Does my tundra have a factory amp or does the HU power the speakers?
Discussion in 'Audio & Video' started by CharlesDGR8, May 8, 2020.
  1. May 8, 2020 at 1:47 PM
    CharlesDGR8
    CharlesDGR8 [OP] New Member
    2019 Tundra TSS Double Cab
    So I’ve been looking to adding a subwoofer and I’ve looked and looked over threads to help me find my stock amp but no luck. It’s a Non-JBL. Anybody have any idea?
  2. May 8, 2020 at 1:50 PM
    johnnyskullface
    johnnyskullface New Member
    Beaverton, Oregon
    2018 White Tundra Limited Crewmax
    Looks like double cabs can come with one or not. If it has one its under the passenger front seat.
  3. May 8, 2020 at 1:52 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    If you have an SR5, you have an amp under the front passenger seat. The headunit powers the shitty speakers on the dash. The shitty amp powers the 4 shitty speakers on the doors. You will need a sound processor or LOC at a minimum to add a sub and amp.
  4. May 8, 2020 at 1:58 PM
    CharlesDGR8
    Yea there is no amp under the passenger seat. @johnnyskullface
    alrighty, i will look into buying an aftermarket HU @Danman34
    thanks gentlemen
  5. Jun 12, 2022 at 7:21 AM
    AlrightAlrightAlright
    AlrightAlrightAlright New Member
    Northwest Arkansas
    2020 SSM DC 4x4 with SR5 Upgrade Package
    RetraxONE MX retractable bed cover TRD Rear sway bar Debadged FabFours Matrix front bumper Smittybilt 9,500# XRC winch Aries 30" light bar (internal bumper mount) Diode Dynamics SS3 3" SAE Fog and Driving lights ConsoleVault RhinoRack crossbars
    Hey @Danman34 - I’m in the middle of planning the replacement of these OEM amp and speaker components in my truck. Do you know any of the specs on the factory amp with this very distinctive brand name ‘Shitty’?
  6. Jun 12, 2022 at 8:21 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    No amp under the seat?
    Is there anything under the passenger seat?
  7. Jun 12, 2022 at 8:29 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    The specs?
    Sure, it produces minimal wattage to power OEM 2-ohm door speakers.
    It's a POS.
    21CBB347-D751-4220-AD0B-F8726124EA25_zps_716c19ddf6955de56e203764ad16d8d9538f2ef7.jpg D366271B-A6F3-49DC-BA1A-E5DDA9144B25_zps_d46f0338ecba8b955744a85580c9aa3de8426e36.jpg
    Use one of these and you won't have to cut any OEM wiring.
    AutoHarnessHouse
    Also found here.
    2010-2019 Toyota Tundra (w/o JBL Audio) AutoHarnessHouse.com Factory Amp Upgrade Harness AHH-4438 : Electronics (amazon.com)
    One more thing;
    Buy the best front door components you can afford.
    Get the JBL door sails and mount your tweeters in them.
    Disconnect all 3 dash speakers, just unplug the side speakers, they feed the DVC center.
    And don't forget you'll need spacers/adapters to fit your aftermarket speakers in the doors.
    67491-0c020-c0
    67492-0c020-c0
    689D6A5A-12D7-46ED-8E04-46779903642B_zps_0f109f91e58e6181d356bb2dda8374e726b270f0.jpg B5767B44-33BF-42E9-ACEC-7ED59E995713_zps_8b507d5cb03d182017ac574ef236e816da242022.jpg
  8. Jun 12, 2022 at 9:27 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Why waste money on new sails? Just use a hole saw and drill holes in the ones you have.
  9. Jun 12, 2022 at 10:17 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    Because I want to be pretty and flat.
    The JBL sails angle the tweeter more towards in the inside of the cab.
    Stock sails have a curve to the face.
    A flat tweeter mounted in them looks like shit..
  10. Jun 12, 2022 at 10:57 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    The Infinity tweeters I have are adjustable. I have them angled towards me.
  11. Jun 12, 2022 at 11:50 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    I'm overwhelmingly and ecstatically excited that the stock door sail met your needs.
    They didn't meet mine.:oops: :thumbsup:
  12. Jun 12, 2022 at 12:09 PM
    mswya
    mswya New Member
    matthew
    I recently replaced the amp under the seat and the door speakers and added a hideaway sub. The upgrade was well worth it!
    I kept the factory head unit and I have the amp set for "high line level". Is that the right setting if you reused the factory amp input wiring?
    I ask because I have a bit of white noise when the volume is low.
    1lowlife likes this.
  13. Jun 12, 2022 at 1:32 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    Yes that is correct..
    Make sure your amp has a good ground.
    Make sure to get good ground contact to an unpainted surface.
    If I remember correctly the stock amp had its own ground bolt to the body.
    Make sure you used a big enough power wire gauge from the battery for your amp.
    You might need to make some gain adjustments on your amp.
    Look the this and see if it helps..
    Car Audio Noise Suppression Guide — Diagnosing and Treating Noise Problems in Your Car Audio System (crutchfield.com)
    This too.
    This guy makes great vidoes.
    https://youtu.be/Q8dpucdxs6Y
  14. Jun 12, 2022 at 4:25 PM
    Northwest Arkansas
    Mark (CAF) is a great expert, very responsive and helpful!
    1lowlife[QUOTED] likes this.
  15. Jun 12, 2022 at 8:10 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    I've learned a lot from him and his videos are well made.
    He dumbs it down without making one feel dumb...:D
  16. Jun 13, 2022 at 7:06 AM
    Northwest Arkansas
    I went ahead and paid for his consultation services. I used the Crutchfield tools and somehow got the right speakers, but the amp and subwoofer, I was completely lost. He was able to get me straightened out in a day.
  17. Jun 13, 2022 at 1:59 PM
    mswya
    mswya New Member
    matthew
    Thanks for the tips. I may have an issue with chassis ground of the amp being tied to the same place the ground cable is connected.
  18. Feb 9, 2023 at 5:25 PM
    Jpasic
    Jpasic New Member
    Not sure if anyone is watching this thread any longer but here it goes...
    I've got a SR (base model, like a "fleet" vehicle) not a SR5. I don't think I have a amp. The only thing under the passenger seat is a small (approx 8" x 3" ish) cylinder shaped black thing with two sets of wire coils attached. Sure doesn't look like an amp. If no amp, what is my easiest and least expensive option to get any audio sound improvement?
    Lkb1450 likes this.
  19. Dec 14, 2024 at 7:55 PM
    Lkb1450
    Lkb1450 New Member
    Also super curious, I have the same situation!!
  20. Dec 15, 2024 at 2:52 PM
    pH7
    pH7 New Member
    Hello All,
    I also have a base level 2012 Tundra (with the Texas package added). It seems like the wiring under the passenger seat is for potential power seats in the future (heatingcooling as well). Not sure if any of the wiring under that seat has anything to do with the amp leads. I installed an android head unit that I thought would resolve the speakers not working right. Same thing after install. I got full sound from passenger door and a little from the dash, and no back door sound at all....... I am guessing I will just be adding new speakers with new wiring to ensure everything works.
    I am hoping that someone who has gone through this already will share their wisdom. I snapped a picture of the wiring from under the passenger seat.
    I will most likely buy the Kenwood set which fits well based on some youtube videos.
    https://www.amazon.com/dp/B07R8WV1YD/?coliid=I66TA7ZGSTZQB&colid=2IA68C7OVMVS1
    Anyone used this set?
  21. Apr 10, 2025 at 5:24 AM
    Slim Goody
    Slim Goody New Member
    William Bruce
    2013 Toyota CM
    none
    I also have the exact same issue with my 2013 Crew Max, Non JBL sound system and the only speakers working are the passenger door & passenger dash tweeter. Nothing from the rear speakers or from the drivers side. I replaced the head unit & still have the same issues. If you found a solution, I would love to hear about it. It's driving me crazy!
  22. Apr 10, 2025 at 7:58 AM
    pH7
    pH7 New Member
    I installed the Kenwood set from Amazon. After installing new wiring from the new head unit, everything was good. I didn't do the back doors, so in the future I may need to rearrange things.
    I should have tried to trace the wiring and look for a short. The way this stock wiring works, is the head unit sends signal to the dash speaker, then from there another line goes from the dash speaker to the front door speaker. So if any part of that series has an issue, then neither speaker will work. There also could be a small amp hiding somewhere, but I kind of doubt Toyota would spend more money for that.
