2012 tundra wont crank after changing accelerator pedal position sensor
Discussion in '2nd Gen Tundras (2007-2013)' started by Lucas04, Apr 22, 2020.
  1. Apr 22, 2020 at 2:02 PM
    Lucas04
    Lucas04 [OP] New Member
    Raini
    2012 silver tundra sr5
    My 2012 tundra wont crank after changing the (apps)
    So I decided to change this part because my truck would start but wouldnt rev up and wouldnt have throttle response no matter what gear I was in. So after changing it I tried to start the truck and it wont crank now. Tried to disconnect the negative cable for 30 mins still nothing. I've looked online to try and find an ecu restart procedure and cant find one for this model. Does anyone have any ideas of what to do?
  2. Apr 22, 2020 at 2:43 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    It almost sounds like its in limp mode. Its hard to try to figure some of this stuff out as it would be a list of things that could be going on. Have you done any work to the truck lately?? Have you changed your spark plugs?? Have you done any modifications to the truck??
    I don't think it had anything to do with the accelerator pedal, and more to do with the possibility of a secondary air injection pump failure which would trigger the limp mode. Have you gotten any codes, prior to swapping out the pedal and prior to unplugging the battery??
    Another possibility would be a dirty MAF sensor, throttle body or even an AIC valve which all deal with the intake system. If you sit in the truck with the radio off turn the key to the on position and listen for a slight whine which means the truck primes which might mean you are getting fuel. Check your EFI fuse if that is working, check your sparks, finally it may be your fuel pump, which will require you to test your pressure which in the end might be your fuel pump. This is only a stab in the dark, without more information this can contract or expand as more information is provided.
  3. Apr 22, 2020 at 2:55 PM
    Lucas04
    Raini
    I havent done any work to it prior to this. I had drove home from work the day prior and everything was fine then I went to drive it and the gas pedal wasnt giving any response.
  4. Apr 22, 2020 at 3:27 PM
    blackdemon_tt
    how many miles?? does the dash light up?? does it make any sounds??
  5. Apr 22, 2020 at 3:31 PM
    Lucas04
    Raini
    50000 miles dash lights up and everything. Drove fine when I parked it too
  6. Apr 22, 2020 at 3:44 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Disconnect the battery, and put the original pedal back in. Reconnect the battery and let us know what you get.
  7. Apr 23, 2020 at 1:27 PM
    Lucas04
    Raini
    I just reinstalled the old pedal and I'm still having the same issue.
  8. Apr 23, 2020 at 2:41 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    Check all your fuses, even in the engine bay, with a multi meter. I'd check the ignition fuse first.
  9. Apr 23, 2020 at 2:45 PM
    blackdemon_tt
    Agree with the above Starter relay after the ignition. Going back to the stock pedal will not resolve the issue since something was tripped. Have you pulled any codes from it??
