3” lift front and 3” rear help
Discussion in 'Suspension' started by vtdude27, Apr 29, 2020.
  1. Apr 29, 2020 at 4:49 PM
    vtdude27
    vtdude27 [OP] New Member
    2018 Black Tundra Platinum
    TRD EXHAUST TRD INTAKE RUNNING BOARDS
    I was convinced to get old man emu 3” front and rear lift over a level. Wanted better ride quality, better suspension, etc. but I’m scared it’s going to be too high.
    anyone have any pics of 3” front AND 3” rear lifts? Please help ease my mind
  2. Apr 30, 2020 at 7:04 AM
    The lift itself wont be too high. 3" is common for most of us. The question is.....what is your wheel and tire setup?
  3. Apr 30, 2020 at 7:13 AM
    vtdude27
    Okay thanks for your input, I don't like huge wheels and offsets, I like a lower more "filled out" look, but stock height is waaaay too low. Was driving on a job site yesterday and was scraping mud up front underneath haha
    I was thinking something like this
    https://www.customwheeloffset.com/w...42823/2014-toyota-tundra-fuel-vector-bilstein
    I like 20's with a 33 or 35'' tire I think. Trying to fit something where I won't have to chop a bunch to prevent rubbing.
    what do you think?
  4. Apr 30, 2020 at 7:18 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    3” front and 3” rear? Why are you wanting to raise the rear so much?
  5. Apr 30, 2020 at 7:21 AM
    A stock tire is a 32. A 33 will look small with a 3 inch. My truck has a 3 front and 2 rear. I run an 18 inch wheel with 0 offset and 285/70/18's which is right at a 34.
    Ely010606 likes this.
  6. Apr 30, 2020 at 7:27 AM
    vtdude27
    My mechanic convinced me a 3'' lift is the smallest lift you can go and OME is good quality. I didn't want to do spacers, leveling kit, wanted a good new suspension lift. Also I tow boat, and trailers for work, and like the look of a slight rake. I don't want the rear sagging to the ground whenever I pull a trailer. but was worried 3 in the rear would look wonky. Guess ill find out
  7. Apr 30, 2020 at 7:29 AM
    vtdude27
    I love the look of that, thanks for the pics! makes me feel much better, the 3'' doesn't look ridiculous at all like I was thinking. I think 34's are the golden size
    and you have 2'' in the rear, so 3'' will give me a slight rake look I'm looking for I believe.
  8. Apr 30, 2020 at 7:49 AM
    It's hard to tell with the pics but I do have a slight rake with the 2 in the rear.
  9. Apr 30, 2020 at 8:43 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    OME lifts are good, install and done, ride firmer and really help with off road, towing, hauling. With a 3 inch lift go ahead and get UCAs, you will be much happier having them and so will your truck.
    There is an entire thread in the suspension forum here on OME lift with pics and good info.
  10. Apr 30, 2020 at 9:25 AM
    Youngseed1249
    Youngseed1249 New Member
    08 crew max
    3 inch ready lift
    Get 35s trust me
  11. Apr 30, 2020 at 9:43 AM
    Yoder18
    Yoder18 Veteran underwater basket weaver
    Mitch
    Front range Colorado
    18 tundra trd off-road
    •Toytec Radflo 3” with 1.5 shackles •+25mm icon rebound wheels matte black. •Prox15 tonneau/Softtopper •315/70r17 ridge grapplers •Wheelers front bumper stops •Spray in bed liner •Vleds floorwell leds front and back and interior led kit •Boss front bumper spacer •First choice fabrication welded sliders •8” ss dirty deeds exhaust •Tech12volts remote start with carlink •Vleds front turn signals leds •AFE pro dry s air filter •Baja xl sport amber fogs •Victory 4x4 strike bumper w hoop •Ajt designs chrome delete for vent rings and cup holder/gear shifter (black) •Wet okole seat covers •Husky floor liners •RCI skid plate and transmission skid •Jomax SpEed sensor guards •Rear diff breather location mod
    Toytec radflo 3/1.5 lift w shackles in the back. Slight rake which is perfect. Also on 315/70r17 which is a like 34.5 not sure the exact number. You’ll love it, not too tall but much better than stock
  12. Apr 30, 2020 at 10:08 AM
    vtdude27
    WOW this is the absolute exact look I'm going for.. is your rear a true 3'' or just front 3'' and the rear a lower amount?
    Also what size tires and did you have to trim at all?
    Youngseed1249[QUOTED] likes this.
  13. Apr 30, 2020 at 10:10 AM
    vtdude27
    Awesome, thanks for the good info! also pardon my ignorance but what exactly should I be looking for in aftermarket UCAs ( stronger, different size to accommodate a new tire of angles of components after lifting? etc.) and what would that help with when getting a lift?
  14. Apr 30, 2020 at 10:13 AM
    frichco228
    Frank
    Virginia
    You just need adjustable UCA for the higher lift. Check out the toytec website, they sell the OME kit and offer UCAs as an option that are adjustable with factory style balls
  15. Apr 30, 2020 at 11:24 AM
    Youngseed1249
    08 crew max
    3 inch ready lift
    It’s a ready lift 3 inch spacer lift wheels are 20x9 +20 offset on Falken wildpeak MT 35x12.5 I did my bmc prior to getting my wheels but honestly I don’t think it would of rubbed I did remove the splash guard in the front
  16. Apr 30, 2020 at 3:33 PM
    Red_Leg
    Red_Leg New Member
    Will
    Mine is on a true 3in on all four corners. I ran the OME lift on my last truck. This one I am running just their rear springs with with coach builder +1 shackles.
    Are you going to tow or haul with this truck? If your going for utility and not just aesthetics then you want a true 3" on all for corners. Otherwise you are losing payload and towing capability.
    sbrannon02 and Youngseed1249 like this.
  17. May 1, 2020 at 4:36 AM
    vtdude27
    Wow that looks great. Seeing your truck on 3'' makes me realize that's not too tall at all, and I'm just not the biggest fan of monster wide, offset, wheels. Yours looks fantastic with that height even with stock wheels and more meaty tires. Ill be towing a boat and other trailers, not every week but here and there. So ill go ahead and stick with the OME 3''. Id rather have the capability at least
  18. May 1, 2020 at 7:10 AM
    Red_Leg
    Red_Leg New Member
    Will
    Thank you. I am running 285 65 R20. The tires are 1/3" taller then 35s and a inch narrower. I am running spacers for now. You will either need spacers or new rims to keep the tires from rubbing at full turn. I will be going to an 18" rim when I get my next set of tires.
    Just FYI sometimes you will need to do a body mount chop to get the tires to fit. The chop is not a big deal. I think people on here have had them done for $200. It's pretty easy to do if you want to save on labor.
