Rear Diff Fill Plug REFUSES To Budge
Discussion in '1st Gen Tundras (2000-2006)' started by MrAristo, Apr 27, 2020.
  1. Apr 27, 2020 at 3:35 PM
    MrAristo
    MrAristo [OP] Hounty Bunter
    South FL
    ‘01 4X4 Limited TRD
    Anyone got tips? Looking to check my fluid level as I recently sealed my axle leak. Using an impact wrench w 700+lbs of torque, 24 mm socket, and PB Blaster. No luck, just rounding the thing.
    2425F00D-F41D-40EF-9D49-A23867691CE1.jpg 8BB3CF25-3C2F-4F81-BC0A-ED6AE58DA3FD.jpg
  2. Apr 27, 2020 at 3:42 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Heat it. Then replace it. Shouldn’t do anything to the oil.
  3. Apr 27, 2020 at 3:46 PM
    stlfan
    stlfan New Member
    DFW
    2017 Tundra SR5 4x4
    2018 OEM LED HEADLIGHTS, BAJA DESIGN FOGS, PRO GRILL & SURROUND, 3M CRYSTALLINE TINT40%, 8" SS BAM EXHAUST.
  4. Apr 27, 2020 at 3:47 PM
    stlfan
    stlfan New Member
    DFW
    2017 Tundra SR5 4x4
    Friction drops might help, use them at work in aviation industry. Might be to gone for that though.
  5. Apr 27, 2020 at 3:48 PM
    Hitting it inwards will cause the crush washer to.....crush more, relieving some pressure on the threads and allow you to spin it off.
  6. Apr 27, 2020 at 3:51 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    any hopes of smacking a smaller socket on there?
    Filthyphil, MS22 and Brownsfanhere like this.
  7. Apr 27, 2020 at 4:08 PM
    Wilbur
    Wilbur New Member
    Savannah, GA
    2014 MGM
    buy a replacement plug, weld a socket on this one and go to town.
    bmf4069, YardBird, Darkness and 4 others like this.
  8. Apr 27, 2020 at 4:16 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    Do you have access to a wire feed welder? I have welded a nut on top of stripped bolts and removed them. Also, the heat from welding can help loosen the bolt.
  9. Apr 27, 2020 at 4:36 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Had to use the air hammer and chisel for mine.
    Inquiringone likes this.
  10. Apr 27, 2020 at 4:46 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Same thing happened to the drain and fill plugs on a Borg Warner t-case for an old Ford Bronco. It took a week of spraying penetrating lubricant every day until I emptied the can. Two weeks later I was able to remove both plugs.
  11. Apr 27, 2020 at 5:52 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    Have you tried grabbing onto it with big vice grip. If you could get it to grab you’re gonna have to put some stink on it and heat.
    15whtrd likes this.
  12. Apr 27, 2020 at 6:18 PM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    The welding bold/nut sounds like a good idea. Or try getting a slightly smaller socket and beat it on there for grip, and then try taking off with a breaker bar turning real slowly.
  13. Apr 27, 2020 at 6:30 PM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    Welding a nut on top is best and sure way, if you can get it done. That nut must been bad shape even before you used that impact.
    YardBird likes this.
  14. Apr 27, 2020 at 7:35 PM
    charliebison
    charliebison New Member
    Pipe wrench. Works like a charm.
    speedtre, nvrgvup444, revtune and 7 others like this.
  15. Apr 27, 2020 at 7:37 PM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    Maybe try a butane torch to see if it helps loosen it up?
  16. Apr 27, 2020 at 7:42 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    I suppose if you can’t weld a nut in, you could drill a hole and hammer in a torx drive socket.
    Tundra2 likes this.
  17. Apr 27, 2020 at 7:46 PM
    Hoff
    Hoff New Member
    2021 TRD OFF ROAD CREWMAX
    Pipe wrench or Hammer and Chisel. Been there done that.
  18. Apr 27, 2020 at 7:54 PM
    SouthWestGA
    I like @Hoff idea of pipe wrench
    Darkness likes this.
  19. Apr 27, 2020 at 7:57 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Yup. Heat it, beat it (like @FrenchToasty said) and pipe wrench.
    YardBird and Darkness like this.
  20. Apr 28, 2020 at 7:30 AM
    MrAristo
    South FL
    ‘01 4X4 Limited TRD
    Worth a shot. The bolt itself is pretty rounded as is so we’ll see.
    I do not, probably the most common solution I’ve found with these sort of things. If all else fails might need to invest in one.
    Yeah I used a medium size vice and gripped it pretty tight, beat it w a hammer and that did some of the rounding
  21. Apr 28, 2020 at 8:13 AM
    Danimal86
    Daniel
    Sacramento, CA
    maybe you could take a file and flatten the sides a bit to give the socket something to bight on.
    ultimately though, if the proper size socket and an impact didn't do the trick, i dont think this will be sucessful. I'd call a couple shops, have them weld a bolt on there and pull it.
    MrAristo[QUOTED][OP] likes this.
  22. Apr 28, 2020 at 8:15 AM
    TRDblvd
    TRDblvd New Member
    2019 Toyota Tundra TRD 4X4 Sport
    Like some others have
    This is worth a shot. Pipe wrench may be worth a shot too, better than vise grips.
    NewImprovedRon likes this.
  23. Apr 28, 2020 at 8:17 AM
    SouthWestGA
    Pipe wrench,made too small and hammered onto the plug??
  24. Apr 28, 2020 at 12:02 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Pipe wrench is worth a try but will be really awkward to use. It's a shallow bolt to put the wrench on and the center part of the diff bulges out, not a lot of room between the bulge and the bolt.
    If that proves to be too fiddly then get a big strong nut welded on and put a long extension on your wrench. If you aim your wrench handle at 3 o'clock you could put the stock jack under your breaker bar and use that to provide leverage.
  25. Apr 28, 2020 at 12:44 PM
    Go ahead and order a new fill plug while you're waiting. Might want to order a drain plug while you're at it. It could have been tightened by the same gorilla that did your fill plug.
  26. Apr 28, 2020 at 1:36 PM
    MrAristo
    South FL
    ‘01 4X4 Limited TRD
    Pipe wrench (one big enough) is near impossible. Just tried. Space between housing and bolt end is tight. Nvm the fact it’s already partially rounded.
    As always spot on Darkness.. see above..
    I’m most likely gonna end up bringing it to a buddies shop, weld a new one on and rip the sucker off.
    Gorilla would be an understatement. Ounces of PB Blaster + 700+lb impact not enough, that has to = Godzilla.
  27. Apr 28, 2020 at 3:10 PM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    I think the bolt didn't come out because you were accidentally tightening it. I have a similar Dewalt and the reverse button is flush when engaged.
    Alexstundra, bmf4069, MS22 and 5 others like this.
  28. Apr 28, 2020 at 3:15 PM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    Nice catch. My Kobalt is the same way. I’m constantly checking it to make sure it’s going the right direction
  29. Apr 28, 2020 at 3:19 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I have the same DeWalt gun. That ^^ is a true statement.
    OUCH!!!!
  30. Apr 28, 2020 at 3:46 PM
    unclebeejo808
    unclebeejo808 New Member
    Oahu
    Yup. If you zoom in you can see the arrow on the reverse button.
