Common issues, that aren't so common?
Discussion in '2nd Gen Tundras (2007-2013)' started by BoTheTundra, May 3, 2020.
  1. May 3, 2020 at 11:19 AM
    BoTheTundra
    BoTheTundra [OP] New Member
    Thomas
    2007 tundra TRD sr5
    Lift with rims and tires, exhaust mirrors skid plate, whole interior sound system and head unit
    I find my self often hearing slight noises that are strange but wouldn't say note worth, a small clank here and maybe a swaylink bind there, but nothing big of an issue. My truck is an 07 DC 5.7 4WD with just under 240k on it, and it just seems strange I have yet to run into a major issue or something noteworthy. I'm looking for personal experience or any advice on things to look out for, I am aware of the frame recall which I've done aswell and the bed rusting which I'm working on getting fixed. I know the water pumps are know for issues and that's been done just about 170k so I'm good there. I hear there's a steering component that goes bad but as far as I know and the 6 years owning the truck and researching that's all I can find. With that being said my life's taking me in a direction where I'd like to keep the truck for a while longer so I'm seeing if anyone with more knowledge has and insight on some prevent things to look for. Thanks!
    Filthyphil likes this.
  2. May 3, 2020 at 11:42 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    At 12 years of ownership and 220k right now on a 5.7 2wd DC SR5 long bed,
    Starter replaced at 210k
    Fuel gauge has been off for the last 3-4 years
    window switch replacement, under TSB about 3 years ago
    Stock head unit ate my CDs and wont eject them, lol...
    I've had issues early on, within the first 3 years of ownership
    Transmission seals leaking at 30k
    Electrical gremlins which are pretty much gone
    Water pump bursted and replaced around 30k
    frame inspection
    Driver door realignment with Dash re-dye due to rubbing
    Driver seat has a rod sticking out 15k, was never resolved.
    Paint peel about 15k, These last 3 were probably because the truck was wrecked at some point in the dealer lot, damage is still undisclosed...
  3. May 3, 2020 at 11:46 AM
    BoTheTundra
    Thomas
    2007 tundra TRD sr5
    Trans for 2007-2008 had a recall to replace before 36k and mine went to 164k and they still did it because I wasn't notified of it
  4. May 3, 2020 at 11:47 AM
    blackdemon_tt
    I didn't know of such recall, as far as I know, I'm still on the original transmission.
  5. May 3, 2020 at 3:42 PM
    BoTheTundra
    Thomas
    2007 tundra TRD sr5
    It was for a certain reason like because I had the tow package with something else
  6. May 4, 2020 at 5:17 AM
    blackdemon_tt
    I'll have to look into it, I do have the tow package too.
