Who knows what this is?
Discussion in 'New Member Introductions' started by Robino, May 10, 2020.
  1. May 10, 2020 at 2:45 PM
    Robino
    Robino [OP] New Member
    Rob
    2016 Tundra SR5 TRD off-road 4x4
    upgraded shocks, struts, sway bars
    I was a bit surprised to discover there are no tie-downs in the rear of the bed which are welded to the frame. There are two in the front of the bed, just behind the cab...but, these will be useless to me once my cap is installed. I frequently need to secure a generator that sits on the tailgate. I'm reasonably creative and resourceful, so I know I'll come up with something. Even the tailgate latch hooks look strong enough to use as tie-down points.
    But, can anyone tell me what these are? They're located just inside the tailgate and are securely bolted to the truck frame. They appear to be receivers for some kind of brace or who knows what...20200510_161823_resized.jpg
  2. May 10, 2020 at 2:47 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Looks to be bed extender mounts...
  3. May 10, 2020 at 3:16 PM
    rebmo
    rebmo 2020 Crewmax Limited 4wd Silver/Black
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    What he said for sure, Bed extender brackets. Here's a pic of my AMP bed extender brackets. Looks pretty similar. Amp no drill bkt 2.jpg Amp Bed Ext.jpg
    Ely010606 and landphil like this.
  4. May 10, 2020 at 3:25 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    WELCOME
  5. May 10, 2020 at 4:15 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    What they said. And clearly someone left the rear tie-down loops off when they installed the bed extender mounts.
  6. May 10, 2020 at 4:16 PM
    People are always looking for those.
  7. May 10, 2020 at 4:19 PM
    Midnite72
    Midnite72 Anything DIRT !!
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    Junkyard find
  8. May 10, 2020 at 4:23 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Hi do you know the part number for that bracket and where i can order. Thanks
  9. May 10, 2020 at 4:34 PM
    Ely010606
    SPARKS, NV
    When you decide to get rid of them, ill buy them off you, thanks
  10. May 10, 2020 at 6:34 PM
    Welcome from Ohio
  11. May 10, 2020 at 7:05 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard from SoCal.
