2006 lower control arm bushings
Discussion in '1st Gen Tundras (2000-2006)' started by Rubes, Jul 3, 2019.
  1. Jul 3, 2019 at 10:45 AM
    Rubes
    Rubes [OP] New Member
    c
    Knoxville
    2006 crew cab
    Hello - I recently got a 2006 and it seems like I need lower control arm bushings. I asked a mechanic I know about repairing it and he said that you can't buy the sleeves for the bushings and I would need to buy new control arms. Is this accurate ? Any advice would be much appreciated.
    Thanks
  2. Jul 3, 2019 at 12:06 PM
    Casper421
    In the woods
    06 DC
    I had a shop press in new oem bushings when I installed the new suspension. It can be done but depending on rust, it’s easier and cheaper to buy aftermarket arms with bushings.
    Xsnrg2006 likes this.
  3. Jul 3, 2019 at 2:25 PM
    Professional Hand Model
    Fred
    Hand Protectors
    I had my front end rebuilt last year and I bought new OEM lower control arms as it made economic sense even though it cost $ instead of having them pressed in. Mine were rusty a bit and needed cutting off.
    Your truck will now be able to have a proper alignment with new cam bolts. The OEM bolts are stupid expensive and I went with what the shop recco’d. Not sure of the brand, but they like using them and allows a better precise full alignment at 70% less than OEM.
    Mr_Bill_of_Texas likes this.
  4. May 2, 2020 at 6:08 PM
    Xsnrg2006
    Xsnrg2006 Smiley the Tundra
    Dale
    SoFla
    2006 Limited Crew Cab
    I sure wish there was a 2005-06 Tundra LCA Bushing Remove/Replace Video available with even slightly rusty Cam Sleeves cut off to press out. I am eating crap right now trying to get mine out of one. Using Heat and Bearing separator on 20 ton HF Press tomorrow but am almost over it. I have already bought all the replace parts but now desperate enuf to just get some new with bushings already in.
    It is kicking my ass!
    I wrote this earlier without realizing the Timmy the Toyota Toolman video on this did cover exactly what I was asking for...
    Mea Culpa
  5. May 2, 2020 at 6:13 PM
    Fred
    Hand Protectors
    I did a ton a research before having someone else rebuild my front end. Just bought new LCA’s and called it a day. Many others here that love doing suspension work (which I despise) even say its best to buy new arms with the bushings already pressed in. I bought new OEM arms from Toyota and had a shop install. Pricey, but I’m not in hurtsville like you right now! :D
    bmf4069 and Xsnrg2006[QUOTED] like this.
  6. May 2, 2020 at 6:26 PM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    Buy moog complete lower control arms
    replace them
    that’s what i did On my 06
    No issues
    way easier
    i made advanced auto price match rock auto then hit them with a coupon
    skywalker474, bmf4069 and Xsnrg2006 like this.
  7. May 2, 2020 at 9:33 PM
    Xsnrg2006
    Dale
    SoFla
    I already ordered the Passenger Side MOOG. Will do the upper(s) and the rest of my long checklist while waiting arrival. Am gonna put my new/unused parts on ebay when this is complete. Sorry now I got everything so early on before my education...
    Thanks for good advice!!!
  8. May 2, 2020 at 9:35 PM
    3.4Tundra
    3.4Tundra New Member
    Greg
    So. California
    2006 V8 Tundra 2wd
    Bilstein 5100
    Try this video. Tim does great vids on Toyota Trucks, usually 4runners but the process is the same
    https://youtu.be/_lZbAd1_EUM
    Xsnrg2006[QUOTED] likes this.
  9. May 2, 2020 at 9:43 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    @Xsnrg2006 if you cut the shoulder of the bushing assembly off with a sawzall you should then be able to press the bushing out. If not, then cut the bushing in a circular way around the inner sleeve. Once that's out CAREFULLY cut into the outer sleeve in two spots and chisel that thing out. Then clean the path and press your new bushings in.
    Or give up and buy new arms. Up to you.
  10. May 3, 2020 at 10:57 AM
    Xsnrg2006
    Dale
    SoFla
    I thank you all for the advice. I have been subscribed to Timmy's Channel for a while and agree he is the best tutorial guy across the board. I screwed up and while I had a job did not buy everything he recommends, but now have learned the hard way that cutting out and replacing with new is the way to go.
    The things that are discovered on 15 yr old Tundras when dissembling an entire front end even when you think you have all the replacement parts and tools is that usually you don't. Specialty deep exact receiving/pressing sleeves(MATCO set is limited), 5-10 ton bottle jacks, extra large vice, my missing 16" Channel Lock pliers(liberated from me at a gig...), etc and so on.
    Found the main thru bolt(7 1/4" by 5/8" D) to my Steering rack is bent from some hellacious off road hit and cannot be removed, so I have to get to Toyota twice, once to order/pay then pick up a couple days later, and it is hard to find a ride with the Rona freaking everyone out. I did receive my 6 Diablo Carbide Tip Sawsall blades so can cut stuff! Stuck on driver side until that is resolved. Fortunately having all else broken down and out/out of the way as possible gives access to it all. Plus I have LOTS of time... Unfortunately am on fumes fund wise, no vehicle, no job(Union Stagehand, and ALL Theaters and Venues are CLOSED for several months at least). At least everything once done should get me another 100K easy, and now I have learned to not wait to do several important fixes until it is too late for easy R&R.
    So forgive me spitting out my Life Story, but gotta say that without the Learned and Great Helpfulness of these Tundra Forums' Members I couldn't have even gotten this far!
    I will update as soon as Progress returns, but in the meanwhile going now to order the Driver Side LCA so that I can hopefully overcome my own overconfidence and under-preparedness.
    May my lessons prove to help anyone else from incurring the many damning obstacles I have encountered.
    Afterall, that is why We All are looking out for each other the best We can.
    Thanks to All Again.
    Onward, Forward, Thru the Fog.
    Hoferkill likes this.
  11. May 3, 2020 at 11:22 AM
    Fred
    Hand Protectors
    Heres to hoping your stage career blossoms in the near future!
    bmf4069, Darkness and Xsnrg2006 like this.
  12. May 3, 2020 at 2:07 PM
    Xsnrg2006
    Dale
    SoFla
    I do so appreciate that for All of my Brothers and Sisters Nation/Worldwide that are SOL until then for the most part. Am considering other jobs I can do Independently or for hire, but after nearly 40 years in biz, not looking forward to a career change. We have to do what it takes in life of course so...
    Maybe I can start specializing in LCA Bushing Replacement!! LOL
    Thanks again for the Best Wishes PHM.
  13. May 3, 2020 at 8:13 PM
    Xsnrg2006
    Dale
    SoFla
    That is exactly what I did!
    I got both cams off and out to remove driver side this evening, no cutting.
    There is enuf play that an glad to have ordered both.
    Plus the bent Main Steering rack mount bolt is on the way as well.
    The Diablo Carbon Blade took it out in 15 seconds.
    Its gotta be all downhill from here...
  14. May 4, 2020 at 3:39 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Now you've jinxed yourself.
    Xsnrg2006[QUOTED] and bmf4069 like this.
  15. May 4, 2020 at 6:19 AM
    Fred
    Hand Protectors
    Depends on your definition of ‘downhill’.
  16. May 4, 2020 at 12:46 PM
    Xsnrg2006
    Dale
    SoFla
    There are no real geographic "downhills" here in South Florida but sinking in the swamplands!
    Glub glub glub
  17. May 4, 2020 at 1:01 PM
    Did you already sell off your bushings you didn’t use? What are you trying to get for them?
