TRD Pro exhaust for 2020 Double Cab w/ 8ft bed?
Discussion in '2.5 Gen Tundras (2014-2021)' started by clank4001, May 10, 2020.
  1. May 10, 2020 at 1:57 PM
    clank4001
    clank4001 [OP] New Member
    2020 Black Double Cab 4x4 Long bed
    Hello all and glad to be a member of the Forum!
    I recently purchased a new 2020 4x4 Double cab with the 8 ft bed.
    Most of the on line sources/videos show std bed Double Cab trucks, or Crew cab 4dr trucks with these TRD exhausts, but I have not seen any with the 8ft bed.
    I have not called the local dealership and haven't had much luck finding the kits on line specifically for the 8ft bed Double cab configuration.
    Does anyone have one of these trucks with the TRD exhaust?
    Thanks
  2. May 10, 2020 at 2:15 PM
    biebs96
    PA
    I might be wrong. But I was under the impression that the muffler section that unbolts is just farther back under the truck and has longer pipes from the motor back.
    maybe someone else will have a better answer.
  3. May 10, 2020 at 2:21 PM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    I’m guessing dirty deeds can make you something. I did some quick browsing and it doesn’t look like there is a TRD exhaust for the DC long bed. Just the Regular Cab long bed.
    the other thing you could do is call your local Toyota dealership and ask them if they have a part # for it.
