Clipped wires...
Discussion in '2.5 Gen Tundras (2014-2021)' started by texasrho83, Apr 22, 2020.
  1. Apr 22, 2020 at 9:25 PM
    texasrho83
    texasrho83 [OP] Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Anyone know what these two wires go to? My money is on the VSC system as my Traction light has been on for some time.
  2. Apr 22, 2020 at 9:31 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    can you tell which connector they went too?
  3. Apr 22, 2020 at 9:36 PM
    empty_lord
    05 rollover special
    does your truck have an amp and aftermarket speakers? those might be the wires to the doors for the speakers the purple and pink wires coenside with diagram for the door speaker on the left front door. the red wire that appears to be spliced into them suggests that too.
    TheBeast likes this.
  4. Apr 22, 2020 at 9:38 PM
    That looks like a starter harness. Does it have remote start?
  5. Apr 22, 2020 at 9:45 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yes it does. Dealer installed
  6. Apr 22, 2020 at 9:46 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Beats the F outta me. I took it to a local shop who charged me $400 to "fix" my dash tweeters and tune an amp
  7. Apr 22, 2020 at 9:46 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yes.
  8. Apr 22, 2020 at 9:50 PM
  9. Apr 22, 2020 at 9:53 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  10. Apr 22, 2020 at 9:54 PM
    empty_lord
    05 rollover special
    i would believe the wires are for the door speakers then. they use to be part of the blue connector and were pins 18 and 17.
  11. Apr 22, 2020 at 10:04 PM
    South Texas Tundra
    South Texas Tundra New Member
    South Texas
    2024 Midnight Black CM TRD 4X4
    TRD PERFORMANCE PACK, TRD 3' Lift
    I dont know what those wires are for, but this looks like them, and are connected to something else...
    texasrho83[OP] likes this.
  12. Apr 22, 2020 at 10:09 PM
    empty_lord
    05 rollover special
    If they “fixed” the dash tweeters it was them cutting up the factory wiring to get it all working. I bet your center speaker doesn’t work at all.
    texasrho83[OP] and 1lowlife like this.
  13. Apr 22, 2020 at 10:21 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Dual voice coil center speaker comes off the side dash speakers.
    If the sides work, the center should too, I think...
    Unless they hacked in between the side and center dash speakers
    As others states, the colors certainly look like the left speaker.
    Does the dash fade left to right correctly?
    DOES the center speaker work?
    Sure looks like a hack job by whom ever 'fixed' your audio if those are indeed the speaker leads..
  14. Apr 22, 2020 at 10:38 PM
    empty_lord
    05 rollover special
    I think they bypassed it all because of the center speaker causing issues.
    I’ve seen it on other Toyota’s when people do a “quick” fix for odd sounding systems because of that center speaker
  15. Apr 23, 2020 at 6:13 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Reminds me about the cut wires near my amp
  16. Apr 23, 2020 at 6:45 AM
    cooper4x4
    cooper4x4 New Member
    2016 Tundra SR5
    trace the red wires and see where they go
  17. Apr 23, 2020 at 6:50 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    From the pic above your post it looks like they go to the amp.
    @texasrho83 Is your HU and amp stock or aftermarket?
    I'm guessing aftermarket since you paid to get it tuned and one of the cables by the amp looks like an RCA cable.
    Might be an amp ground wire I'm seeing..
    What HU and amp are you running?
