Am I screwed?
Discussion in 'Lighting' started by fmscott2, May 9, 2020.
  1. May 9, 2020 at 5:26 PM
    fmscott2
    fmscott2 [OP] New Member
    Want to add OEM style fog lights to my base model (fleet?) 2014. There is no receptacle for the fog light relay in the fuse box. See the red circle in the pic below. I have the wiring for the factory fog lights taped up behind the bumper. So where then does the other end of the wiring go?
  2. May 9, 2020 at 6:19 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
  3. May 9, 2020 at 6:38 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Hmmm the fuse box is the harness tgat has those connections... so it has to be there..
  4. May 9, 2020 at 8:12 PM
    fmscott2
    Can you remove the fuse box to see what wires are underneath it?
  5. May 9, 2020 at 8:44 PM
    empty_lord
    05 rollover special
    they seperate. kind of a pain to do. but they do split open
