Can you shove a 275/70/18 in the SPARE TIRE well??
Discussion in 'Wheels & Tires' started by mightyowl, Apr 29, 2020.
  1. Apr 29, 2020 at 2:54 PM
    mightyowl
    mightyowl [OP] New Member
    Just picked up some 275/70/18 all around. Would be great if I can have a spare that matches.
    Will a 275/70/18 "fit" in the factory location of the spare tire?
    Pictures if anyone has done so.
    thanks
  2. Apr 29, 2020 at 2:57 PM
    degs
    degs New Member
    2020 MGM Crewmax
    following
  3. Apr 29, 2020 at 2:58 PM
    timsp8
    NY
    That’s only 33.2”. Itll fit easily. Some people put 35s. Stock tire is about 32”, so it’s an extra 1/2” per side of a round tire.
    zcarpenter92 likes this.
  4. Apr 29, 2020 at 3:02 PM
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    Easily
    Zero One Actual likes this.
  5. Apr 29, 2020 at 3:13 PM
    MR TRD PRO
    MR TRD PRO New Member
    Queens, NYC
    2019 VooDoo Blue Tundra TRD Pro
    HP Tuned
    So 285/70R18s should fit fine as well I assume, as thats the size I'm most likely going with
  6. Apr 29, 2020 at 3:20 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 OR MGM 5.7
    That is a 34. You will need to do something about the brackets under there. I relocated mine forward, other people just cut them off.
  7. Apr 29, 2020 at 3:49 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    I'm glad that you took pictures - I did the same thing and forgot to take pictures (and have been to lazy to drop the tire just to take a pict ;)).
    I did the same mod that @EDDO did and I have my 35x12.5 under the bed. Before this I had an MT tire size 275x70 under the bed - it fit fine with no modifications.
    Ketchumj and EDDO[QUOTED] like this.
  8. Apr 29, 2020 at 3:55 PM
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    285/75/r18 here in stock location. Tire shop massaged the brackets with a sledge hammer though.
    Dixiescotsman likes this.
  9. Apr 29, 2020 at 5:08 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    That size should fit with no mods or bracket removal. I squeezed in a 285/75/17 BFG MT, which is around 33.8” in diameter. 285/70/18 is roughly the same size around 33.7” in diameter.
    MR TRD PRO[QUOTED] likes this.
  10. Apr 29, 2020 at 5:11 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    What year of Tundra?
  11. Apr 29, 2020 at 5:17 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    35s fit in the spare tire space.
  12. Apr 30, 2020 at 12:31 AM
    mightyowl
    does anyone have a picture of a 275/70/18 completely fitted in the spare well?
  13. Apr 30, 2020 at 3:26 AM
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    Here is a 295/70/18 spare tire under the truck
    equin and MR TRD PRO like this.
  14. Apr 30, 2020 at 3:32 AM
    devdomski
    devdomski New Member
    Devin
    South Jersey
    2018 SR5 CM 4x4
    Relocated the brackets and fit a 35
    F2553709-2B1B-4CCC-801B-8D336262EE53.jpg 2684F174-6DA1-442B-9665-33A6AFD2F742.jpg
    equin, EDDO, Skey44 and 3 others like this.
