Will it fit? If not how much lift?
Discussion in 'Wheels & Tires' started by 14burrito, Feb 4, 2017.
  1. Feb 4, 2017 at 4:00 PM
    14burrito
    14burrito [OP] IG @14burrito
    2014 SR5 CM 4x4 5.7
  2. Feb 4, 2017 at 4:06 PM
    sawzall, some strut spacers, you're good to go.
    Those are cute...35's?
    T-Rex266, GNTundra and 14burrito[OP] like this.
  3. Feb 4, 2017 at 4:19 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Nah measly 34", bought a spare to test fit prior to commiting to a full set. 285/75/17
  4. Feb 4, 2017 at 4:38 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    27" lift with CMC should do it
    14burrito[OP] and GNTundra like this.
  5. Feb 4, 2017 at 7:44 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Yes, but stay away from spacer lifts if you intend to take it off road.
    14burrito[OP] likes this.
  6. Feb 4, 2017 at 8:04 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Retrofit some BOSS or OME shocks. (Welding may work) whip out the grinder and cut as needed!!
  7. Feb 4, 2017 at 8:26 PM
    Midnighttaco08
    Midnighttaco08 High Quality H2O Inspector
    Sam
    Gilbert, AZ
    2017 Quicksand TRD OR 4x4 2008 Indigo Ink Tacoma TRDOR
    None yet!
    Thought I was on TW for a second :anonymous:
    3" lift should do it tho...
  8. Feb 4, 2017 at 9:44 PM
    Marty McFly
    Morty McBoonJug
    Just remove the front mud flaps, zero rub :thumbsup:
