Center Dash Speaker Not Working
Discussion in 'Audio & Video' started by DCB500, Apr 26, 2020.
  1. Apr 26, 2020 at 9:44 PM
    DCB500
    DCB500 [OP] New Member
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    So I am at my wits end with this one. I purchased the JL center tweeters from Tech12volts to replace my center factory speaker. Before I replaced I held the speaker up to my ear to make sure I was getting sound and then did the same after installing the JL’s and they worked.
    I also got the sail panels to move my focal tweeters from the dash to the doors, and then started really hearing engine noise coming trough them as they were now being run by the amp instead of the HU. Today I was trying to get rid of the engine noise and tried several things with grounding before I removed the HU to install GLI’s for the RCA’s. Nothing was disconnected but when I was putting things back together I was checking all the speakers and the center was not playing, so in rechecked all the connections twice and everything seemed in order. To test l, I hooked them up in one of the corner dash plugs and they worked in that location and from my understanding all 3 dash speakers run from HU power so how can the corner dash hook up work but the center now doesn’t all of a sudden?
    the engine whine is still there so need some advice on that as well please if anyone has any insight on this please share.
    Tundyfundy likes this.
  2. Apr 26, 2020 at 9:47 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
  3. Apr 26, 2020 at 10:00 PM
    DCB500
    Oklahoma City
    the 4 channel amp is wired directly into the factory amp harness under the passenger seat for speakers with separate power, ground, and remote. I tried scraping a spot to bare metal and creating a new ground - didn’t help. I tried grounding the HU and the same spot as the amp - didn’t help.
    but what really weird is after do that, and trying different RCA’s I went ahead and installed the GLI’s and there was still an amp hiss but the alternator whine was gone so I tested and listened for several minutes and it was gone so I put everything back together, started the truck and it was back! Obviously could be my amp that’s causing the noise but I have no clue why it was gone while the head unit was out but came back after re-installing.....nothing was disconnected and reconnected, just put the HU back in its location.
  4. Apr 26, 2020 at 10:19 PM
    Tundyfundy
    Bay Area, CA
    It’s being introduced into your system somehow. Did you install crossovers?
  5. Apr 26, 2020 at 10:21 PM
    Tundyfundy
    Bay Area, CA
    I’ve seen multiple guys have to run a drc-200 knob to get rid of the hiss.
  6. Apr 26, 2020 at 10:34 PM
    DCB500
    Oklahoma City
    no crossovers. Focal components have in line filter for the tweeters, amp crossovers are set to full and using the Kenwood HU for crossover settings.
  7. Apr 26, 2020 at 10:42 PM
    DCB500
    Oklahoma City
    There is no hiss with amp gain set to zero....turn the gain up just barely and the hiss returns, also gets louder with more gain.
  8. Apr 26, 2020 at 11:53 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    When you grounded the HU to the amp ground, did you bolt directly to the chassis of the HU? Or just the negative wire? Same with the amp(OEM amp negative wire or new wire form amp to truck chassis)? The reference for the audio path will be the chassis ground of the HU run a nice 10g wire from the HU down to the amp and reground the amp and HU. There is a threaded nut in the passenger sill close to the B pillar, I think it's an 8mm. Bare the metal around the hole and bolt both grounds together. That's where I grounded mine and I have zero noise. I also use Japan's Mogami ultra performance studio wire for my RCAs. You can pretty much wrap the wire around the alternator and not get noise. But the reference for those fancy cables is still the HU's ground. Hope this helps, I know you tried some of this already but it can very tough to track noise down.
    Also check the battery ground and possibly improve that? The battery is a natural filter for alternator noise, if it's got a bad cell it will show as noise too.
  9. Apr 27, 2020 at 8:48 AM
    DCB500
    Oklahoma City
    No did not ground the chassis, just ran the ground wire to the same location as the amp. And at the time I had also scraped to bare metal and tried a new grounding point for them amp that what it was previously.
  10. Apr 27, 2020 at 9:00 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Is the amp mounted on a wooden mount or metal? If it’s on metal then you need to get it off that.
  11. Apr 27, 2020 at 9:15 AM
    DCB500
    Oklahoma City
    It’s under the passenger seat on top of the carpet not screwed into metal.
    Mater[QUOTED] likes this.
  12. Apr 27, 2020 at 12:48 PM
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    2020 Tundra Platinum
    If it’s the stock HU you can’t get rid the whine. It’s caused by the BT module and it can’t be turned off.
  13. Apr 27, 2020 at 12:50 PM
    DCB500
    Oklahoma City
    kenwood DMX905S is the HU I’m running. Any ideas on the center speaker not working?
  14. Apr 27, 2020 at 1:02 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    did you talk with james? i'm sure he's seen just about every issue ever with the tundra stereo.
    DCB500[QUOTED][OP] likes this.
  15. Apr 27, 2020 at 1:04 PM
    AZBoatHauler
    So.Arizona
    If I'm following this correctly, you moved your dash tweets to the sail panels leaving the dash speaker connection unplugged? Supposedly the center channel pulls signal from the corner speakers so if there are no longer speakers connected to the corners I believe that is the reason you have currently have no sound in the center.
    I ran my JL component tweets in the sail panels hooked to the door speaker and put some Kenwood 3.5" in the dash corners and the same JL C1 center speaker you are using and have no issues.
  16. Apr 27, 2020 at 1:22 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    I'm just putting this out there, but the audio gods are sending you a sign!
    The first thing I did when I got my truck was disconnect the center channel. You are not in a Atmos theater. There is no place for a center channel in a vehicle, as you do not have an ear where you're nose is. You have two ears and that's exactly how many tweeters should be in an audio system, Left and Right just like your ears. If you're watching video ALL the time then maybe. But, ultimately when properly tuned, a component set in the doors, with the tweeters in the sails, will outperform any multiple tweeter array. If you have more than 2 tweeters up front, you should set your system to mono, otherwise you'll have phase issues too.
    This is just an opinion about the center channel, not any criticism of anyone or what they do with their trucks.
  17. Apr 27, 2020 at 2:13 PM
    DCB500
    Oklahoma City
    Yes that’s exactly what it is, spoke to James just a while ago. I knew they were connected but didn’t realize they corners had to be hooked up for the center to work.....so mystery solved on that one. James also seems to think my head unit is causing the noise so I am looking into warranty options for that.
  18. Apr 27, 2020 at 2:16 PM
    DCB500
    Oklahoma City
    Yeah probably not going to make a huge difference but just figured I would use the dash locations for a little fill in sound since it is hooked up. The rest of my system does really well, just read about those who had done it and figured I would try it.
    Toyotoholic[QUOTED] likes this.
  19. Apr 27, 2020 at 2:19 PM
    DCB500
    Oklahoma City
    alrighty then
  20. Apr 27, 2020 at 2:32 PM
    DCB500
    Oklahoma City
    Appreciate the help fellas! center speaker issue solved now just have to work on this engine noise issue.
