  1. Apr 29, 2020 at 5:49 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    It delays the bag slightly if depending on where he seat is. It does have dual stage bags. I literally just have the sensor stuck onto the bottom of the seat since it’s magnetic! Lol. But at least now I have air bags
    NUDRAT[QUOTED] likes this.
  2. Apr 29, 2020 at 9:28 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    My pre-assembled coilovers came in today. The UPS driver had treats for my dog, tex! Smart idea for a delivery man.
    These are supposed to be adjustable.
    Although I'm not exactly sure how to adjust them. Any advice from those experienced?
    Still waiting on Alcan leafs to start the job, and new rear bump stop for the one I'm missing.
    Mountun Goat, bmf4069, NUDRAT and 5 others like this.
  3. Apr 29, 2020 at 9:56 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    @Tundra2 with 5100s the coil has to be removed and the lower coil perch has to be moved up on the notches, then coil goes back on.
    I don't know anything about those blue coils, looks like Dobinsons maybe, but they may not need to move up the perch for lift.
  4. Apr 29, 2020 at 10:26 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    They are Dobinsons. I'm assuming that what kind of spring doesn't matter for the adjustment. So I will need spring compressor if I want to adjust it?
    Which I'm thinking I will because it looks like I'm on the bottom notch, and the rear will sit 2 inches higher than that. :rofl:
    Thanks again @Darkness
    Now I just feel plain stupid for paying extra for pre-assembled units.
    :anonymous:
    You live, and learn. :thumbsup:
    I am doing my best not to "down talk" myself anymore. A mental health thing I learned recently.
    bmf4069, CodyP and crikeymike like this.
  5. Apr 29, 2020 at 10:47 AM
    oscardog86
    oscardog86 New Member
    Southern California
    Im no expert at all and still learning myself, so this could be wrong.
    But I believe the spring does matter for the adjustment. One spring on the lowest notch could give just as much lift as another "weaker" spring raised up 2 notches. So the spring you have now could still give you a level truck even on the lowest notch. Depends how heavy your front end is too.
    Also, I think its better to have a spring on the lowest notch giving you the lift you want, than to have a spring that has to be moved up to the 3rd notch to give you the lift you want as now that spring has been compressed slightly to almost artificially give you your desired lift.
    Basically, I could be wrong but if im not I think your pre assembled units could still work out well for you!
  6. Apr 29, 2020 at 10:53 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    This.
    Darkness and Tundra2 like this.
  7. Apr 29, 2020 at 10:56 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    You sure sound like an expert to me at least.@oscardog86
    Well, I'll still order a set of compressors I guess just in case I need them on install day.
    I didn't want to leave you out @chrisb. Sounds like I have a plan now! Lol
  8. Apr 29, 2020 at 11:30 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    What @oscardog86 and @chrisb said sounds reasonable.
    I looked at Dobinsons website and looks like they sell those clips with a stock-like shock and achieve lift, so put them on as is and see where it takes you.
    If you find that you need more lift later it won't be hard to remove those things and have a shop with a wall mount spring compressor do the job of moving the coils up a notch.
    I'm a rare non-believer in "pre-load" but along the lines of what Oscar mentioned, I find it much preferable to gain lift from a longer coil rahter than by the use perch adjustments.
    chrisb, bmf4069, speedtre and 2 others like this.
  9. Apr 29, 2020 at 11:55 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Compressors are not going to work on dobinsons coils.
    There is a technique used to compress coils without compressors. It's on YouTube. Involves using floor jack to raise lca which compresses coils then tightening top hat.
    It's awesome
    bmf4069 and NUDRAT like this.
  10. Apr 29, 2020 at 11:59 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I read that with sarcasm. Maybe I missed the mark on that.
  11. Apr 29, 2020 at 12:00 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    That sounds reasonable.
    Thanks again all. I look forward to installing everything.
    oscardog86 likes this.
  12. Apr 29, 2020 at 12:13 PM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Tundra2[QUOTED] and oscardog86 like this.
  13. Apr 29, 2020 at 12:35 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    That was an interesting watch. It took me 10 minutes to watch a 5 minute video because of buffering lol.
    TX-TRD1stGEN[QUOTED] likes this.
  14. Apr 29, 2020 at 12:38 PM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Spobrien84 likes this.
  15. Apr 29, 2020 at 3:51 PM
    Outbound
    Aaron
    Northern Alberta
    Washed and detailed today. Probably not to @War Machine 's standard but I'm happy. Hydro2 is awesome.
  16. Apr 29, 2020 at 5:27 PM
    empty_lord
    05 rollover special
    The Dobinsons should give you about 2” of lift on the lowest setting
  17. Apr 29, 2020 at 5:27 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Coo'
    NUDRAT likes this.
  18. Apr 29, 2020 at 5:27 PM
    empty_lord
    05 rollover special
    [​IMG] Got my bed extended brackets in.. so my Tacoma’s extender now works in the tundra too
  19. Apr 29, 2020 at 5:29 PM
    empty_lord
    05 rollover special
    And yes it clears mostly. It just barely grazes the lift strut, I’ll modify that to eliminate the issue eventually
    Tundra2 likes this.
  20. Apr 29, 2020 at 6:16 PM
    Army_of_One
    Army_of_One New Member
    2019 MGM 4X4 CrewMax, 2005 Cement 4x4 Double Cab
    OEM+
    What are we doing for bed lights? ;)
    Tundra2 likes this.
  21. Apr 29, 2020 at 8:51 PM
    mitchellrhen
    mitchellrhen New Member
    Rhen
    1st Gen Ivan Stewart
    Bought it this way....sorry.
    Spobrien84[QUOTED] likes this.
  22. Apr 29, 2020 at 8:53 PM
    mitchellrhen
    Rhen
    What are you using to paint?
  23. Apr 29, 2020 at 9:13 PM
    pock
    pock New Member
    USA
    2005 Access Cab 4.7L V8 4x4 SR5
    163B0E9B-4DD4-43A2-8052-20FAF23227A7.jpg C3E81864-1E89-4BBE-B4B0-FE7F5C6A5190.jpg
    Hey everyone.
    Clean tires are an essential business!
  24. Apr 29, 2020 at 9:14 PM
    empty_lord
    05 rollover special
    Baja designs dome lights wired to the cargo light are what I’m looking at. We shall see.
    Darkness likes this.
  25. Apr 29, 2020 at 9:34 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    If your located in metro Denver I have a Milwaukee High torque impact you can borrow. I would like to see it put to a test.
  26. Apr 29, 2020 at 10:39 PM
    fcgoulart26
    fcgoulart26 Ol’ Franky Boy
    Francis
    Denver, CO
    2002 SR5 Regular Cab
    None
    Got my Bilstein 5100's installed on the tundra as well as some new tail lights. I chose to set the perch at the third setting. Wound up leveling it out a bit. The shocks I took off were, not surprisingly, totally dead. On to replacing everything rusty underneath the truck and saving for a second set of wheels and tires.
    Mountun Goat, bmf4069, NUDRAT and 3 others like this.
  27. Apr 29, 2020 at 11:45 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    So, I registered my truck on toyota.com/owners and was thumbing through the service history, or lack there of.
    Only one record, oil change, and lower ball joint as covered by a recall it says.
    On May 19, 2006 my truck had 29,245 miles.
    My truck has literally officially been confirmed as being local with documents all this time. Its only been hearsay so far. Sold at the dealer 1 hour away from my house. Neat.
    I think pops said he bought the truck in 2007, with 31,000?
    Also, I remember reading somewhere that the "CK all weather" thing means you might have heated mirrors? Maybe I should investigate. It sucks driving in the winter and only having the rear view.Screenshot_20200430-014158_Chrome.jpg
    Mountun Goat likes this.
  28. Apr 29, 2020 at 11:52 PM
    empty_lord
    05 rollover special
    heated mirrors did not come with that, the larger battery, and better starter were the major editions.
    good news is most trucks are wired for heated mirrors. my reg cab was, just had to get the mirrors and the door side harness from a junkyard and a relay and switch. works like a charm
    Tundra2[QUOTED] likes this.
  29. Apr 29, 2020 at 11:56 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I'll have to look into it. So what wiring do I need to look for? And do you have part numbers or pictures of everything I'd need if I have the wiring?
    Also, the Toyota website won't accept the VIN for the Sequoia. Yet when I was messaging with Roman whenever he was around he never said he had an issue with it. I copied, and pasted into toyota.com from our ping-pong. Very interesting.
  30. Apr 30, 2020 at 12:08 AM
    empty_lord
    05 rollover special
    check your fuse box and see if the mirror heater relay is there or not. if it isnt it should be marked on the fuse cover, so see if the pins are in the fuse box. My box is different from yours otherwise id get you pics
