Level Kit vs Bilstein Front Shocks?
Discussion in 'Suspension' started by jay131866, Feb 1, 2017.
  1. Feb 1, 2017 at 9:50 PM
    jay131866
    jay131866 [OP] New Member
    Which do you think is the better option to level the front of my stock truck? I dont want to lift the back, and dont want the front to be higher than the back. Just looking for a small 1-2" level. Someone suggested installing bilsteins on the middle setting rather than a level kit. I dont really offroad so i dont want to sacrifice ride comfort if the stocks make it way stiffer.
    Not sure which is better w regards to cost, ride comfort, gas mileage, wear and tear on truck components, etc. thanks for the help!
    jp_over likes this.
  2. Feb 1, 2017 at 10:05 PM
    Level..more options and better ride, IMO. I have the 3/1 BOSS kit
    Medic, Law323, Patriot and 1 other person like this.
  3. Feb 1, 2017 at 10:32 PM
    If you are worried about ride, stay away from spacer level kits.
  4. Feb 2, 2017 at 12:34 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    I'm pleased with my Bilstein 6112 on second setting and 5100's on the rear.Still have enough rake left to stay level when towing or loaded.Got the "package" from E-Bay for $759 shipped.
  5. Feb 2, 2017 at 4:49 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    X2
    SouthBoundSteve likes this.
  6. Feb 2, 2017 at 5:26 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Bilstein 5100s on top setting had my truck sitting level. They're better than spacers IMO, very affordable and the ride didn't suffer.
  7. Feb 2, 2017 at 5:26 AM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    +++1
    T-Rex266[QUOTED] likes this.
  8. Feb 2, 2017 at 6:01 AM
    jay131866
    So you left the rear of truck stock and just added the front shocks which made it level?
  9. Feb 2, 2017 at 6:02 AM
    14tundra
    14tundra On Wisconsin!
    WI
    2014 Platinum Crewmax 4x4 5.7L 1G3
    5100s top setting
  10. Feb 2, 2017 at 6:04 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yep. Originally I had 5100 (top setting) and stock rear and it was level. Measured the same as a stock Pro.
    Dgjman and (deleted member) like this.
  11. Feb 2, 2017 at 8:34 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    it depends on the lift. 5100 vs spacer lift, and the 5100s win hands down (or is that up?) 5100 vs suspension lift, and it becomes an issue of money vs. capability. If you really don't off-road, I should think the 5100s on the top setting would give you your best bang for your buck.
    jay131866[OP] likes this.
  12. Feb 2, 2017 at 9:44 AM
    jay131866
    So the fronts would be same as stock pro but the rear would be a few inches lower than stock pro version? I assume the Pros come with a rake stock but not positive. Thanks for the info!
  13. Feb 2, 2017 at 10:01 AM
    Tundra Pirate
    Tundra Pirate Bamf
    Kelly
    Stanley, NC
    2014 Super White Tundra Crewmax 4x4 Limited
    Bilsteins 5100 Leveled Method NV Machine KO2
    Bilstein 5100 adjustable front plus non adjustable rear set. Just purchased off Amazon prime for ~$350.
    Tophergt99 likes this.
  14. Feb 2, 2017 at 10:31 AM
    lightningtundra
    lightningtundra New Member
    2017 Tundra Crewmax TSS Off Road white/black out package
    I stay confused on this issue as well. I went to a local shop this weekend asking about the 5100's and he said why would you want to replace brand new shocks on 2017 since I don't off road and told me a pro comp strut spacer kit would do just fine. I haven't pulled the trigger yet because I get too many varying answers. This shop is well known and also sells on line as well so idk
    SC_HANK and BullyKnuckled like this.
  15. Feb 2, 2017 at 10:36 AM
    Tundra Pirate
    Tundra Pirate Bamf
    Kelly
    Stanley, NC
    Going with Bilstein 5100 level simply because my Limited is not TRD so has factory shocks.
    Two birds with one stone.
    Dgjman likes this.
  16. Feb 2, 2017 at 10:37 AM
    YotaDan
    YotaDan New Member
    Grants Pass, Oregon
    OP do you plan to drive the truck on back roads or off road much?
  17. Feb 2, 2017 at 11:26 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Pros are level. So with 5100, top setting, mine measured the same as the pro front and rear.
  18. Feb 2, 2017 at 11:29 AM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    6112's on 3rd setting. Sitting level, love the ride.
    These big boys.
    Stormtrooper81, ARES and Medic like this.
  19. Feb 2, 2017 at 12:15 PM
    jay131866
    No I pretty much never off road which is why I have such a dilemma. I don't want to sacrifice ride quality if possible. A few people recommend NOT using a spacer level, but a buddy who works on my cars said a spacer will be fine if I'm not off-roading. I'm not a super gear head so I don't know if a spacer or the bilsteins will provide a stiffer ride, or which is better/worse for the internal geometry of the parts. My truck is basically brand new (2016 w 2K miles).
    SC_HANK and YotaDan[QUOTED] like this.
  20. Feb 2, 2017 at 12:18 PM
    jay131866
    Good to know. But isn't the rear of the pros higher due to the shocks compared to the standard SR5?
  21. Feb 2, 2017 at 12:20 PM
    Zharris
    Zharris Merica!
    2016 Super White 4x4 Crewmax
    I've been looking at some old man emu suspension stuff. Seems pretty inexpensive compared to some of the others and has a lot of good reviews.
    Rancid13, Black Wolf and joonbug like this.
  22. Feb 2, 2017 at 12:24 PM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    2017 White Crewmax SR5
    They must sell a lot of spacer kits. Blocks are going to make it ride worse. I would avoid a shop advising this.
    http://www.bilsteinus.com/fileadmin/user_upload/user_upload_us/pdfs/Bil_LevShks_WebArticle.pdf
    plumber802, joonbug and 831Tun like this.
  23. Feb 2, 2017 at 12:27 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    As far as I recall it was the same height, certainly too close for me to remember a difference. Also, with a spacer you're losing travel and compressing your spring. So, it's bound to be a little harsher. I've been looking but can't find the info about whether the 5100 is longer than the stock 4600 but I'm inclined to think it is. I also don't know if, at top setting, that's the same amount of compression on a 5100 as putting a spacer on top of a 4600.
    joonbug likes this.
  24. Feb 2, 2017 at 1:07 PM
    YotaDan
    YotaDan New Member
    Grants Pass, Oregon
    How many miles are on the truck? Is it due for shocks anyway?
  25. Feb 2, 2017 at 1:40 PM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    They are pretty much bullet proof. If you like maintenance-free heavy-duty set-up, OME is an awesome option.
    Rancid13 likes this.
  26. Feb 2, 2017 at 1:45 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Nope, same height in the rear
    jay131866[QUOTED][OP] likes this.
  27. Feb 2, 2017 at 2:00 PM
    jay131866
    Its almost brand new, 2K miles. So no haha.
  28. Feb 2, 2017 at 2:47 PM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    This shouldn't sway your decision away from shocks. Its a ~40k truck that rides nice already. The difference is small with significantly more detriment on one option. Does the shop have a truck with a spacer lift on it you can drive? That will make the decision likely easier on you.
    Those who are telling you to put a spacer lift on it to save a couple hundred bucks likely give no crap to comfort.
    Stormtrooper81 likes this.
  29. Feb 2, 2017 at 3:03 PM
    rons23
    Ron
    Kill Devil Hills
    Pump the brakes just a little ej63090. I have had spacers on mine for 2 + yrs and ride quality is the same as when I drove it off the lot. If your not going off-road hardly at all, spacers are not that big of a deal. Obviously the Bilsteins (5100,6112) are your better choice. Just don't want some members getting the wrong impression that spacers are not an option. Budget could be factor, as it was for me. Short term fix for long term plans. Driving habits factor in quite a bit here.
  30. Feb 2, 2017 at 6:39 PM
    Medic
    Medic New Member
    Ontario, Canada
    2014 Limited Crew Max
    I had a spacer set 3/2 on my last truck. Looked great but the ride was a little stiffer. I am going to go with height adjustable Bilstein's this round. Sorry to hijack the thread but does anyone know the weight rating of the spring in a 6112 kit? I am on the fence between 5100 and 6112 in the front. I know the boss lift has 650 or 700 lb springs but it is twice the cost. Thanks
