285/75 R18 on a 2018 Tundra CM 3-1 leveling Kit
Discussion in 'Suspension' started by redduc, Apr 30, 2020.
  1. Apr 30, 2020 at 5:10 PM
    redduc
    redduc [OP] 2018 Limited
    Derek
    2018 Met. Gray Tundra TRD
    Shell so far ......I’m going with a 3 inch lift and want to know if you guys like 285/70 or 75’s and did they rub?
  2. Apr 30, 2020 at 5:14 PM
    Tundraman1000
    Tundraman1000 New Member
    2016 SR5 DC MGM 4x4
    Looks great
  3. Apr 30, 2020 at 5:14 PM
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    Nice tires! Please post actual tape measurements and psi. Thank you, nice work. If you weighed them first that would be a great point of reference too.welcome.
  4. Apr 30, 2020 at 6:28 PM
    redduc
    Derek
    34.8 h and 11.2 foot print and 80 psi
    Sorry didn’t Wt them...
  5. Apr 30, 2020 at 6:44 PM
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    As I suspected nitto are closer to posted size. Don’t be sorry! Nice looking ride!
  6. Apr 30, 2020 at 6:48 PM
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    Maybe let some air out so you don’t hurt yourself :)
    Zero One Actual likes this.
  7. Apr 30, 2020 at 7:00 PM
    808Guy
    808Guy New Member
    Midwest
    2020 White Tundra SR5 CrewMax
    3" ReadyLift
    I have the same tires size on with TRD Pro wheels(60mm offset) and 1 1/4 Spidertrax spacers. I also have a 3/1 ReadyLift kit on. Try and reverse with the steering wheel turned fully left or right, it should rub.
  8. Apr 30, 2020 at 7:47 PM
    redduc
    Derek
    They don’t the Pro Comp kit and some skid plate trimmed and front flap removed all good.
  9. Apr 30, 2020 at 8:00 PM
    Zero One Actual
    80 psi is way too high.
    zcarpenter92, TheBeast and Skey44 like this.
  10. Apr 30, 2020 at 9:03 PM
    redduc
    Derek
    What then? It may not be haven’t checked it just installed only 10 miles on them and did lock L/R in reverse no rub.
  11. Apr 30, 2020 at 9:04 PM
    redduc
    Derek
    What then? It may not be haven’t checked it just installed only 10 miles on them and did lock L/R in reverse no rub. Will check in Am
  12. May 1, 2020 at 1:03 AM
    Zero One Actual
    zcarpenter92 and TheBeast like this.
  13. May 1, 2020 at 6:03 AM
    redduc
    Derek
    I just checked and they are at 40 psi.
    Thanks
    TheBeast and Zero One Actual like this.
  14. May 1, 2020 at 12:56 PM
    Zero One Actual
    Awesome. Double that at 80 and we were worried about your spine! Hahahaha.
    TheBeast likes this.
  15. May 1, 2020 at 7:55 PM
    redduc
    Derek
    Thanks
  16. May 1, 2020 at 7:57 PM
    redduc
    Derek
    Great conversations!!!!
