  1. May 13, 2020 at 7:47 AM
    RockyMtnTundra
    RockyMtnTundra New Member
    2020 SX Crew Max 4X4
    Stock size, just put Falken Wildpeaks on (275/65R18)
  2. May 13, 2020 at 8:01 AM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    AJT interior is complete, got the V2 shift knob on, was the last piece I needed
  3. May 13, 2020 at 8:24 AM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    Looks proper now..:thumbsup:
    Ryuu[QUOTED] likes this.
  4. May 13, 2020 at 9:22 AM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Hey, Krackerjack!
    The running light LEDS are 6mm flush mount light bolts. The ones on the ends are simple enough as they screw right into a factory nut. The two middle ones required a small 6mm hole to be drilled and a stronger fastener than the provided black nut. I used a stainless steel washer and lock nut.
    These LEDS were then wired back up to the cab for switching on/off along with the running lights in the grille.
    https://www.oznium.com/led-bolts-prewired-leds/led-bolt
    https://headlightrevolution.com/2014-2020-toyota-tundra-led-reverse-bulbs-upgrade-1000-lumen/
    The only other LEDS on the tail end are the insanely bright reverse lights that I picked up from Headlight Revolution. I definitely recommend them for greater visibility. The rear camera is also less grainy too.
    GAknight, WAtundra4x4, Fotnot and 4 others like this.
  5. May 13, 2020 at 9:43 AM
    BoxersBrew
    BoxersBrew New Member
    Thomas
    Northern Virginia
    2020 Black Tundra Limited Crewmax TRD
    Dealer installed TRD dual exhaust system and tonneau cover. Personally installed TRD Pro grille and surround, side mirror caps, and TRD shifter.
    Thank you sir! I got mine ordered, as well as the shift gate piece. If you can drill into your 2020, I can too. ;)
    2020Platinum[QUOTED] likes this.
  6. May 13, 2020 at 9:43 AM
    owb2gp
    owb2gp New Member
    ID
    It's been close to 2 years with the new grill and having the sensor relocated and I've had zero issues.
    Lowgybear[QUOTED] likes this.
  7. May 13, 2020 at 9:46 AM
    2020Platinum
    Patrick
    Northeast PA
    No prob!...it’s really not that bad, let me know if I can help ya!
  8. May 13, 2020 at 10:21 AM
    manhster
    manhster New Member
    Richmond, VA
    '17 Black CM 4x4 Ltd TRD OR
    Already digging the vinyl wheel kit from @rrentrop. Definitely remove the wheel and take your time.
  9. May 13, 2020 at 10:59 AM
    SiberianTundra
    SiberianTundra I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    looks really good
    what brand steering wheel is it (eBay ?) how much and any link ?
  10. May 13, 2020 at 11:05 AM
    SiberianTundra
    Greg
    War Machine
  11. May 13, 2020 at 11:21 AM
    Krackerjack
    Krackerjack New Member
    2020 Tundra TRD Sport Metallic Grey
    Awesome! I’m gonna definitely give that a try. Really like the running light look. What kind of lights did u use for the front running lights?
  12. May 13, 2020 at 11:37 AM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
  13. May 13, 2020 at 1:08 PM
    2020Platinum
    Patrick
    Northeast PA
    Got the install done on the Anytime Backup Camera, including front facing cam as well...nice little feature to allow you to view rear/front camera at any time, not just in reverse!
    https://youtu.be/7Axamo4_nlE
  14. May 13, 2020 at 1:37 PM
    Cthulhu
    @rrentrop any chance you're exploring doing blackout vinyl for Limited rims?
  15. May 13, 2020 at 1:55 PM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    Did some “truck” stuff today by making my truck “work”. Then trying to OG BTTF. Didn’t work.
  16. May 13, 2020 at 2:35 PM
    BoxersBrew
    Thomas
    Northern Virginia
    Added TRD center caps.
    Ostrich, co2owen, ElNopal and 5 others like this.
  17. May 13, 2020 at 2:48 PM
    BoxersBrew
    Thomas
    Northern Virginia
    Ok, at 300 miles on my truck, am new to this. How do you have DCC set to 76 MPH but yet are doing 88?
    Love the color btw. Was trying to deal on a Voodoo Blue Platinum but it didn’t work out.
  18. May 13, 2020 at 3:26 PM
    Jerry70
    Jerry70 New Member
    Lakes region NH
    2019 Limited CM OR CAValry blue
    TRD exhaust, TRD rear sway bar
    did they tape off your shocks and sway bar?
  19. May 13, 2020 at 3:40 PM
    Chonfelito
    Chonfelito New Member
    Utah
    2016 Tundra Crewmax Sunset Bronze Mica
    ElNopal[QUOTED] likes this.
  20. May 13, 2020 at 5:19 PM
    TundraLuv
    TundraLuv New Member
    Kent
    IA
    2018 Midnight Black Metallic Limited Crewmax
    Where did you snag those at? link?
  21. May 13, 2020 at 5:28 PM
    SnrDisregardo
    Wade
    IL
    Just step on the gas. Cruise will limit you but you can still press the pedal if you need more power or to pass, etc.
    NewImprovedRon likes this.
  22. May 13, 2020 at 5:31 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    TundraLuv[QUOTED] likes this.
  23. May 13, 2020 at 5:49 PM
    Marty33
    Marty33 New Member
    2018 Tundra TRD 4\4
    Put on my Rough Country front seat covers, easy and very comfy. Ordered front turn signal replacements, brighter. Install Friday on my Falken Wildpeaks and Black Rhino Selkirk rims. Turn signals are JDM ASTARS from Amazon.
  24. May 13, 2020 at 6:23 PM
    BoxersBrew
    Thomas
    Northern Virginia
  25. May 13, 2020 at 6:27 PM
    BoxersBrew
    Thomas
    Northern Virginia
    Ah, yeah, duh. :rolleyes:
  26. May 13, 2020 at 6:33 PM
    RyRy12
    RyRy12 New Member
    ‘17 Silver SR5
    Debadged oh yeah!!
  27. May 13, 2020 at 6:34 PM
    BoxersBrew
    Thomas
    Northern Virginia
  28. May 13, 2020 at 6:35 PM
    BoxersBrew
    Thomas
    Northern Virginia
  29. May 13, 2020 at 6:37 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    Traced out and “fabricated” an amp mount using the factory amp brackets as a template just to clean up the amp install a little.
  30. May 13, 2020 at 6:46 PM
    BoxersBrew
    Thomas
    Northern Virginia
    Ok, not to knock the chrome around the Toyota/Tundra or TRD grille, because I actually like it.. Anyways, I tried this originally With a newer TRD Pro grille and posted a photo on Reddit and got crucified.. All this to say I appreciate this group/forum for being more open to individual preferences. Thank you!
