help with spyder headlight adjustment
Discussion in 'Lighting' started by swede78, Jan 22, 2017.
  1. Jan 22, 2017 at 7:26 PM
    swede78
    swede78 [OP] Not so new member
    Lars
    westminster co
    2019 tundra platinum mgm crew max
    Nothing yet
    just bought some spyder headlights, projection u bar led with h1 halogen bulbs, like the ones in the other spyder post but for a 08 tundra. problem is when i have the low beams adjusted horizontal/vertical and turn on my high beams the pass side shines directly to the drivers side, while the drivers side shines straight. high beam reflector messed in wrong? i bought theses from carid.com going to call them tomorrow. also not sure about the low beam light output, dose not seem very bright, thanks for input.
  2. Jan 30, 2017 at 10:16 AM
    whammy_0
    whammy_0 New Member
    2010 Rock Warrior
    I tried putting mine in on my 2010, but couldn't get my low beam light to come on at all. Also, don't bother calling carid. just call Spyder directly, and press 2 for tech support extension.
  3. Jan 30, 2017 at 5:52 PM
    swede78
    Lars
    westminster co
    Nothing yet
    ended up sending pics to carid and am in the process of returning them for another set, hopefully they will be better. as for the low beams i had the same problem on the drivers side, i ended up sanding down the end of the pig tail from the lights to where it plugs into the factory harness, then it worked, it did not take much. hope you got your's working.
  4. Feb 1, 2017 at 7:40 AM
    whammy_0
    whammy_0 New Member
    2010 Rock Warrior
    Thank you sir! I'll be putting them in today. Hopefully we can make them work.
