Helpppp!!! Found rust under back seats
Discussion in 'General Tundra Discussion' started by sillydadztrksR4momz, Apr 26, 2020.
  1. Apr 26, 2020 at 10:14 AM
    sillydadztrksR4momz
    sillydadztrksR4momz [OP] New Member
    Any suggestions and has this happened to anyone? Was vacuuming under the seats on the back and when I folded them up I see rust??!!!!
  2. Apr 26, 2020 at 10:15 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    What part of the country are you in? Probably surface rust from humidity
  3. Apr 26, 2020 at 10:36 AM
    sillydadztrksR4momz
    @CaptainGrumpus im in southern ca.
    @NewImprovedRon that would make sense since my little boy sits there and always has a water bottle.......what should I do. Steel brush it off??
    NewImprovedRon likes this.
  4. Apr 26, 2020 at 10:43 AM
    CaptainGrumpus
    Maine
    000 Steel Wool would be a good start. Go more aggressive if it doesnt remove it. 00 Steel wool would be more aggressive then 000.
    You can get the pads at any hardware store or Amazon
  5. Apr 26, 2020 at 10:47 AM
    devdomski
    devdomski New Member
    Devin
    South Jersey
    2018 SR5 CM 4x4
    Make sure you don’t have a 3rd brake light leak
  6. Apr 26, 2020 at 11:05 AM
    sillydadztrksR4momz
    Thank you so much for your help guys!
  7. Apr 26, 2020 at 11:07 AM
    CaptainGrumpus
    Maine
    If you can get in there with a spray can, Id hit it with some Rustoleum after removing the rust.
  8. Apr 26, 2020 at 11:08 AM
    TheBeast
    TheBeast The Beach
    might have been your kid dropping off water there :)
  9. Apr 26, 2020 at 11:14 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    What's he been drinking, pickle juice? I wouldn't think occasional water spills could cause that much rust.
  10. Apr 26, 2020 at 11:23 AM
    sillydadztrksR4momz
    @CaptainGrumpus ok I’ll order some now thanks again
    @bleach well just water...but that’s the only thing that makes sense. I guess over a period of time......I usually get the truck washed so I never really had a reason to look under there until now....
    bleach and StihlBuckin like this.
  11. Apr 26, 2020 at 11:46 AM
    devdomski
    Devin
    South Jersey
    2018 SR5 CM 4x4
    I had pretty much the same rust issue in my 16 Tacoma a few years back. Ended up being the 3rd brake light. Haven’t had that issue on my Tundra but it’s in the back of my mind.
  12. Apr 26, 2020 at 12:11 PM
    sillydadztrksR4momz
    @devdomski oh ok that’s good to know. What do I do if that’s the case?
  13. Apr 26, 2020 at 12:12 PM
    devdomski
    Devin
    South Jersey
    2018 SR5 CM 4x4
    Take it to the dealer if it’s still under warranty. With the Tacoma I just traded it in for the Tundra. Lol
    Edit: The cushioning inside the seats became wasted and smelled like mold. I wanted the Tundra anyway so instead of fighting with the dealer to replace the seats I just traded it in
  14. Apr 26, 2020 at 12:13 PM
    sillydadztrksR4momz
    @StihlBuckin thanks!!! I have a pro comp stage 2 with coil overs 35” toyo mt tires xd rims. I love it and just barely got it to fit in my garage lol
  15. Apr 26, 2020 at 12:14 PM
    devdomski
    Devin
    South Jersey
    2018 SR5 CM 4x4
    If it ends up being the 3rd brake light, or even what the other guy mentioned, you could just use some sealant
  16. Apr 26, 2020 at 12:17 PM
    spdrcer26
    spdrcer26 New Member
    Bakersfield, CA
    2017 Crewmax
    The rear seat and is easy to take out - remove it and steel wool with some black spray paint like others suggested- with the seat removed you can look under the carpet also to check for where water may have gone.
  17. Apr 26, 2020 at 12:18 PM
    devdomski
    Devin
    South Jersey
    2018 SR5 CM 4x4
    Did you change out the lights in the 3rd light? Like put LEDs?
  18. Apr 26, 2020 at 1:06 PM
    sillydadztrksR4momz
    @spdrcer26 ok will do. Thank you everyone for your help really appreciate it.
    @devdomski no never touched that light although thought about it a bunch never got around to it so that’s all original.
  19. Apr 26, 2020 at 2:20 PM
    sillydadztrksR4momz
    any special instructions on removing the seat I should know in advance? Thanks again guys
  20. Apr 26, 2020 at 2:48 PM
    devdomski
    Devin
    South Jersey
    2018 SR5 CM 4x4
    8 bolts. Easy, just heavy.
  21. Apr 26, 2020 at 2:49 PM
    TXTundra2722
    2015 Black Tundra
    Yes, the bolts are not all the same(different thread) so keep track of where they came from and don't set the seat down once you pull it up. It has a stud or piece of metal on the bottom that will punch holes in your carpet. I did it by myself, but an extra set of hands would really help
    devdomski likes this.
  22. Apr 26, 2020 at 3:33 PM
    sillydadztrksR4momz
    @TXTundra2722 oh ok I’ll note that. This is the single side i need to do passenger side. The drivers side back seat has no rust at all
  23. Apr 26, 2020 at 3:40 PM
    devdomski
    Devin
    South Jersey
    2018 SR5 CM 4x4
    Definitely good info there. I forgot about how i punched a hole in the carpet. Lol
    TXTundra2722[QUOTED] likes this.
  24. Apr 26, 2020 at 3:42 PM
    devdomski
    Devin
    South Jersey
    2018 SR5 CM 4x4
    The single seat side threads are the same and it is not as heavy. You can do it yourself.
  25. Apr 26, 2020 at 3:43 PM
    sillydadztrksR4momz
    How would I check for the brake leak? Just put water over it?
  26. Apr 26, 2020 at 3:45 PM
    devdomski
    Devin
    South Jersey
    2018 SR5 CM 4x4
    You could spray a hose at it from above. Just try to simulate rainfall. Then check for water inside.
    Edit: Although it could be forced in by wind while driving in rain? So maybe just shoot the hose at it. Lol.
  27. Apr 26, 2020 at 3:47 PM
    sillydadztrksR4momz
    Perfect. I ordered all the stuff you all told me about will do all that listed. Thank you again guys you’ve all been very helpful
    devdomski[QUOTED] likes this.
  28. Apr 26, 2020 at 3:49 PM
    devdomski
    Devin
    South Jersey
    2018 SR5 CM 4x4
    Are you out of your warranty period?
    Edit: I ask because by the looks of the rust, it could be somethings thats gone on for a while. And if its anything like my tacoma, you could have an issue with the seat cushion and mold. Just something to look into. Smell the seat cushion.
  29. Apr 26, 2020 at 4:09 PM
    sillydadztrksR4momz
    Yes I’m out of warranty it’s a 2015. And I’m in the truck now and I don’t smell any kind of mold at all. I’m double checking the drivers side back and no rust at all. Just the single back side but no mold smell
