  1. May 7, 2020 at 2:02 PM
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    Finished up the "base" of the drawer setup. I still need to get the "wings" cut and installed, figure out latches/handles and clean everything but it's getting there. The Flex-Seal is a great coating but it's definitely not the perrtiest!
    20200507_155215.jpg 20200507_160418.jpg 20200507_161653.jpg 20200507_161727.jpg
  2. May 7, 2020 at 4:05 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Discovered my end link has managed to start coming loose. Makes me really think the sway bar is indeed bent... hmmm
    bmf4069 and Tundra2 like this.
  3. May 7, 2020 at 4:12 PM
    empty_lord
    05 rollover special
    Actually. Looking closer. Looks like the Napa end links didn’t come with lock nuts... I’ll retighten for now and keep an eye on em.
  4. May 7, 2020 at 4:43 PM
    04 Tundra
    04 Tundra New Member
    Albert
    2004 Toyota Tundra 4x4 AC Limited
    DIFF Breather, Painted Rims, Interior Wrap, Tint,
    Brown Bear, hammeron, chrisb and 10 others like this.
  5. May 7, 2020 at 4:45 PM
    empty_lord
    05 rollover special
    04 Tundra[QUOTED] likes this.
  6. May 7, 2020 at 4:46 PM
    C54B63DC-99EF-405F-98F8-6B27F532895E.jpg So I’ve been chasing a stupid p0420 code, seemingly right after 12port injectors, I dreaded one leaking by, or that I toasted the cats some how. Well today I went to swap front air fuel sensors bank to bank, started on the driver, put on my money maker protectors and stuck my hands up in some hot pipes! When I got the ratchet onto the crows foot o2 socket, I was readjusting the ratchet for a better torque pull......but the sensor freed on that little bit if socket adjustment! Pretty sure I could have taken it out with a protected hand covering. Passenger side wasn’t much tighter. Both smelled and tasted the same. Driver side was definitely harder to put back in, with my big banana fingers. Only thing I noticed different between the two was the bottom numbers 07g23 on driver and 07g25 on pass. Not sure if that’s a serial number or not? But when I fired the truck up, it was THEEEE smoothest and quietest start up I feel like I’ve heard in a long time! So that’s kinda promising I hope! I guess I should go take her for a spin?
    chrisb, oscardog86, NUDRAT and 3 others like this.
  7. May 7, 2020 at 4:46 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Nice! What is your rating on the beer scale of difficulty?
    oscardog86 and NUDRAT like this.
  8. May 7, 2020 at 5:09 PM
    04 Tundra
    Albert
    Install 4
    Removal empty the fridge
    TX-TRD1stGEN, NUDRAT, CodyP and 5 others like this.
  9. May 7, 2020 at 5:21 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Never had the opportunity to remove or work on the o2 sensors before, but have heard they are usually seized up. Hope this is the fix for you.
    NUDRAT and Tundra2 like this.
  10. May 7, 2020 at 5:22 PM
    Fred
    Hand Protectors
    Impressive. I’d hire you.
    EDIT: Any improvement in performance?
    Tundra2 and 04 Tundra[QUOTED] like this.
  11. May 7, 2020 at 5:32 PM
    04 Tundra
    Albert
    I didnt dyno anything and wont be doing that. BUT i could never do a burnout from fully stopped and going straight. I can now so i got something for sure. Also in gear with the foot off the gas she really wants to pull harder then before. Start up is butter i love it
    chrisb, NUDRAT, Tundra2 and 2 others like this.
  12. May 7, 2020 at 5:32 PM
    Yeah I’m used to seeing exhaust bolts and stuff rusted to hell. I’m not sure if they had been removed before, but i soaked them to no end with kroil the day before, juiced it on real good! With the crow foot o2 socket, it was super easy.
    https://www.amazon.com/OEMTOOLS-25249-Oxygen-Sensor-Crowfoot/dp/B004FEN9JG
    something like that, I went local, overpaid by 3$, but big gurrl has been lagging w delivery, so I’ll pay the price for satisfaction now.
  13. May 7, 2020 at 5:34 PM
    04 Tundra
    Albert
    I had a p0430 code i switched my 02 sensors and they worked. I made a thread up on it.
  14. May 7, 2020 at 5:36 PM
    Fred
    Hand Protectors
    Nice. Stoked for ya. Sounds like you got some gains for sure.
    NUDRAT likes this.
  15. May 7, 2020 at 6:06 PM
    I have how Big Gurrl has become part of the forum lingo. We don't even have to explain it. :rofl:
    Nice job PHM.
    NUDRAT, FrenchToasty, Tundra2 and 3 others like this.
  16. May 7, 2020 at 6:15 PM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    Did the seafoam SS14 treatment on the ol' gal today. I totally forgot to take pics, but I had a grand time dumping smoke on the roads and getting that brake pedal to soften up.
    This was the first time getting my brakes hot with the DOT 5.1 brake fluid and it felt a lot better. Still spongy, but nothing like it has been in the past.
    I installed the JBA shortys on my tundra a few months back and I absolutely agree with 04 Tundra on the removal process being a refrigerator emptying experience.
    NUDRAT, 04 Tundra, Darkness and 2 others like this.
  17. May 7, 2020 at 6:28 PM
    Fred
    Hand Protectors
    Still waiting on my ‘stemillus’ money. Breaking a little wood on these headers, except I prefer to keep a stocked frig.
    theblurry1, Thrussn and Tundra2 like this.
  18. May 7, 2020 at 6:51 PM
    Thrussn
    Gabe
    NM
    My stemillus went straight to my new leaf pack and those superbumps. Not sure if it was worth it yet.
  19. May 7, 2020 at 7:10 PM
    I’m pretty sure I’m gonna go full mentality challenged, and do long tubes, “freest flowing cats” and cat back. I’ve been doing a bunch of side jobs(kinda feel bad getting paid to tell them they need new equipment) so I haven’t touched the stache under the bed in a long time, I checked the other day and was shocked. After we get taxes back and I get paid for doing the AC in our house, it won’t be a dream
    I really need to call Keith
  20. May 7, 2020 at 7:13 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    If I'm being honest, and I am, I still don't know where to go when people say they got em from 'Big Gurrl'...I just picture a big black chick on the street corner slingin' truck parts.
    My luck my wife would peek over at my google search and wonder what the hell is wrong with me! haha
    Darkness, Tundra2 and FrenchToasty like this.
  21. May 7, 2020 at 7:19 PM
    Your guilty, just don’t know it yet.
    Haha I definitely searched for big gurrl on google, got some interesting sites.
    That’s why PHM was missed greatly.
    I also noticed recently, my auto correct really likes PHM.......kinda weird
    Darkness, Tundra2 and CodyP[QUOTED] like this.
  22. May 7, 2020 at 7:28 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    bromance!
    Soooo....it's a truck parts website? or on the black market?
  23. May 7, 2020 at 7:40 PM
    Dog
    Dog sit!
    Rocky Mountain high...
    2006 SR5 AC 4x4 TRD-OR
    Ok, I'll spell it out. Big Gurrl = Amazon. If you google definition of Amazon, it is a tribe of really large women on a mythical island (as I recall..)
    EDIT: from Greek mythology, large women warriors ... and maybe not an island...
    bmf4069, chrisb, speedtre and 7 others like this.
  24. May 7, 2020 at 7:41 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    ...and this is why I will never be any good at Jeopardy
    What is thank you
    bmf4069, chrisb, speedtre and 3 others like this.
  25. May 7, 2020 at 7:52 PM
    Haha once you see it, it’s like ohhhhh yeah!!!
  26. May 7, 2020 at 8:10 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Also, me and big gurrll go way back....I am basically her full week lover.
    Funny story:
    With all the Amazon shopping I do the UPS, FEDEX and USPS drivers know my house well. I’ve been doing a bunch of outside work to the house and the other day the UPS driver came with a package and said, “Man, it sure has come a long way since last fall. You’ve done a ton of work and it’s looking great!”
    I was a bit happy to have someone else see the fruits of my labor and a bit embarrassed that he stops at my house so frequently haha.
    theblurry1, bmf4069, chrisb and 6 others like this.
  27. May 7, 2020 at 8:28 PM
    I’ve had one younger dude, not normal guy, almost cream himself delivering a snorkel for the 4runner, the other normal guy, has told me his wife has a top of the line 4runner that she never takes on dirt. I’m always creepin and drinking in the front side yard(grilling and pond territory) and the neighbors always get stuff, the normal guy yells, nothing for you today, I’m like, yeah I know, but hello!! Haha
  28. May 7, 2020 at 8:32 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    glad I'm not the only one.
  29. May 7, 2020 at 8:50 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    I apologized to my UPS guy on Monday for the Tacoma receiver hitch coming Friday or Monday. He was cool with it & offered to deliver it out back by the garage. There'll also be an adaptor for the Tundra as it has a 7pin socket, so adaptor will let me connect 4pin trailers.
    theblurry1, bmf4069 and FrenchToasty like this.
  30. May 7, 2020 at 8:53 PM
    Have some frosty beverages waiting for him, a menagerie of choices maybe.
    Tundra2 and NUDRAT[QUOTED] like this.
