Missed the engine filler port. Who else has done this?
Discussion in '2.5 Gen Tundras (2014-2021)' started by VA10, May 3, 2020.
  1. May 3, 2020 at 5:01 PM
    VA10
    VA10 [OP] New Member
    Virginia
    I performed my trucks first oil change at 5k yesterday. Everything, went smoothly as expected. Except the pouring part. While I started pouring the last couple of quarts - I got completely distracted by something out of the corner of my eye - causing me to miss and pour maybe 1 - 2cups of oil all around the filler area. I can see some oil pooled up on top of the valve cover - no deeper than 1/16th''. I'd like to clean it up but the places are to tightly tucked away for me to get my hands. Does anyone have any estimates for how long the oil will take to burn off? I think a majority of the oil has dripped down onto other parts...as well as my driveway....
  2. May 3, 2020 at 5:21 PM
    Chip_Tundra
    Chip_Tundra New Member
    Lol, wipe off everything you can by hand. Next, get a power washer.
  3. May 3, 2020 at 5:50 PM
    koditten
    Kirk
    Midland of the Mitten
    There is a product called Oclanosorb. Sprinkle it all around the oil spill. 2 days later use compressed air to blow the material off the engine.
    No worries about water getting blasted where it's not supposed to be.
    It's main ingredient is pulverized peat moss. It works amazing!
    AutoZone carries a similar product, but it's a bit spendy. It still works the same and just as good, just not in as large of a bag. (You won't need a big bag).
    WILLINH, Hbjeff and texasrho83 like this.
  4. May 3, 2020 at 5:55 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Spray it all down with engine parts cleaner and be done with it
    Inquiringone and Hbjeff like this.
  5. May 3, 2020 at 5:55 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Douche the area with Brake Clean. Rinse off with water. Go about your life.
    Inquiringone likes this.
  6. May 3, 2020 at 6:00 PM
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    Degreaser and water hose.
  7. May 3, 2020 at 6:41 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
  8. May 3, 2020 at 7:19 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Buy a big funnel for next time.
    Your snap on one is kool, little pricey. :boink:. good luck Sir
  9. May 3, 2020 at 7:28 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    ryanryan34 likes this.
  10. May 4, 2020 at 4:35 AM
    Stig
    Stig New Member
  11. May 4, 2020 at 5:02 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Sumo91 and Y0TA PR0 like this.
  12. May 4, 2020 at 5:15 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Nah, me neither. NEVER did I do that before! :anonymous:
    Tent a rag over the end of a long screwdriver and hold the rag up around the handle. Then, stick the screwdriver down in the close spots and mop up the oil. Change the position of the rag as necessary. Someone more clumsy than me said this will work like a charm. :thumbsup:
    But, if you want to feel better about yourself, a guy on another forum changed his oil, then wondered why the oil level was way high on the dipstick. He also mentioned that his transmission wouldn't shift either. :confused: :eek:
  13. May 4, 2020 at 5:30 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I use a funnel specifically designed for Toyota. It screws right into the neck and it’s large. If you miss that thing you have probably fallen over.
  14. May 4, 2020 at 5:54 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    This post SUCKS without picture of HER!
  15. May 4, 2020 at 5:55 AM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    These are things I have used that screw directly into the cap opening:
    Milk or Tea Jugs
    Juice Jugs
    Etc etc whatever fits
    I cut a few inches off the bottom and wash them out very well
    Then screw them into the filler cap opening
    No More Spills
    Uhhhh.... and NewImprovedRon like this.
  16. May 4, 2020 at 8:18 AM
    glowblue
    glowblue From time to time
    VA
    FrenchToasty and BTBAKER like this.
  17. May 4, 2020 at 8:21 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    That’s exactly what I use. Works great.
    glowblue[QUOTED] likes this.
  18. May 4, 2020 at 8:34 AM
    PKFan
    2018 Inferno! DC SR5 4x4
    I have the same funnel. Also have the Honda lower chamber that screws into my son's Accord and the adapter for my wife's Sienna with a half-turn opening. It's a real help when you're trying to pour those 5 qt jugs with only 2 hands.
  19. May 6, 2020 at 4:29 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    HALP!
  20. May 6, 2020 at 5:49 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    Agreed. You can get the same thing by cutting the bottom off a milk jug and screwing it into the oil thingy. I used an empty bottle of windshield washer fluid. Cut the bottom off, rinsed/wiped it out really well, and viola - a giant funnel that screws into the oil intakey thingy.
  21. May 6, 2020 at 5:58 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    LOL, I thought I was the only one that used that half milk jug. First time my coworker saw me do this to his car, he thought that was the most ghettoist thing he'd ever seen in his life... besides all the side Mexican remarks he could come up at the moment. It was funny for a bit, but then got old fast and I stopped helping this dude.
    My problem with funnels is the same as everyone's relationship with that 10mm socket (I have multiple, more than 5). They're there when you don't need it, gone when you do.
    NewImprovedRon and Uhhhh.... like this.
  22. May 6, 2020 at 6:02 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Bingo. We all like to DIY - resourcefulness comes with that haha
    Uhhhh....[QUOTED] likes this.
  23. May 6, 2020 at 6:04 AM
    Twise
    Twise More punk than you...
    Trever
    Temecula, California
    2017 Tundra Cmax TRD Off-road
    Fox 2.5 /w DSC CO’s and Rear Shocks, Total Chaos UCA’s, 17” Rock Warriors /w 35 12.5 17 BFG AT KO2’s, Powerstop Rotors and Pads Front And Rear and The stereo is really nice.
  24. May 6, 2020 at 6:58 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Try this
    bmcdds and NewImprovedRon like this.
