the seat. That thing sucks.
    TXTundra2722 likes this.
