Old Man Emu front install help
Discussion in 'Suspension' started by SouthernFriedWerewolf, Apr 29, 2020.
  1. Apr 29, 2020 at 1:01 PM
    SouthernFriedWerewolf [OP] New Member
    Bailey
    2011 TRD Rock Warrior
    Old man Emu, wheels, tires,
    Hoping to get some guidance
    When I bought my 2011 Rock Warrior, it has a leveling kit on it, using the factory 4600 Bilsteins
    I replaced the rear shocks with OM-EMU and I'm still level, super nice!
    Question is on the fronts , I see a black spacer disk in each side, in between the top of the coil and the mounting tower. I guess this gives me the LIFT or leveling right?
    If I go with preassembled OME springs and shocks (Toytec), will they retain the lift/ leveling on the front?
    Or will I have to also install the spacers again to keep it LEVEL?
    Hoping to do this myself, using the preassembled units from Toytec ....
  2. Apr 29, 2020 at 1:11 PM
    crikeymike
    crikeymike ExitOffroad.com
    Jacksonville Beach, FL
    That black spacer is probably the leveling kit, depending how thick it is. You won't use that once you put in the new assembled coils. Those will give you the lift instead of using spacers.
    equin likes this.
  3. Apr 29, 2020 at 1:31 PM
    nishibot
    nishibot Just2havnfun
    Perris, CA.
    2017 Tundra CM 4x4 TRD Off Road MGM
    @Toytec Lifts give them a call. They will answer any questions you have
  4. Apr 30, 2020 at 7:19 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    Can you post up some pictures of that Black Disk along with some ride height measurements from the center of the wheel hub to edge of fender?
  5. Apr 30, 2020 at 10:56 AM
    Bailey
    Really appreciate all the responses! Called Toytec today to discuss.
    Fantastic customer support
    Nice to have them local too!
