E or D load range tire for 20" TRD Sport wheels
Discussion in 'Wheels & Tires' started by Rhino2220, Apr 26, 2020.
  1. Apr 26, 2020 at 1:21 PM
    Rhino2220
    Rhino2220 [OP] New Member
    2019 Tundra TRD Sport Crewmax
    I was wondering if there are any suggestions on a good all season or AT tire that's either D or E load range tire that will fit on the 20" wheel that comes stock on a 2019 TRD Sport. I recently purchased a new camper that has a giver of 5,500 lbs and plan on traveling long distances and want to be safe. Its not really an option right now to change wheels and tires and I currently have the stock Bridgstone Duelers which are a passenger tire. Thanks in advance.
  2. Apr 26, 2020 at 1:28 PM
    stlfan
    stlfan New Member
    DFW
    2017 Tundra SR5 4x4
    2018 OEM LED HEADLIGHTS, BAJA DESIGN FOGS, PRO GRILL & SURROUND, 3M CRYSTALLINE TINT40%, 8" SS BAM EXHAUST.
    I run BFG AT KO2’s 285/55r20’s on my stock Tundra with OEM 20” rims. That tire is D rated, might be worth a look, also come in E rated version. I’ve been happy with them, 47,000 mile and still plenty of tread left.
  3. Apr 26, 2020 at 1:32 PM
    Rhino2220
    Thanks for the info! I will give them a look. My stock tire size is 275 55 20 and was wondering if going to a 285 would cause any rubbing because of the sport suspension....
  4. Apr 26, 2020 at 1:36 PM
    stlfan
    stlfan New Member
    DFW
    2017 Tundra SR5 4x4
    not sure, my truck is a TSS version which is pretty much an appearance package, came with 20" rims and 285/55/r20's on stock suspension. I know my rims are a +50 offset not sure if sport rims are same offset.
  5. Apr 26, 2020 at 2:44 PM
    Rhino2220
    Thank you. I'll look into it
