Spacers or Bilstein suspension lift?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by MatausTundra, Apr 21, 2020.
  1. Apr 21, 2020 at 10:39 PM
    MatausTundra
    MatausTundra [OP] New Member
    Andrew
    2017 Tundra 1794
    2k17 Tundra 1794, factory and want to level the rig with done lift. Advice and guidance would be great!
  2. Apr 22, 2020 at 12:16 AM
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    Saw this posted by @AccuTune Offroad in another thread, and think it should answer some of your questions. As stated in the original post, while this was made with a Tacoma, the same results will occur with Tundras
    https://youtu.be/pve9VtD39H0
    EDIT:
    I would roll with Bilsteins, and if you have the coin to drop, do the Bilstein 6112/5160 combo. They seem to keep everyone very happy, just a more heavy duty adjustable coilover than the 5100s.
    6112 Thread: https://www.tundras.com/threads/6112-setting-and-tire-wheel-combo-thread.23699/
    Good Luck!
    AccuTune Offroad likes this.
  3. Apr 22, 2020 at 8:02 PM
    MatausTundra
    Andrew
    2017 Tundra 1794
    What about shackles is this required when using a Bilstein Combo?
  4. Apr 22, 2020 at 8:14 PM
    SC_TRD
    Colin
    Round Rock, Tx
    Nothing is required, it’s all about what you like. Check out the thread I linked above, you can see how everything looks with different lift heights in the front paired with shackles or expansion packs or just stock in the Really whatever you want.
    here is the chart for the 6112s so you know how much lift you can get. After that is a matter of preference if you want rake or no rake
