Exhaust replacement
Discussion in 'Performance and Tuning' started by Spaceiscool, May 1, 2020.
  1. May 1, 2020 at 9:31 AM
    Spaceiscool
    Spaceiscool [OP] Something something.. danger zone?
    JL
    Ontario
    2008 White Tundra CM TRD
    Spray painted rims
  2. May 1, 2020 at 9:33 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Buy some new exhaust pipe
  3. May 1, 2020 at 9:34 AM
    Spaceiscool
    JL
    Ontario
    Spray painted rims
    If i just do the pipe i assume it needs to he welded on. Would that be more cost effective than to replace?
    I dont have a welder.
  4. May 1, 2020 at 9:40 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    From that pic what little I see is needing replacement. That pipe doesnt look worthy of a new weld. Take it to a muffler shop and let them fix it. You might be out a hundo
    Mountun Goat and Spaceiscool[OP] like this.
  5. May 1, 2020 at 9:45 AM
    ZTundra
    ZTundra New Member
    ZACK
    Knoxville, TN
    2021 MGM Nightshade
    There are plenty of guys on here that have replaced there muffler section with something else. I would be willing to bet someone nearish to you has one they would sell really cheap to you or possibly give it to you. Then all you would have to do is remove a few bolts, pull out the muffler section, replace, and reinstall the bolts.
    Spaceiscool[OP] likes this.
  6. May 1, 2020 at 9:53 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    If the muffler is still good and you're looking for a cheap fix, the shop will put a new piece of pipe on for you, weld it up and you're good.
  7. May 1, 2020 at 10:00 AM
    BENWALES
    BENWALES New Member
    Ben
    2020 Tundra White SR5
    There are plenty of brand new stock exhaust systems in the buy/sell/trade boards. What year is your truck?
  8. May 1, 2020 at 10:03 AM
    Spaceiscool
    JL
    Ontario
    Spray painted rims
    Muffler is still good and the exhaust pipe afterwards is in great shape. Im on the covid income so cost is important. I will ring up a shop and look into that.
    I was checking the classifieds as ZTundra suggested ive seen some new take offs for 350ish or that replacement muffler for under 200.
  9. May 1, 2020 at 10:04 AM
    Spaceiscool
    JL
    Ontario
    Spray painted rims
    Its an 08 crewmax, im in canada though
  10. May 1, 2020 at 10:10 AM
    BENWALES
    BENWALES New Member
    Ben
    Ahh I had the 07-08 bastard exhaust system. They are still out there. You can still pick up a newer stock system really cheap and have the Muffler shop modify the pipes leading in. However nothing sound cooler than a Dirt Deeds Exhaust.
  11. May 1, 2020 at 10:13 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Hell I gave my old muffler and tailpipe section away to a scrapper lol
  12. May 1, 2020 at 10:14 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    @dirtydeeds is running a hell of a special if you're an "essential" too
    MTRock, Spaceiscool[OP] and BENWALES like this.
  13. May 1, 2020 at 10:28 AM
    Spaceiscool
    JL
    Ontario
    Spray painted rims
    Thanks guys i will check my options. Good to know a pipe shouldnt be too hard or costly to fix. Im going to check the classifieds in my area, downside is theres not many tundras and if there is parts usually a few hours away.
  14. May 1, 2020 at 10:37 AM
    Spaceiscool
    JL
    Ontario
    Spray painted rims
    Theres one less than an hour away off a 2015, only used for 10,000 kms, curious if theres a change in fitment from 2nd to 3rd gens?
  15. May 1, 2020 at 12:12 PM
    ZTundra
    ZTundra New Member
    ZACK
    Knoxville, TN
    2021 MGM Nightshade
    I couldn't say for sure, but I do know dirty deeds exhausts are for 07 and up.
  16. May 1, 2020 at 1:21 PM
    Spaceiscool
    JL
    Ontario
    Spray painted rims
    Okay so after some searching looks like 2nd gen and 3rd gens are compatible and crewmax and double cab are as well. Only difference is double cab long box. Messaged seller regarding 2015 take off for $160. I would be happy to stay stock. If i can get it for a similar price to a pipe repair i may as well replace the whole unit. Thanks for all the help so far fellas
    Edit, just double checked the connection at the converter, the catalytic converter looks good but where the two pipes connect it looks like the connection was welded and now rusted so i couldnt just bolt a new muffler on. Would a shop be able to fix that connection rather than replace that whole unit as well?
    texasrho83 likes this.
  17. May 2, 2020 at 5:09 AM
    BENWALES
    BENWALES New Member
    Ben
    Exhaust shop will cut off the flanges and weld new ones on.
    Spaceiscool[OP] and texasrho83 like this.
  18. May 2, 2020 at 8:23 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    This ^^^
  19. May 2, 2020 at 9:25 AM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
  20. May 2, 2020 at 5:46 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    B.Ross[QUOTED] likes this.
