Load Reduction?
Discussion in 'Towing & Hauling' started by green winged teal, May 3, 2020.
  1. May 3, 2020 at 5:22 PM
    green winged teal
    green winged teal [OP] New Member
    2008 Tundra
    I have a 2008 double cab tundra grade tundra. The yellow sticker with the load and cargo capacity states 1,395 pounds.
    Then I have this sticker that states my cargo capacity has been reduced by 380 pounds. Do any of you know what would have been added to get the load reduced by 380 pounds? It has a spray in bed liner but nothing else that I can think of to reduce it.
    The reason I ask is because with this reduction it gives me 1,015 pounds. I wanted to get a trailer but I've been reading a lot on this site and I really don't think I can get the size of trailer I wanted without going to a bigger truck.
  2. May 3, 2020 at 5:32 PM
    Options reduce the weight:
    Sunroof, step bars, trim packages all add weight.
    GODZILLA likes this.
  3. May 3, 2020 at 5:40 PM
    spn4125
    spn4125 New Member
    Most likely a sticker from the bed liner place. I have a similar one they added to the door jam, not sure of the weight they listed off the top of my head.
  4. May 3, 2020 at 5:52 PM
    green winged teal
    2008 Tundra
    That's the thing there are no step bars, sun roof, rear sliding window or anything like that. It is a base model truck that's why I can't figure out why the number is so high.
  5. May 3, 2020 at 6:02 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
  6. May 4, 2020 at 9:42 PM
    green winged teal
    2008 Tundra
