Any benefit to UCAs with a 2/1 level kit?
Discussion in 'Suspension' started by TKNorthwest, May 5, 2020.
  1. May 5, 2020 at 8:34 AM
    TKNorthwest
    TKNorthwest [OP] New Member
    Washington
    2018 Limited Crewmax 4x4
    I needed new UCAs on my 03 after lifting the front at least 3 inches. I'm only gonna lift my 18' maybe 2 inches in the front. Is there any benefit to new upper control arms like total chaos? I know everyone says they aren't neccesary. until around 3" or more.
    The last time I did UCA's (on my first gen) I wished I would have just done everything when I swapped out the struts.
  2. May 5, 2020 at 9:01 AM
    I would for alignment purposes. You’re already under there so buy once, cry once.
  3. May 5, 2020 at 9:20 AM
    IMO it's a waste for 2 inches.
    EDDO likes this.
  4. May 5, 2020 at 9:22 AM
    TKNorthwest
    Washington
    That's what I figured. I was just wondering if there's any benefits to a uniball or delta joint arm, apart from lifted/level applications.
    If someone with stock suspension threw on delta joint ucas, would there be any posetives?
