  1. May 6, 2020 at 8:17 PM
    #7021
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Towed a couple horses around.
  2. May 6, 2020 at 11:07 PM
    #7022
    BigArt
    BigArt New Member
    2008 Tundra Crewmax Limited
    Wow, those are some serious mudflaps you have there!
    Mountun Goat likes this.
  3. May 6, 2020 at 11:12 PM
    #7023
    BigArt
    BigArt New Member
  4. May 7, 2020 at 2:11 AM
    #7024
    MikeBeach
    MikeBeach New Member
    Houston TX
    '11 CM-DAP-SABM/AFE/5100s etc.
    Couple set backs painting my headlights and trying to restore the lenses.
    All primed, ready to hit with a scotch brite pad/soapy water
    Disaster struck, as I was blowing them off to dry them, air caught an edge and peeled the paint, argh! I used adhesive promoter and self etching primer, 2 cans on the housings alone. Lesson learned.
    Another setback, this spare set of lights I had, the lenses were pretty trashed. Was really hopeful they would come back to life. But, after sanding and buffing, I went to hit them with clear coat and the clear coat cracked. Theyre ruined. Hit ebay and found some lights that have tabs broken etc, wound up finding a set for $65 shipped and Ill just rob the lenses off them.
    Wanted to try something different with the turn signal housings. Krylon makes a stained glass spray, Ive seen some ricers use it on their fogs. Hit it with 10 coats on the back and 4 on the front and then clear coated. 20200501_170907.jpg
    Heres a sneak peak as they sit waiting for the other set to come in. 20200505_205250.jpg
    Bama, Prostar 190, TheBeast and 5 others like this.
  5. May 7, 2020 at 8:41 AM
    #7025
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Yep, can’t huck rocks at that beauty trailer ;).
    kparrow, Prostar 190, MTRock and 3 others like this.
  6. May 7, 2020 at 8:42 AM
    #7026
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I love the yellow signal! Bummer on the other downfalls. Sounds like you have it under control! Looking good Mike.
    MikeBeach[QUOTED] likes this.
  7. May 7, 2020 at 2:04 PM
    #7027
    1rooster
    1rooster New Member
    Tony
    2007 crewmax
    Was putting some fresh paint on my engine cover when it feel off the hook and cracked... fmlEB43B9BF-C36C-48E9-BB7F-33758D643012.jpg
  8. May 7, 2020 at 2:18 PM
    #7028
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Damn, epoxy the bottom side and refinish the top side?
    TheBeast and Kiddnapped Tundra like this.
  9. May 7, 2020 at 5:48 PM
    #7029
    I did this during the week.
  10. May 7, 2020 at 6:18 PM
    #7030
    vhstejskal
    vhstejskal New Member
    Vic
    2010 Silver SR5 Crewmax
    That’s looking great. How do you like the setup?
    Silverghost likes this.
  11. May 7, 2020 at 6:24 PM
    #7031
    Alot nicer than the ReadyLift spacers. I put about 50 miles on it today. The shackles will be here tomm so I can get the rear block out.
    vhstejskal[QUOTED] likes this.
  12. May 7, 2020 at 6:27 PM
    #7032
    vhstejskal
    Vic
    Good luck to you sir. If your replacing the bushings they can be a pain.
    0.S.T. likes this.
  13. May 8, 2020 at 12:28 AM
    #7033
    NV.Recon
    NV.Recon Project FUV
    Scott
    Reno, NV
    2010 Limited CrewMax
    Installed rod holders inside the cab for my fly rods! IMG_20200507_131959.jpg
  14. May 8, 2020 at 8:13 AM
    #7034
    Kiddnapped Tundra
    Kiddnapped Tundra New Member
    Grand Island, NY
    2010 Tundra DC
    I finally finished routing the wires and got the 2 sets of KC lights I bought over the winter. You have to look real hard to see the Ditch lights, they blend in with the mirrors in this shot. They are KC pod lights on Rago brackets. The KC's on the push bar are yellow when on.
  15. May 8, 2020 at 2:43 PM
    #7035
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Had the battery and outer tie rods replaced, but the tech says the inner’s are seized and need to be replaced as well. Hate parting with so much money at once, but this is a 12 year old pickup that hasn’t needed much maintenance done in the 5 years I’ve owned it.
  16. May 8, 2020 at 2:53 PM
    #7036
    oogabooga289
    oogabooga289 New Member
    If your steering and suspension components are as siezed up as mine were (and you haven't had to adjust alignment since the truck was made), good luck getting the LCA cam bolts loose.
  17. May 8, 2020 at 6:36 PM
    #7037
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Rock Warrior grill arrived today!
  18. May 8, 2020 at 6:51 PM
    #7038
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Momma has discovered the Morimoto XB headlight upgrade/update, and now wants it for her sequioa. I know I saw someone somewhere on here that had them.
    How do you like them so far?
    Easy install?
    I'm assuming its literally just like swapping out headlights which I'm sure is no big deal. I mean hell, it can't be any harder than removing old, putting in new, and plugging everything up. I practically did that for the headlight washer nozzle.
    Are we expecting lens fade?
    I would HATE to spend $900 roughly and then in a few years the lenses fade similar to OG headlights?
  19. May 8, 2020 at 7:20 PM
    #7039
    vhstejskal
    Vic
    Found it need to locate what’s wrong here. :crazy:
    Mountun Goat and Tundra2 like this.
  20. May 8, 2020 at 7:22 PM
    #7040
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Gas tank skid plate broke a bolty?
    Should the skid plate mount point really be riveted? Is that OG, or an el cheapo repair?
  21. May 8, 2020 at 7:23 PM
    #7041
    vhstejskal
    Vic
    Yeah, not sure how that happened but embarrassed to say that I also don’t know how long it’s been like that.
  22. May 8, 2020 at 7:26 PM
    #7042
    sensei
    sensei master and teacher of nothing
    trd boosted, trd bbk, fox stage 4, corsa, amp, jl/kenwood
    I bought them but yet to install. all my research says plug and play. few notes:
    1. they come with headlight leveling feature but if your truck doesnt have it you can still add. there's a wire harness you can buy for a hilux on ebay or make one if you're inclined. i'll be adding leveling to mine.
    2. if you swap headlights be careful removing the extension panels (ie, filler panels) underneath the headlights. the two plastic guide pins break off pretty easy. watch a youtube video on how to remove the panels
    3. if she has fog lights consider getting their fog lights too or a set of LEDs to match the new headlights
    good luck, glad my wife isnt into modding. i cant afford another mod junkie.
    D4x4TRD and Tundra2[QUOTED] like this.
  23. May 8, 2020 at 7:53 PM
    #7043
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    You know about it now. Now you can fix it!
    vhstejskal likes this.
  24. May 8, 2020 at 7:54 PM
    #7044
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    She does not consider them a "mod" but an upgrade. This is the last time I mention an "upgrade" casually.
    As far as I know Sequoia's don't have the leveling system or at least ours does not. I might be wrong. Someone please correct me if I am.
    Extension panel clips, and drivers side panel are already on order due to the washer nozzle thing.
  25. May 9, 2020 at 1:16 PM
    #7045
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Spent last weekend picking up these curb throwaways and flipping them. 5 in total.
    Used the funds to get these:
    Now to find the time to install.
  26. May 9, 2020 at 6:34 PM
    #7046
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Got the rear shocks and sway bar installed. Need a better day to do the fronts.
  27. May 9, 2020 at 6:51 PM
    #7047
    1rooster
    1rooster New Member
    Tony
    2007 crewmax
    What you gone set the fronts at?
    97551DD6-3E86-4FFA-BC53-33877B690F9B.jpgI machined a “0” notch into my 5100s so I could run them with my Maxtrac with no added lift.
    Prostar 190 likes this.
  28. May 9, 2020 at 6:59 PM
    #7048
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    @1rooster I'm planning for mid height. I have 1 shim ready to go too. Need to measure and see how bad my drivers side lean is before I send it.
    1rooster likes this.
  29. May 9, 2020 at 7:06 PM
    #7049
    Iowa12tundra
    Iowa12tundra New Member
    2012 tundra crew
    Hey like your set up looks. I got the rock warrior grill recently and debating about my numbers too. What's your wheels and lift?
  30. May 9, 2020 at 7:09 PM
    #7050
    Punisher17
    Punisher17 New Member
    New Vision 372 Raptor rims tight af IMO love it gangsta so what I’m like is what do you guys use for matte wheels to keep them protected?
    Also I’d love to get Spyder headlights but I’ve heard so many bad things about their light output which is a huge deal for me where I live with no street lights.. any input appreciated
    Prostar 190 and Mountun Goat like this.
