Meguirs Scratch X 2.0
Discussion in 'Detailing' started by Grumpy Uncle, May 10, 2020.
  1. May 10, 2020 at 6:19 PM
    Grumpy Uncle
    Grumpy Uncle [OP] Pushing string down the hall SSEM #10
    Pat
    CO
    I had some sap, bird shit and water stains that I could not remove with most of the stuff I had on hand. I had some of this stuff and it worked. I'll be keeping this on hand from now on.
    Pudge likes this.
  2. May 10, 2020 at 6:49 PM
    EglSctAndy
    EglSctAndy MGM Crüe
    Andrew
    Arizona
    2019 MGM Crewmax TRD Sport
    Icon Stage 5 17” Icon Rebound Wheels TOYO Open Country A/T 35 12.5 RCI Heavy Duty Side Step Weathertech Mats 4” Stubby Antenna Fyre Flys Interior LED Lights Plastic Dipped Badges Decked tool box Baja Designs Squadron Sport fog lights
    I really like their quick detail spray. “Washed” the entire truck the other day in about 20 minutes. I will have to pick up some of thus the next time I’m out.
  3. May 10, 2020 at 7:04 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Yes, this work great. I actually bought two.
  4. May 10, 2020 at 9:37 PM
    linwozzle
    linwozzle New Member
    Linden
    2014 SW Tundra Platinum 4x4 CM
    They have a waterless wash also, that would work better than the detail spray, especially if the truck is dirty and will cause less scratches
  5. May 11, 2020 at 4:14 AM
    War Machine
    War Machine SSEM # 5 3MW
    It’s an excellent product for removing light scratches / defects. Hadn’t used it for what you did, so I’ll have to try it.
  6. May 11, 2020 at 5:53 AM
    Grumpy Uncle
    Pat
    CO
    I dont remember if I bought it or one of the boys. I tried vinegar and distilled water, groits cleaning wax, and a couple of other things. I found that stuff hiding on the shelf and figured what the hell. It made easy work of getting those stains out.
  7. May 11, 2020 at 6:00 AM
    EglSctAndy
    EglSctAndy MGM Crüe
    Andrew
    Arizona
    I will have to look for that as it sounds like a better option than what I am currently using. Thanks for the recommendation.
