2010 Tundra 5.7 4x4 Potential Purchase
Discussion in '2nd Gen Tundras (2007-2013)' started by V8Tundra4x4, May 6, 2020.
  1. May 6, 2020 at 5:26 PM
    V8Tundra4x4
    V8Tundra4x4 [OP] New Member
    NY
    I found a clean 2010 Tundra, 5.7 4x4 "extended cab" with towing package. It also has a cap on it that I'm not really a fan of, but whatever.
    79,000 miles.
    Asking price is $ 17,900 but I can probably get the guy to come down a bit since there are several 2010 trucks on cars.com right now with less miles listed at 16k.
    I know to look for frame rust, body rot, cam tower leak. Anything else I should watch out for? It's a one owner truck that was dealer maintained.
    Thanks in advance for any help.
  2. May 6, 2020 at 5:47 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    Buy it and don't look back.
    5ive7even likes this.
  3. May 7, 2020 at 7:56 AM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    try to see if the water pumps leaking at all and get dealer records. I always call the dealer and give them the vin then they will email you the full history on the vehicle.
  4. May 7, 2020 at 12:15 PM
    Dr_Al
    Dr_Al New Member
    Al
    Usually if it's a dealer you can get the carfax for free. Look at it to see where it spent it's life. Just because it's close to you doesn't mean it's local. When i was looking I found several that were used for pulling an RV. In the summer it would be in the rust belt but all the winter records would be in the warn states. You can also get an idea of how close they were when it came to changing the oil when it was due.
  5. May 7, 2020 at 1:16 PM
    V8Tundra4x4
    NY
    No, it's local. Private seller.
    Supposedly he has all of the maintenance records since it's been dealer maintained since new.
  6. May 7, 2020 at 3:27 PM
    5ive7even
    5ive7even New Member
    Brett
    Nova Scotia
    silver 2007 regular cab long box sr5
    Leveled w/ Bilstein 5100, 1.5" spacers & rear airbags, factory alloys wrapped w/ 275/70r18 Goodyear Duratracs and a SS Magnaflow 12588
    He said it best. awesome trucks, I love my second gen. Id look out for the bed rot issue, happens behind the wheel wells near the tail gate on both sides.. my truck had it pretty bad when I bought it, the previous owner told me that it was from a "space cap" he had on the truck (it was used as a work truck before I bought it used) but I've since found out from reading threads here that they rust from the bottom side up where the bed sits on the cross member on the frame. wasn't a deal breaker for me but I'm a welder/fitter so a little metal work doesn't bother me a whole lot
  7. May 7, 2020 at 8:06 PM
    ANOMIC
    ANOMIC New Member
    Do not buy without a carfax, ask your lender they will get you one with the vin
